Question about Rinnai ES38N Heater
Rinnai convector 516/ 25A Gas heater (natural gas) ignition clicks over occasionally lights and runs a few minutes then cuts out Mostly doesn't even ignite before cutting out I opened unit to have a look if maybe it's dust clogged but way too complex so closed it up again. anything simple to do myself or .... what kind of tradesperson repairs these? Electrician? Plumber? Appliance repairs?
Therinnaiguy
  • 1420 Answers
SOURCE: rinnai convector 404
You have a dirty pilot assembly and maybe even a bad ECO switch (safety switch). I would suggest replacing the ECO and removing the pilot assembly and clean it out.
Posted on Jun 03, 2008
  • 4 Answers
SOURCE: rinnai natural gas log fire heater
12 is a fault code, look in the book if you have if, i think 12 is no or low gas pressure, cheers
Posted on Feb 05, 2009
taran_2005
  • 10515 Answers
SOURCE: manual for rinnai convector 516 thankyou
The manual would be
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/152.pdf
Thanks for using Fixya.
Posted on Mar 10, 2009
  • 53 Answers
SOURCE: Rinnai Convector 404 Natural Gas
No conversion parts available since 2005.
Posted on Jul 16, 2009
johnsonr1
  • 91 Answers
SOURCE: How old is my Rinnai Convector 516 TR?
2000 is the year of manufacture
Posted on Nov 13, 2009
506 convector rinnai
if the flame does not start at all, so just ticking from the ignitor you have a main valve problem and this is expensive replacement part and it must be done by a trained gas fitter.
May 21, 2014 | Heating & Cooling
We get a horrible smell occasionally with our Rinnai Avenger 25 nat.gas heater when alight. The filters are clean & was serivced last winter. It was making the smell at times even after the service. It...
From what you have described, it sounds like a case of delayed ignition or as the Owner's Manual calls it a "Combustion Control Fault"or "Incomplete Combustion". This can be caused by several things: A change in the gas pressure; dirty or clogged burner, electronic fault in the combustion controls.
Despite having it cleaned an services last Winter, 12 months have elapsed, with the unit just sitting and collecting dust and spiders. Portable Heating units should be serviced annually. Usually in the early Fall, before firing it up for the heating season.
Hope this helped you ... Cheers.
Jul 06, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Need to convert rinnai convector 417 gas heater from propane to natural gas, are the nozzles available?
Rinnai New zealand conversion kit number, R1852.
VERY complicated - get a qualified gasfitter to do it.
Jun 10, 2009 | Rinnai Vent Free Gas Heater/
Rinnai 560PTR Heater Converted Propane To Natural Gas No Ingition
I think you will find the thermocouple or thermostat has gone this allows the gas valve to open and is a saftey device to stop the escape of dangerous fumes .. it looks like a long piece of thin copper wire approx 4mm thick and it extends from the main valve into the pilot light flame .. When the ignition is pushed and you hold your finger on it for a while this tells the the valve that the pilot light is lit .. conduction of heat along this pipe then opperates the diaphram in the valve allowing the gas to the burners the pilot light then ignites them .. if the pilot light goes out the unit will nort run ..
My advice to you is that even though you may be conversant with the heater .. they do tend to have all manner of faults occur when left in storage or if shipped ( jostling and bumping ) is to get a trained gas engineer to check it out it may cost a bit .. but a gas escape and the following reprocussions are far more exspensive and costly .. Also You may not be aware that if you do have an incident your house ,insurance may be null and void if no service documents can be raised for the correct servicing of a fixed or mobile gas Convector .. I hope this helps Regards Vortash
May 22, 2009 | Heating & Cooling
RINNAI CONVECTOR 417 Natural gas heater 17.5 MJ Wanting to know if this is a decent model. Anything that may cause you to avoid buying this model? And about how old would this model be?
The 417 service manual is dated 2003, so they're no more than 7 years old.  You can download the operation & service manuals here:
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/161.pdf
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/161.pdf
May 06, 2009 | Heating & Cooling
Rinnai convector 516TR
Hi This is happening to us and I called Rinnai... they suggested that if anyone either in our apartment or an ajoining one has painted walls or varnished a floor that the convection heater picks up the smell and the only way to get rid of it is to burn it off by running the heater for several hours in a well ventalated room...
I am going to try it tomorrow.
will let you know
Jul 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Hi - I have a Rinnai Convector 406 gas heater which is 2 years old. Yesterday, it started cutting out with an error code of "12" showing in the display. It can be re-started but only stays on for a few...
I believe the 12 is the error code for "incomplete combustion". In this case you will want to start with the thermocouple. If you are not handy at these things I would call a service tech. You can find a service person on their website.
http://www.rinnai.us/
Jun 15, 2008 | Rinnai Heating & Cooling
Rinnai convector 404
Jun 03, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai ES38N Heater Logo
333 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
