Question about Refrigerators
Water dispenser on fridge freezer is locked,how can I open it?
  • 146 Answers
Press and hold TO LOCK for 3 seconds to lock the dispenser.
Press and hold TO LOCK a second time to unlock the dispenser. The display screen indicates when the dispenser is locked.
If still the problem exists, then it means the lock must be jammed. Call your near by customer care of that particular product and place a warranty repair. Thank You.
Posted on Jul 09, 2010
My whirlpool fridge water dispenser won't dispense water but it shoots out a burst of water each time the door is opened even though I have the dispenser in the lock position.
I'd look for a pinched water tube where it enters the freezer door at the hinge. This would happen when you called for water, but got none because the tubing was pinched. Then, when you open the door and the tube flexes the pressure would be relieved and water would shower out of the dispenser (or on the floor if the tube was damaged.)
Oct 27, 2016 | Whirlpool Refrigerators
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have an admiral GC2224GEKB
You may have to open the door to let the dispenser thaw since it's in the door.
Sep 03, 2009 | Refrigerators
Water dispenser inside fridge does not dispense water
Are the water inlet / outlet correctly fitted onto the filter ??
Sounds silly - but very easy mistake seen several times.
Is the water supply for the filter turned on . . remove hoses from filter to verify. - YOU WILL GET WET.
Aug 15, 2008 | KitchenAid Architect KBRA20ERSS Bottom...
Fisher and Paykel fridge buttom freezer with water dispenser
Please advise where the dispenser is leaking? If it is dripping out the front of the door, then I suggest you run the water dispenser to flush about 3 liters of water. Does the noise stop when you open the fridge door?
Jul 01, 2008 | Fisher and Paykel Active Smart® E522BR...
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
