I have a cable/ant tv and don't know how to hook it up to my reciever
    Sergeant:
    Champion:
  • 319 Answers
Need more info
Posted on Apr 19, 2008
  • Van Lake Apr 21, 2008
    Without knowing what TV or recv. you have, it would be difficult to say. If both are newer types, you might find audio outputs in back of TV. Use patch cables to hook up to receiver. Just about any recv. analog input will work with audio, except phono.
Hooking VCR to DISH Network Reciever Box
In order to diagnose the problem I need your help.
Have you hooked the dish receiver directly into a tv or another device and had it working?
Have you tried a different cable at all?
Have you tried pressing the ant. button on the remote or tv/vcr button?
Please update me with as much info as possible and I will figure out where the problem is coming from. thanks
May 04, 2008 | Toshiba W627 VCR
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
I bought a Sharp Aquos HDTV. Am trying to use a digital co-ax cable to run tv thru my reciever. I get no sound. there is only 1 place on each device to hook up this cable. Any suggestions?
I dont wish to assume that when you say receiver, you mean sattelite or cable. Since you may be trying to hook this up to a surround sound reciever...
Let me also clarify, if this is the case, the receiver needs to be turned on AND the selection signal device set to TV or AUX wherever it is you've connected the TV.
Now by receiver, if you actually meant cable or sat box, then the Ext antena from that service connects to that units ANT IN.
Then from there on that unit ANT OUT to your TV SIGNAL IN.
If you want the external surround sound and have the connectors for this. Then you need to send them OUT to the Stereo/Surround receiver TV IN.
Now having said that and assuming that your TV does not have the Red and White Audio RCA connectors... Your Sat or Cable box does... You connect those to the surround sound Receiver Audio IN
Hopefully you'll find this useful.
If this has not answered the situation. Please feel free to come back and provide all components your working with. Surround reciever, Sat, cable, DVD, VCR whatever etc. etc... I'd be more than glad to help you through this
Good Luck
Respectfully
Jun 10, 2011 | Audio Players & Recorders
Is it necessary to bring the signal from the ant. if I never intend to record? Do I still need to use the "out to tv" hook up?
If you want to watch TV you will need to hook the antenna to ANT. IN and run a coaxial cable from OUT TO TV to ANT. IN on the TV. Otherwise disconnect the antenna from everything. Good luck to you!
Dec 09, 2009 | Televison & Video
Tv converter
there is no way to convert your antenna/cable wire to use either hdmi or dvi. you must use either a cable box or satellite reciever. on any new tv sold within the last year there is a " rf connector " where you would attach the antenna or cable wire. take a look at your owners manual to find out exactly where.
Dec 28, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
EWF TV ANT IN BOKEN
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Nov 26, 2008 | Televison & Video
60" can not switch from ant a to ant b
Where can I find a bulb for this tv for a good price
Aug 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
EWF TV ANT IN BOKEN
ANGLS186-YES YOU CAN RESOLDER THE ANT. IN COAX CONECTION BUT KNOW YOU MUST FIRST SOLDER THE CENTER WIRE OF COAX TO TUNER BD. THEN CAREFULLY INSERT COAX BACK INTO ORIGINAL POSITION.THE EASIER SOLUTION IS TO USE A VCR OR CABLE BOX HOOKED TO YOUR SETS' VIDEO IN PORT AND CHANGE CANNELS W.THAT COMPONENT.JOE TV
Nov 19, 2007 | Emerson EWF2004 20" TV
"No Signal"
Might need a tuner, I suspect if you arent seeing any snow/static you probably need to press the tv/video button untill you get the ANT input.
Jul 31, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
71 people viewed this question
 Grubhead
Grubhead
