Question about Konica Minolta Magicolor 1600W Printer
Toner cartradges not rotating
  • Anonymous Mar 17, 2014
    c 352 is not dedecting yellow toner cartradge
  • 3 Answers
install remote panel utility and see status for more info
Posted on Jul 09, 2010
How can i fix the 'replace toner cartradge 'which is show in ricoh printer 4210
Please follow the steps to replace the toner cartridge on the attached link: http://support.ricoh.com/bb_v1oi/pub_e/oi_view/0001037/0001037078/view/hardware/unv/0084.htm
http://www-it.desy.de/systems/services/printing/help/Manuals/Ricoh/SP-4210/Manual/hardware/unv/0098.htm?lang=en;view=print
If the message Replace Print Cartridge remains, it means that it is not the correct toner cartridge, replace it with the correct one. If Reset Print Cartridge message appears after correct replacement, it means that the toner cartridge is not set correctly or not installed. Set the toner cartridge correctly. If the cartridge is installed, close the front cover and turn the power switch to off and to on. If the message appears again, contact your sales or service representative.
Apr 17, 2017 | Ricoh Office Equipment & Supplies
Di2510 toner bottle is not rotating
must have the block that turns the botle toner it works well
remove the toner click on f8 and watch the block rotates or not
Jun 01, 2014 | Konica Minolta DiALTA Di183F Copier
Toner bottle is not rotating
Open the toner bottle door,rotate the bottle mannualy 90 degr.and turn the copier ON.If the bottle rotated verify the toner level in the developing unit.If not rotate check the bottle motor and sensor.
Mar 05, 2013 | Konica Minolta Copier Toner 7155 7165...
How to remove error E000013-000 canon IR5000 Photocopy mashine?
Waste toner feedscrew (locked)It is likely that the feedscrew inside the waste toner pipe is preventedfrom rotating because of some fault. If the outlet of thewaste toner pipe is clogged with toner, remove the waste tonerdrive unit, and remove the toner. If otherwise, try turning the mainmotor clockwise by hand. If the screw rotates, wait and see whathappens; if the screw does not rotate, replace the waste toner feedingunit.
Jan 06, 2012 | Canon imageRUNNER 5000 Copier
I change a sensor from the cartradge and it refuse to get ready but shows f2 what will i do
Use the original toner cartridge though you have not indicated the particular model of the copier.
Dec 16, 2011 | Sharp Office Equipment & Supplies
Every copy has large black streaks across the page
Are the streaks horisontal or vertical on the page?
What printer? Laser or InkJet?
If laser, and streaks are vertical, you might have some dirt stuck in teh tomer cartradge or somewhere along the paper path
If laser, and streraks are horisontal, your toner cartridge might be dirty or leaking toner
Aug 23, 2011 | Office Equipment & Supplies
I want to repair my HP LaserJet 1020 Cartridge 2612A
my tonner problem is centere double line. so whats the problem for mu cartradge
Aug 10, 2011 | HP 12A Toner (Q2612A) Printer
I could not find the ink cartradge for the printer D3200 CAN YOU LET ME KNOW AT LEAST THE COMLATIBLE ON THE ORIGINAL CARTRADGE IS OC20 AND 0D10
u can order and get that via net.......just go for shoopin online.com .........here u will find that and u can purchase that by usin ur visa card and other cards
Oct 15, 2009 | Office Equipment & Supplies
Ds cannot read game data
To solve this problem, either:
1)Take a slightly wet soft cloth and wipe the back of the cartradge then blow into the space where the cartrege is inserted and then try.
2)clean the cartradge as shown above and continue this of a period of 2-3 Days and it may work.
(During this period do not insert the cartradge into the DS Lite. You may use other games.)
Apr 11, 2009 | Nintendo DS Lite
How to put a ink cartridge in a Canon i850?
LIFT THE FRONT COVER UP , GIVE THE PRINTER SOME TIME AND THE PRINT HEADS SHOULD GO TO THE CENTER OR RIGHT OR LEFT MARGIN PUSH IN AND DOWN.
----------------------VERY IMPOTANT-----------------------------
I THINK NEW CARTRADGES INSIDE THE PACKAGING HAS INSTALL INSTRUCTIONS INSIDE THE BOX WHEN YOU BUY IT FROM CANON INK CARTRADGE, OTHER BRANDS MAY DO THAT, IF NOT SURE OPEN BOX LOOK INSIDE AND SEE IF THERE IS INSTRUCTION ON HOW TO INSTALL NEW PRINT CARTRADGE
ROD
Jan 06, 2009 | Canon i850 InkJet Photo Printer
Konica Minolta Magicolor 1600W Printer Logo
324 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
