Question about Kenmore Dryers
KENMORE DRYER DOES NO START UNLESS THE TURN ON SWITCH IS HELD DOWN. IF IT LET LOOSE DOES NOT WORK
  • atocha_56 Jul 09, 2010
    kenmore model 110-64972301
    dryer that only work whwn the start button is kept pressed
  • 6,784 Answers
HI. The actual start switch will be the culprit. The switch circuit has failed. It is no longer able to hold a closed circuit. Use my procedure below to confirm the damage, and replace asap.
START SWITCH TEST:
Locate the start switch(Usually located in the control panel housing). it will have two or three wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a two wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the start switch, the reading should change to zero.
For a three wire switch, touch one probe to the terminal labeled NC (or CT1) and touch the other probe to the terminal labeled CO (or R1). You should get a reading of infinity. With the probes still in place, press and hold the start switch, the reading should change to zero.
If the switch fails either test, you should be replaced.
  • NOTE_Labeling on the switch terminals may differ.
Posted on Jul 09, 2010
    President:
  • 1,554 Answers
This is either an issue with the motor centrifugal switch, timer, or the wiring connection between the two. But most likely the first. Check for 120 VAC between terminals 4 and 6 of the motor centrifugal switch with the timer set to any setting and the door closed. It is indeed a faulty motor centrifugal switch and needs replacing should 120 VAC is present between these terminals. Otherwise, check the connection of terminal 6 to the timer. The issue is within the timer should the connection turns out intact, good, and snug fit. Replace the timer if that is the case.
Please indicate the exact model number of the dryer for the correct replacement parts and for further troubleshooting if necessary.. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from posting comments or follow-up questions. You can continue communicating with an expert as long as you need assistance regarding the issue stated herein.
  • Jahn27
    Jahn27 Jul 09, 2010
    The advice was posted prior to your posting of the model number. The problem would have been determined if the model number is indicated in your first post. Anyway, the issue is with the motor relay. Hold the Push-to-Start button for a couple of minutes to check if the dryer heats up or not. If it does, unplug the dryer then insert a putty knife blade between the console and the cabinet as shown to release the clips holding the console to the cabinet then rotate the console up.
    Use the heater relay near the timer in place of the motor relay near the Push-to-Start switch. Make sure to take note of the wiring connections of the relays before disconnecting them. Rotate the console back into position then plug the dryer in and start it. Replace the motor relay (part number 3405281) if the dryer continues to run with the heater relay used.
    Relay
Kenmore dryer wont run unless the start button is held down
the button has broken and needs to be replaced. Contact a local repairman or the place you bought it from
Aug 04, 2016 | Kenmore Dryers
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
I have a Kenmore 90 Plus Series that won't run
thats a sign ur start switch is bad again? test with a meter could have gotten a bad one
Sep 23, 2014 | Dryers
Dryer won't stay on without the button held in
Most likely the motor relay or the even heat board is bad.
Oct 06, 2017 | Kenmore 74992 Gas Dryer
Dryer stopped heating, still tumbles, also the push to start switch has to be held down now for it to work at all. checked voltage (good) checked cotinuity of all parts and all were good except the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Feb 09, 2011 | Kenmore 63942 Dryer
Kenmore Elite 73942 Gas Dryer only runs with start button held
Unplug the dryer. Open the control console.Mark and remove the wires from the start switch.
Using a volt meter set for continuity,touch meter leads to R1 and R2 while pushing the switch. No reading is a bad switch.
Touch meter leads to R2 and CT1. No reading is a bad switch.
If the switch checks out good the start windings in the motor are bad.
Dec 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore 73952, If I held start switch, dryer running, but not running if switch not held down. And no heat out when motor running
the motor sw ( a part of the motor) has stuck and is not working . it is a centrifical sw. / you may may correct it by cleaning out the motor . ( like blow it out with hi pressure air . if this does not work the motor will have to be replacedl .. mm
Dec 12, 2009 | Kenmore 73952 Gas Dryer
Kenmore-110.73952101 start button won't work unless its held down
It sounds like you need a start switch located on the motor To replace this you will need to get the 2 screws off where the harness plugs into the motor MAKE SURE THE POWER IS OFF :) Ask you locat parts placeGood luck:)
May 05, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
