Question about Olympus FE-210 Digital Camera
Help! Will not let me transfer images from camera
I'm trying to download the images on my camera to my PC. I've done it before with no problems. But now, when I click to start the transfer I get a first message "Retreiving thumbnails" and then all of a sudden the screen fades to white and I get the message "Olympus Master has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you of a solution if available."
I have followed through with the solution it offers but it still hasn't fixed the problem (find an error jpg or something).
Any ideas??
I have done a disk check, I've removed the software from my computer and reloaded it, I'm out of idea.
Can anyone help me?
Thank you.
  • Anonymous May 04, 2008
    i was downloading olympus 2, but there was a fatal error and i cannot remove it from my programs. How do i do this, it will not let me load pictures from my camera.
  • sharon_clark May 11, 2010
    I have Vista Ultimate
    President:
  • 2,712 Answers
Removing the software and reinstalling it using a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
2. Open the Windows Control Panel.
3. Open the Add / Remove Programs window.
4. Locate the listing for the camera software and remove it. When prompted to remove the camera drivers files, click Yes.
5. Locate any other camera software and remove it as well.
Now download the latest version of the software for your OS from the manufacturer's website.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, install the downloaded camera software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 03, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    IrishDruid
Transferring images
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com )
Jul 31, 2010 | Sharp VE-CG40U Digital Camera
Impossible to connect camera with PC. no driver in the PC for camera powershot A510. What's the matter?
Just figured this one out. Man, they don't make it easy. I'm borrowing my roommate's PowerShot A510 and since it has a USB port going out, I'd assume I could simply connect the camera to my PC and access my images directly. Almost every other camera I've seen will register itself to Windows as a straight USB connection (prompting the Windows screen asking how you want to open the connection - 'open folder' etc). This one just sits dead quiet about things :)
If you've just bought this camera at a garage sale or are borrowing it or for whatever other reason do not have the "bundled" software and driver CD or have the camera's serial number, do not bother trying to find windows drivers or try to obtain any software from Canon. You won't get very far.
FINALLY found the solution in the User's Manual (which was free thank God). You can download the manual here: http://usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a510#BrochuresAndManuals
(Select your operating system and download the "PowerShot A520/A510 Camera User Guide". File name is PSA520510CUG-EN.pdf)
In the User Guide, page 107 (I'll paraphrase):
1. Put camera in Play mode (the switch on the back (green arrow in green box)
2. Press Menu button (center one of the three along the bottom of the view screen)
3. In the 1st menu option (Play Menu, again green arrow in box highlighted), use the wheel button to scroll down to highlight "Transfer Order". Press Set (center of wheel).
4. You should now see "Transfer Order (DPOF) at the top of the screen and "Qty. of images 0".
5. Below "Qty of images 0" you'll see "Order", "Mark All", and "Reset". Order lets you select individual images; Mark All marks all current images for transfer; and Reset is reset. Press Set to choose.
Note: pressing the Menu button while selecting images brings you back to this main screen. If you are already at this main screen and you aren't ready to do your transfer yet, DON'T press the Menu button from this screen as it will initiate the transfer to your computer. Not a horrible thing, but might cause a mini freak-out.
7. Once you're selected the images you want to transfer, from the main Transfer Order window (now showing "Qty. of images" with a count of the images you selected), press the Menu button.
8. You'll see a white progress bar at the bottom of the screen. Don't worry! it's not deleting files or something bad.. (my first thoughts :) ..
9. Go to your PC and Voila! the Windows AutoPlay screen is now active!
10. Proceed with normal Windows USB operations (transferring at least, I didn't try any deletion).
I hope this helps somebody else out there who spent the last 3 hours trying to dig through internet hell to get this to work.
Atm, this is as much as I know so I probably don't have any good answers for any questions. Sorry :))
But, hope this helped at least!
Mar 12, 2010 | Canon PowerShot A510 Digital Camera
Question after I download my pictures to my pc. can I redownload the pictures back to the canon power shot a520?
As a part of the download process, most cameras and transfer applications ask you if you want to delete the images off of your camera once they've successfully transferred to your PC. Check the preference setting of the application you're using to transfer the images to your PC. Best way to check is to transfer images to your PC, disconnect the transfer cable and see if the images are still on your camera.
Nov 17, 2009 | Canon PowerShot A75 Digital Camera
Cannot download pics from a95 powershot
Afetr you plug your camera into your PC using USB Cable, can you transfer the images via my computer and selecting the camera from the devices with removal storage under the drives lists?
May 11, 2009 | Canon PowerShot A95 Digital Camera
Canon 20d raw to pc
Have you ever been able to view the pictures on your pc?
Have you got a card reader that can view the card contents externaly from the camera?
I found the Canon software is quite as happy from a card reader as it is reading from the camera. (I have the next model up, 30D.)
Have you tried upgrading your software, or tried using a third party image program to read the raw files?
Over to you!
Dec 29, 2007 | Canon EOS-20D Digital Camera
Image downloading problem
Eject your memory card from your camera and set your camera on default setting after that insert card and format it in the camera turn off camera power for 5 min. after this turn on it.
Oct 18, 2007 | Largan Mega 2 Digital Camera
Computer freezes up while trying to transfer images
Hi, The only reason your apps freezes is if it is having a hard time communicating with the camera and more often than not it is the memory of the camera that causes this. A couple of things you can try: 1. Rather than direct connection camera to PC, use a memory card reader. Remove the camera memory and use the reader to access/transfer the files; 2. It may be time to reformat the memory card itself which can be done by the PC through the card reader or the Format command in your camera; 3. retrieve files from the camera memory using a file recovery program such as "GetDataBack for FAT" and after all pictures/data/files have been recovered, do 2 above; 4. Try a different memory card (not necessarily same capacity) to check whether it is the memory or the camera itself; and/or 5. Reset you camera (powering off and removing the battery). Good luck and kind regards.
Sep 29, 2007 | Olympus Camedia D-390 Digital Camera
Could a photo printer corrupt my camera?
Do you have a memeory card reader? They work a lot faster than cable transfer. Get one if you don't, for about $10 or so, or borrow one to test your card. Then see if your memory card (the "disk") displays your pictures onto the computer through the card reader. If it does, your friend might have physically damaged the USB cable connector on the camera or the card socket inside the battery compartment (or, of course, you might have done so yourself somehow). As long as you have the card reader you'll still be able to transfer images. If the pictures don't show up on the card reader, it's more likely the card itself was damaged, though you say you tried another card. If you've already downloaded the pictures, try reformatting the card (which will erase everything) and then give it another shot.
Jan 21, 2007 | Canon PowerShot A540 Digital Camera
Olympus FE-210 Digital Camera Logo
154 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
