Trying to set up wireless and need pin# (8 digits)where is it? have (ssid)&(wep)#'s Help thanks
  • 903 Answers
Not sure what kind of router you have, but for many routers the default key is printed somewhere on the router, on a white sticker.
If you can't find it there, try checking the manufacturer's website.
Posted on Jul 09, 2010
I'm trying to connect wirelessly, but its asking for a sercurity key code! What is this and where do I find it? Help, pls!
Network security key
Some later model wireless routers have the Password (ie.Encryption key) and the SSID already configured in the wireless router and this information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adapters in your computer/laptop.
If these settings do not suit you, then it can be changed to suit your requirements.
The encryption key secures your data and wireless connection from unauthorized access.To configure the wireless settings in the router, connect a LAN cable from your computer to the wireless router, then open a Browser on your computer and enter the router's configuration IP address, then enter the admin login and password and then go to the wireless settings and configure the SSID and Encryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2 key.If you use the Passphrase method select either WEP or WPA or WPA2 to generate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to 63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born in January 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop, configure the wireless card in your computer/laptop with the router's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops can communicate with your wireless router. http://www.fixya.com/support/r10267861-network_security_key
Nov 22, 2012 | Computers & Internet
I forgot my WEP key for my ps3
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Mar 18, 2012 | Linksys Computers & Internet
How do I enable WEP encryption
Configuring WEP on the router First, let's log on to the router.
  1. Open your internet browser and type http://192.168.1.1 in the address bar. This is the default IP address of the browser.
  2. In the login box that appears type 'admin' (without quotes) in both fields. 'admin' is the default username and password.
Write down the SSID
  1. In the Wireless > Basic Wireless Settings menu you will see the Service Set Identifier or SSID. The SSID differentiates one wireless network from another. It is the 'network name'. Write it down, or copy paste it to a text file. You will need it later. You can first set your own SSID if you like.
In the Linksys WRT54G router you will find the wireless security options under Wireless > Wireless Security. This page allows you to set wireless encryption options.
'WRT54G The Wireless Security page allows you to generate a strong network key. Here is how.
  1. Select WEP in the security mode dropdown menu.
  2. Set the Default Transmit Key to 1
  3. Select 128 bits hex digits from the WEP encryption dropdown menu.
  4. Enter any phrase or word in the Passphrase field and press the 'generate' button. The passphrase is just used to generate keys. It has no other purpose.
  5. Copy-paste the first key to a text file or write it down.
  6. Click Save Settings.
Your computer will now be disconnected from the router. You may see a 'page not found' warning or some other error message in your webbrowser. Your router now demands that computers that connect to it use WEP encryption and the correct WEP key. In other words: you have succesfully secured your network.
Mar 18, 2011 | Linksys Wireless-G Broadband Router
I was trying to manually the router up as wireless.
If you want to connect to the router wirelessly you need to know the SSID or the Name of the Router (Nework Name) and the Network Key or Wep Key. The Default Wep Key is the 10 digit key located on the bottom sticker of the router. It is near the Bar Code. You can also personalize the Network Key by simly accessing the router. I've listed the steps on how to access the router incase the Network Key on the sticker is not working.
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
  • Connect to your SSID by clicking on START then click on Connect To, Select your SSID then it will ask you for your Network Key. Type the Network Key then hit Connect
Rate me if this helps so i can help others
Thanks for using Fixya.
Jan 31, 2011 | 2wire 2700HG-B Router (2700HGB)
We are trying to secure our internet but are not sure which number to use off of the rouder when it asks for the pin #.
Your wireless card in her laptop needs to be configured with the router's wireless settings eg. the SSID and encryption key
The encryption key (pin or security key) is in your wireless router, without this key the wireless router won't allow the laptop to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 29, 2010 | Linksys WRT110 Wireless Router
How do i connect a pin number from wireless router to a blackberry curve
To make things easier for try to do manual set-up instead and that will resolve all your concerns...Open an Internet Explorer browser page on your wired computer(desktop).In the address bar type - 192.168.1.1...Leave username blank & in password use admin in lower case...
For Wireless Settings, please do the following : -
Click on the Wireless tab
-Here select manual configuration...Wireless Network mode should be mixed...
-Provide a unique name in the Wireless Network Name (SSID) box in order to differentiate your network from your neighbours network...
- Set the Radio Band to Standard-20MHz and change the Standard channel to 11-2.462GHz...Wireless SSID broadcast should be Enabled and then click on Save Settings...
Please make a note of Wireless Network Name (SSID) as this is the Network Identifier...
For Wireless Security : -
Click on the Sub tab under Wireless > Wireless Security...
Change the Wireless security mode to WEP, Encryption should be 64 bits.Leave the passphrase blank, don't type in anything...
Under WEP Key 1 type in any 10 numbers please(numbers only and no letters eg: your 10 digit phone number) and click on save settings...
Please make a note of WEP Key 1 as this is the Security Key for the Wireless Network...
Click on Advanced Wireless Settings
Change the Beacon Interval to 75 >>Change the Fragmentation Threshold to 2304, Change the RTS Threshold to 2304 >>Click on "Save Settings"...
Now see if you can locate your Wireless Network and attempt to connect...
Jun 25, 2010 | Belkin (F5D8231-4) Wireless Router...
Trying to set up LInksys WPS54G, connected as
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every settings
Feb 12, 2010 | HP LaserJet 1320n Printer
Need my WEP Key and can't find it
Hi! To find the WEP key on your DLink DIR-655 wireless router, you need to access the setup page of the router by typing at the url: 192.168.0.1, then it will show the setup page of the router. on the left side, you will see Internet, Wireless settings, Network Setting, USB Settings, Select on Wireless Setting, then it will go to Wireless Network Settings, Under that you will see, Enable Wireless, Wireless Network Name, 802.11 Mode , Enable Auto Channel Scan , Wireless Channel , Transmission Rate , Channel Width , Visibility Status and under that you will see Wireless security mode and click the pull down arrow, and you will see, wep, wpa, wpa2, once you select one of the security mode, it will show on the buttom the option to setup the wireless security. If you have any question pls feel free to get in touch..
Sep 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
What is a ssid and a wep key. I am dumb.
SSID is the wireless networks name you want to access.
WEP is a special hexadecimal key to secure your network means if you want to connect a wireless network you will have to put this key.
It will be provided by the admin
Aug 12, 2009 | Office Equipment & Supplies
Need ESSID and WEP info for a Toshiba Satellite A205
The users guide for your laptop won't have information about ESSID or WEP for any wireless networks you are trying to connect to. SSID is Site Security Identification. That is the name of the wireless network you are connecting to and WEP is Wired Equivalent Privacy and is a key that is set up on the wireless network that if you don't know that key you can't use that wireless network even if you know the SSID. Each wireless network will have its own ESSID and WEP settings. If you control (I.E. you have the username and password for that router) the wireless router that you are settings up you control what the ESSID and WEP settings are. If you purchased the wireless router that you are trying to connect to, you might need a users guide for that router or if the company you get your Internet from owns your wireless router, you need to contact them concerning the setup of that wireless router.
Hope that helps.
Good Luck
Jan 08, 2009 | Toshiba Satellite A205-S4617 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
