Question about Hayward SAND FILTER, PRO SERIES
I have hayward sand filter model 244T. I just installed it 3 weeks ago and it appears it is not filtering. It circulates and backwashes good but the pressure goes back to 18 psi and doesnt change. The water is not clearing up. Could there be debris in the multiport valve that could cause this?
  • 8,404 Answers
18 is about what I would expect ... you shouldn't back wash until about 30.
If your water is cloudy ... take a look at the chemestry. Is this a gunnite or vinyl pool? Has the metal been removed from the water using a sequestering agent. What is the pH? Alkalinity? Oh yea ... how long do you run the filter? Should run at a very minimum 16 hours a day ... better to run it 24/7.
First, if you have not ... let the CH go to nothing ... put in some 'metal out' according to the bottle insructions. When the metal is gone ... next, get the alkinity to 100 ppm. Introduce Cl to 2 - 4 ppm. Get the pH to 7.4 - 7.6. Are you using stabilized Cl or liquid? If liquid, introduce 75 ppm Cynauric acid according to container instructions. What about calcium? Vinyl - don't worry about it ... gunnite - get the CA to 300 ppm. BTW - Don't dump all this stuff in at one time.
(presence of metal will turn the water green and possibly stain your pool)
If you fillow my lead, your pool will be sparlking in a couple days.
Posted on Jul 09, 2010
  • A Miller Aug 02, 2010
    Darn spell check ... it is no better than me ...
    Let the Chlorine go to nothing, if possible, before adding the sequestering agent ...
    ... and on second thought, you might want to have around 300 parts of calcium in you water
Hayward sand filter allowing dirty water to come through
1) Make sure that you have thoroughly backwashed the sand.
2) Make sure your chemical balances are correct
3) Remove filter canister top valve and insure that it was properly seated on the filters canisters center pipe.
4) Remove all sand from the filter canister
4) Clean all components thoroughly
5) Check for cracked laterals or plumbing
6) Repair or replace any bad or missing components
7) Reassemble
Tip: carefully use a rubber mallet to seat the canister valve by lightly tapping on and about the circumference of the valves seat.
Hope this helps,
https://www.oskopoolnspa.com
Jul 09, 2015 | Hayward SAND FILTER, PRO SERIES
How to get the right pressure to backwash and rinse
you dont need a lot of pressure to backwash just make sure water is clean coming out then rinse for 30 sec then put back on filter do not turn valve while filter is running you will ruin multiport gasket
Jul 18, 2014 | Hayward SAND FILTER, PRO SERIES
I have a S-244T sand filter and I am noticing that my water level is going down about 3/4
When the pump is running is water discharging from the waste pipe outlet?
If so then the selector valve that switches the pump outlet to waste, backwash, filtering etc. is faulty.
Aug 21, 2012 | Hayward SAND FILTER, PRO SERIES
When backwashing...sand discharges out backwash hose..
A little sand in backwash is not uncommon. Many packaged sand filter systems use pumps whose flow rates greatly exceed the flow capacity of the filter.(the more horsepower the better, right? - Wrong) If this occurs only during back flush the the pump is too strong or the sand level is above the beginning of the rounded top of tank. The sand level will eventually correct itself.
Aug 10, 2012 | Hayward SAND FILTER, PRO SERIES
I have a Hayward S310T filter. It's been running 24/7 for over a month. The water does not appear to be clear, even after floccing. How do I tell if the water is being filtered or if the filter is...
Backwash the filter. If the water coming out of the backwash line is not dirty you need a sand change. If the water is dirty you need to continue let the water filter and back washing once a week. Also make sure the six way is on filter and not recirculate
Www.theswimtimeonline.com
May 26, 2011 | Hayward SAND FILTER, PRO SERIES
Just installed a hayward pump and followed directions on the pump having problems when we tried to backwash it shoots sand into the pool
Backwash should put no water back into the pool. It should be sending filter dirt to a waste line. Maybe your lines are incorrectly installed?
Secondly, under normal conditions, sand does not go to backwash waste either. Could there be too much sand in the filter?
Gary
May 01, 2011 | Hayward Pool & Spa
I have a hayward S310T filter, cleaned 2 months ago sand replaced with "glass" and all ok. This week i did a backwash and rinse and vave put back to filter and now the filter empties via the...
Remove the screws holding the top of the valve into the valve body. Once removed lift the handle/cover assembly out. Depending on the model and age of the valve you will find a gasket of some sorts that sits between the portion you just removed and a surface or groove in the body. Reseat the gasket if you can for a quick bandaid then get a replacement part to fix it permanently.
John
Feb 08, 2011 | Hayward S310t Sand Filter with 30 " Tank...
We have a Hayward Pro Series sand filter S244T. It was installed 3 years ago. There is no indication of flow through the glass bulb on the back of the valve when the valve is in normal operating...
The sightglass is designed for backwash only, it allows you to see the degree of clarity in the effluent water. There should not be flow through the sightglass when the filter is in normal operation. Sometimes the pump will be alot louder when you backwash because there is alot less back pressure and it sometimes causes pump cavitation. The pump should quiet down when in normal filter mode. If not, there may be problems with the bearings and/or cavitation.
Aug 15, 2010 | Hayward SAND FILTER, PRO SERIES
Pressure up past 15 or 20 shortly after
The sand is clogged and needs a backwash or change.
May 25, 2010 | Hayward Pro Series 18" Above Ground Pool...
Reduced circulation/backwash (sand filter)
check your pool pump by putting the valve in recirculate mode.If flow is a problem it may be a clogged impeller.
Jul 05, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
207 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
