Question about Crosman (4032)
I have a Crosman 2200 Magnum .22 caliber Air rifle.could you give me the link to order a Overhaul kit.it bleeds air through the barrel when trying to pump it up.it has sat for many years and just inherited it.i tried to lubricate the felt ring with Crosman oil but I think it has sat so long it needs new o-rings etc- Thanks!
  • 18 Answers
SOURCE: hi,i have a crosman 2200 magnum it wont hold air i need parts
you can look in your manual that you got with the gun and it says that you can send it in to crosman with $14 and they will send you a different gun. Yes they are used but they still work.
Posted on Feb 17, 2009
  • 3 Answers
SOURCE: Crosman 2104 Air Rifle
i had the same problem with my 2100. you would have to take it apart. the barrel is held in place with a small allen bolt. you would remove the bolt and slap some locktight on it and retighten.  that should solve your problem but i would think twice before taking it apart cuz its kind of tricky getting it back together and I would replace any seals while you have it apart. good luck
Posted on Apr 08, 2009
badenhop
  • 44 Answers
http://www.crosman.com/airguns/service/manuals/crosman-rifles
Look up the correct model (it depends on when your gun was made) and download the manual. Once you've identified the parts you need, just call or email crosman with your credit card in hand and they'll get you squared away.
Posted on May 13, 2009
agent91
  • 2100 Answers
SOURCE: 397 Ben/Sher .177 air rifle - installing repair kit problem
Crosman bought out benjamin / sheridan, and they still repair just all their pump guns. The ring sounds like a piece of a pellet, the barrels are silver soldered to the bottom tube, Not lead. Also, the repair kit should not have too many parts, you can only go so far with those guns before needing special equipment to get them apart. Get a hold of Crosman and tell them that benjamin sent you a bad part. They should fix it.
I had an old Benjamin Franklin in .22 cal, it was just a brass tube with a stock and barrel. I sent it to them, to be repaired, and I wanted the .22, because I had the 5mm and the 177. So I got it back, cost $29, New barrel, in .177, soldered on, new guts, new paint, trigger, bolt, the works.. Brand new gun. I told them I wanted the brass and I wanted the .22, They said oops, sorry. I didn't complain, nice old gun. Hope this helps.
Posted on Apr 19, 2010
tbreeze47
  • 3083 Answers
SOURCE: Need reassembly instructions for a
The following webpage has some excellent assembly pics and directions for this model:
http://airgundevelopment.com/crosman2200_exploded.html
This page should be enough to help you reassembly the gun. I found another web page that has various manuals, which might be of use to you, also:
http://www.stevespages.com/page7b.htm
Good luck, and hope this gets you fixed up.
Posted on Oct 29, 2010
How do u fix a crosman 2200 magnum .22 cal pellet
Depends what is wrong with it. The question has insufficient information for us to help you.
The easy answer is to take it to a gunsmith or air rifle shop.
Jul 18, 2016 | Crosman Optics
Can i but a new barrel how much
Bone Collector .177 and .22 cal special edition air rifles ...
www.gamousa.com > Air Rifle
The "BONE COLLECTOR" .177 and .22 caliber air rifles. ... blast reducer integrated into a bull barrel, and utilize the advanced IGT (Inert Gas Technology).
images for Bone Collector .177 Caliber barrel
Nov 07, 2015 | Gamo Bone Collector .177 Caliber Hunting...
Http://www.airfuns.net/faq.php#faq1
If you simple have the air go right thru each time you pump it, there is a little o-ring between barrel and the chamber, probably the one that needs replaced. Call Crosman and order by phone or go on-line.
Feb 11, 2013 | Crosman Recruit Multi-Pump .177 caliber...
I have a crossman phantom model cs1k77bv lost manual need to know where to put oil
Go to Crosman's web site for manuals:
http://www.crosman.com/cs/manuals/crosman-rifles
Jan 30, 2011 | Crosman Phantom .177 Caliber Break Barrel...
Pelet rifle won't fire
Does it leak out?, pump up?, trigger release anything? What are the symptoms? Anything stuck in the bore? I think Crosman will repair your gun at a fixed price, just get a hold of them and get permission to send it back.
Feb 13, 2010 | Crosman Phantom .177 Caliber Break Barrel...
Jul 29, 2009 | Crosman (4032)
Will not pump up in order to fire
open the pump handle and spray a little WD40 into the piston tube and let the gun stand **** down for an hour or so. close the handle and try again. It seems the piston sticks and then separates from the linkage in the pump handle.
Apr 03, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Where can I purchase a Breach Seal for a Crosman Spring Air Rifle, Model C1K77? The Product # is C1K77-008. Also, Can I replace the worn out seal with a standard "O" ring (black) found in most hardware...
I don't know if you'll read this but I too Have a Crosman Phanton among other Crosman rifles. You can call Crosman at 1-800-7-AIRGUN for a free breech seal if your rifle is still in warranty (One Year) or e-mail me and I'll send you one at no charge. Don't worry I have several and don't have a problem with giving you one.
Mar 05, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Crosman (4032) Logo
467 people viewed this question
Top Crosman Optics Experts
Anthony Coots
Anthony Coots
Level 1 Expert
raysaw
Are you a Crosman Optic Expert? Answer questions, earn points and help others
