Question about Hansgrohe AKTIVA BODY SPRAY - 28451931 - Polished Brass
I have a hansgrohe Activa Kiwa shower head in silver with gold rings and need to clean the head. Do you have the instructions, please? There is quite a lot of tough black over the head and I've undone the centre screw, taken out the first fittings, but the large plastic ring above is firm. How does it come out for cleaning?
4 Suggested Answers
  • 102 Answers
SOURCE: Leaking hand shower
If it is leaking right where the hose connects to the hand shower, there is usualy a rubber washer inside that may have shifted or need to be replaced. Overtightening is the number one cause for leaks on these. I would try to repair before replacing, as hand showers are costly. Hope this helps.
Posted on May 06, 2010
blueextc3221
  • 15935 Answers
SOURCE: loss of pressure in Hansgrohe shower panel
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
HANSGROHE US
  • 7 Answers
SOURCE: I replaced a broken Hansgrohe hand shower with a
Hi Christieb942,
When you get a new hand shower you can sometimes get sediment on the federally mandated FLOW RESTRICTOR. Not screaming, that is ****** in cheek. To CHECK the Flow Restrictor for debris, look at the hose connection end of the hand shower. You will see an INSERTED part that is green, yellow, or white. We have to push that in there to satisfy the EPA requirement for flow. You can pull it OUT and rinse it off. Then connect your handshower and try it and see if it is improved. You will not void the warranty in any way by doing this. I hope you understand what I am telling you, but if not you can call me 800-334-0455. I wish I could answer more directly, but Big Brother has eyes.
Posted on Sep 20, 2011
How do you unscrew Hansgrohe showerhead (needs cleaning to remove calcium deposits)?
Easiest is to simply pour some CLR cleaner (from grocery or hardware store, it is a brand name) into a plastic bag, and tie the bag around the pipe with the shower head soaking in the solution.
Easy fix!
Jul 26, 2014 | Hansgrohe Home
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Shower hose keeps disconnecting from metal connector
It seems you may need a new hose. You can contact Hansgrohe Tech at 1-800-334-0455 and we can handle the replacement for you.
Apr 10, 2013 | Hansgrohe 28274000 Techniflex 80in....
Hansgrohe shower head leaking
If the shower head is constantly dripping and not shutting off it is most likely the valve in the wall not the head itself. How is the head leaking? Where/when does the water show up? Feel free to contact Hansgrohe Tech at 1-800-334-0455. Press 2 for tech. We would be happy to help.
Dec 01, 2012 | Hansgrohe Home
Slow flowing hansgrohe shower head
First thing to check is the filter screen at the hose connection on the hand shower. If this screen is clean and there is no debris in the flow restriction device inside the handle end you will most likely need to clean the hand shower spray face. You can remove the unit from the hose and soak the spray face in CLR. Follow the instructions on the container for use and dilution. Soak for no more than 10 minutes at a time. After soaking, rinse the unit well and reconnect to the water source. Run water through it and while running rub the rubber spray channels to further clear up any deposits. Repeat the soaking and cleaning process at least two more times to clear out all deposits that may be limiting your performance. If you need more help feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be happy to help.
Oct 29, 2012 | Hansgrohe Shower 28504 Raindance S 100 Air...
Hansgrohe Clubmaster Kiwa head leaking from seal
For the Clubmaster shower head there is a rebuild kit available. This is part number 92027000 and is available through your local dealer or online dealer. If you need further help feel free to contact me at Hansgrohe. 1-800-334-0455 press 2 for Tech and ask for David Scarborough. I'd be happy to help.
Sep 05, 2012 | Home
Hansgrohe shower head water leaking out of connector
Is it a Grohe or Hansgrohe shower head? If it is a Hansgrohe shower head the first thing to check is if the self sealing filter gasket is installed at the connection to the shower arm. Hansgrohe shower heads have a black self sealing filter gasket in the head that some people remove assuming it is a flow restriction device. It is only a filter and does not restrict flow unless clogged with debris. Next make sure the flow restriction device below the filter gasket is still installed. On some models removing the flow restrictor will cause water to be expressed from the air injection ports near the pivot ball. Feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for Technical and ask for David Scarborough
Aug 20, 2012 | Grohe Home
Hansgrohe clubmaster shower head is dripping
First step is usually just taking off the shower head and apply a descaling solution but make sure you read the intructions for which material it can work on eg brushed nickel.
May 15, 2012 | Hansgrohe 28496821 Clubmaster Shower Head...
Insufficient hot water from Gledhill pulsacoil 2000
changing the shower head will not do anything.to do what you want,you would need more BTU's or a bigger unit to supply more water,someone may be hogging the water also.
Feb 25, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Hansgrohe AKTIVA BODY SPRAY - 28451931 - Polished Brass Logo
500 people viewed this question
Top Hansgrohe Home Experts
Shehu Pro
Shehu Pro
 John
John
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
