Question about Ryobi Garden
Ryobi PBC 3046YE strimmer starts but cuts out when speed control
Ryobi PBC 3046YE strimmer starts and runs on tickover but cuts out when speed control trigger is pressed
    President:
  • Ryobi Master
  • 1,545 Answers
A lack of acceleration in these units is most likely a fuel delivery related issue. It may possibly be time for a diaghram kit or carb rebuild kit to be installed in your carburetor. Ethanol in the gas deteriorates the parts that accomplish the acceleration procedure and may need to be replaced as they don't function anymore.
Many other things can affect these little machines as well such as clogged air filters, clogged crank case vent, clogged mufflers/exhaust ports./ spark arrestor screens...but more often than not, your problem is a carburetor issue.
Please look at the troubleshooting section on this Zama site PDF file
http://zamacarb.com/pdfs/TechGuide_2007.pdf
Posted on Jul 10, 2010
Ryobi Li-ion strimmer
check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
Jun 16, 2017 | Ryobi Drills
Adjusting the tickover and mixture
The carb is factory set you need to remove carb you will then see two screws one marked L and the other H with a small hacksaw cut a slot across both screws don't worry about cutting into carb body this can't be helped screw both screws fully in then back them off 1 and 1/4 turns this rough sets high and low running start saw set low speed first adjust screw in or out to get best low running then rev saw to max.and adjust max revs do the same as you did with the low speed screw to obtain max revs this should solve your problem.
Mar 07, 2015 | Ryobi Garden
What is the correct oill mixture for Ryobi 30cc pbc 3046ye
Normally it's 2.6 oz per 1 gallon of gas. Purchase the 2 cycle oil with the squeeze top measuring the oz and it gives instructions for the use.
Sep 26, 2012 | Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Hi, I have a Ryobi PBC 3046YB strimmer/brushcutter, which worked perfectly well in its first season, used about 10 times. When first used the following season, the machine would start easily, but when I...
This does not sound like an air leak, normally an air leak will cause fast uncontrollable idle, if it sounds muffled i would be looking at a blocked spark arrestor, or exhaust port, or muffler.Slacken the muffler right off and just try running it to see if it picks up normally.
Jul 18, 2011 | Ryobi Garden
Pcb 3046ye machine starts idles too fast touch throttle then cuts
Hi Ronald,
Not a lot to go on here.
If you are serious about getting an answer, include Make and Model. Describe your problem clearly, concisely and with as much detail as possible.
Often, a problem can be the result of a seemingly unrelated event. It is always a good idea to include a recent history.
Additional information such as what steps have already been taken, has the product ever worked, is it new, etc. can have a bearing on providing the best solution for your particular circumstances.
Remember, you are a key participant in this process. I am not there, you are. I depend on you to be my eyes and ears. I can only respond to what you provide me.
What you get out of the experience depends on what you put in to it.
So help me help you.
Best regards
Mike
Jul 12, 2010 | Ryobi Three Trimmer Combo
I have been given a ryobi 306rt petrol strimmer. It starts and then cuts out, I'm not sure of the exact settings as to how you start it up and keep it runnng. Any help would be apprciated.
To give the inital fuel needle mixture settings i would need to know the type of carb. on the unit ie. zama,walboro ect. it should say on the carb.,it may take a little hunting for. Second check all the fuel lines running from tank to carb. checking for craks or breaks.
Dec 26, 2009 | Ryobi Garden
My ryobi pbc-3046YE brushcutter wont run. When I start with choke it races for a few seconds then cuts out, if I get it started without choke it idles briefly then cuts out, if I try to accelerate it cuts...
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 09, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
2,438 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
