Question about Casio CTK810 61 Key Keyboard
How to play sa re ga ma - Casio CTK810 61 Key Keyboard
  • 127 Answers
Try looking it up on youtube some excellent piano and keyboard tutorials on there
Posted on Jul 09, 2010
Need korg ma-20 digital metronome owner manual
You can download the MA-20 user guide in word format from here:
http://tinyurl.com/cp6sddd
ciao
Bruno 0.5
Feb 22, 2012 | Korg Music
When I play the keys too fast the whole keyboard shuts off with how can I fix the problem as I recently just began learning the piano I will find it very unfortunate to have to bring it in for repair after...
Is it possible you have the wrong power adapter? Next to the power socket on the back of the keyboard it should say what voltage and how many milliamps it needs (eg: 9v DC 500 mA). You should find a similar rating on your adapter.
If the adapter doesn't quite produce enough mA the keyboard will happily sit doing nothing but shut off when you raise its power requirements by playing a lot of notes.
Aug 01, 2011 | Casio Lk-220 Stad 61 Lighted Key Keyboard
Do 4-10 devilles need to have the bias adjusted when replacing tubes?
When replacing the two output tubes you should check the voltage at TP26 or either cathode pin of the power output tubes to ground. Set the bias by adjusting pot R82 to 60mv which is 60 ma across the 1 ohm metering resistor. This coresponds to 30 ma per tube. Changing other tubes requires NO adjustment.
Apr 12, 2011 | Fender Hot Rod Deluxe Guitar Combo...
I've plugged my SX RST guitar into the SX GA-1065 amp but I can't get sound to come from the amp. I've made sure everything is plugged in and adjusted, but it still won't work. Why can't I get it to play?
Test the amp cable by plugging in the guitar cable an touching the end of the cord and you should get hum from the amp if the volume controls are up.
Many guitars require a battery to operate the preamp inside them.. Verify if yours needs a battery and it is fresh and properly installed.
These batteries are turned on by plugging in the guitar cable into the guitar. Leaving the cable in will exhaaust the battery, often within a day.
Sep 01, 2010 | Sx Guitars SX SST SE CAR + GA1065 STCAD...
Looking for a manual and playing instructions for a TLOK-SA Lowery with Genie
Here is the link to a source:http://www.organservice.com/lowrey/LowreyManuals.htm Here is the service manual in pdf:http://www.lowreyforum.com/manuals/TLOKS25Service.pdf
Jul 18, 2010 | Music
How do get this machine to do 3/4 time?
go in and create your own pattern, set the time signature to 6 beats per measure
Apr 04, 2010 | Alesis Sr 16 Stereo Drum Machine
I have a YAMAHA GA 24/12 mixer and 10 aux (all) no
Check that you have the gains INTO the aux channel from each strip you want routed there turned up... AND... the gains OUT of the aux turned up. Two places to adjust the gains.
The AUX LIKELY use TRS balanced outputs... check that you are using those.
These are a starting point, I do not have a manual for this device.
Feb 11, 2010 | Yamaha Music
Yamaha YPT310 use of wrong adapter fried fuse won't power up
1200 ma provides more power than the 700 ma, and would not be affected by using it on a device that draws 700 ma. The voltage of the charger makes a difference as well as the polarity of the plug. (if it is dc)
If the 700 ma charger is not working, most likely the 700 ma charger is not working
Sep 16, 2009 | Yamaha Portable Keyboard with 61...
Casio CTK810 61 Key Keyboard Logo
701 people viewed this question
Top Casio Music Experts
Ben Armstrong
Piyal Perera
Piyal Perera
Are you a Casio Music Expert? Answer questions, earn points and help others
