Hi my router wont connect to comp.need help making connection between router and computer
  • 3,037 Answers
Here's How:
  1. Choose a convenient location to begin installing your router such as an open floor space or table. This does not need to be the permanent location of the device. Particularly for wireless routers, you may find it necessary to re-position the unit after installing it as the cables / signals may not reach all areas needed. At the beginning, its better to choose a location where it's easiest to work with the router and worry about final placement later.
  2. Plug in the router's electrical power source, then turn on the router by pushing the power button.
  3. (Optional) Connect your Internet modem to the router. Most network modems connect via an Ethernet cable but USB connections are becoming increasingly common. The cable plugs into the router jack named "WAN" or "uplink" or "Internet." After connecting the cable, be sure to power cycle (turn off and turn back on) the modem to ensure the router recognizes it.
  4. Connect one computer to the router. Even if the router is a wireless model, connect this first computer to the router via a network cable. Using a cable during router installation ensures the maximum reliability of the equipment. Once a wireless router installation is complete, the computer can be changed over to a wireless connection if desired.
  5. Open the router's administration tool. From the computer connected to the router, first open your Web browser. Then enter the router's address for network administration in the Web address field and hit return to reach the router's home page.
    Many routers are reached by either the Web address "http://192.168.1.1" or "http://192.168.0.1" Consult your router's documentation to determine the exact address for your model. Note that you do not need a working Internet connection for this step.
  6. Log in to the router. The router's home page will ask you for a username and password. Both are provided in the router's documentation. You should change the router's password for security reasons, but do this after the installation is complete to avoid unnecessary complications during the basic setup.
  7. If you want your router to connect to the Internet, you must enter Internet connection information into that section of the router's configuration (exact location varies). If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider (you would need to have requested it), the static IP fields (including network mask and gateway) given to you by the provider must also must be set in the router.
  8. If you were using a primary computer or an older network router to connect to the Internet, your provider may require you to update the MAC address of the router with the MAC address of the device you were using previously. Read How to Change a MAC Address for a detailed description of this process.
  9. If this is a wireless router, change the network name (often called SSID). While the router comes to you with a network name set at the factory, you will never want to use this name on your network. Read How to Change the Router SSID for detailed instructions.
  10. Verify the network connection is working between your one computer and the router. To do this, you must confirmed that the computer has received IP address information from the router. See How to Find IP Addresses for a description of this process.
  11. (If applicable) Verify your one computer can connect to the Internet properly. Open your Web browser and visit a few Internet sites such as http://compnetworking.about.com/.
  12. Connect additional computers to the router as needed. If connecting wirelessly, ensure the network name (SSID) of each is computer matches that of the router.
  13. Finally, configure additional network security features as desired to guard your systems against Internet attackers. These WiFi Home Network Security Tips offer a good checklist to follow.
Tips:
  1. When connecting devices with network cables, be sure each end of the cable connects tightly. Loose cables are one of the most common sources of network setup problems.
What You Need:
  • A network router (wireless or wired)
  • Network adapters installed on all devices to be connected to the router
  • A working Internet modem (optional)
  • A Web browser installed at least one computer in the network
Please let me know if you need any further help and I would be glad to assist.
Thank you for using Fixya and Good Luck
Posted on Apr 19, 2008
Cant connect wirelessly to my router. have done all the steps like WEP setup, password and router name. just says failed when i try to connect wirelessly. and when i try to connect the router to my comp...
You will need to check the settings of the router. You said that if you connect the cable to the router and computer, it still doesn't work.
First make sure that the computer is able to go online when connected to the modem directly, without the router. If your computer is able to go online through the modem then your modem is working properly.
Now connect the modem and the computer to the router. check the IP address on the computer. open the set up page of the router. This is the page where you can change all the settings of the router. According to the type of Internet service change the settings of the router.
Click here for more information about the router and networking
Feb 14, 2010 | Linksys Wireless-G Broadband Router
I tried to set up my wrtg54 linksys with my new motorola modem from at&t. The linksys says it cannot find an internet connection. Of course, when ethernet is taken out of comp to plug into router, the...
Good day,
The AT&T modem(Motorola), is actually a modem and a single port router.
To work with the Linksys it must be set up in bridge mode. Then let the router make the decisions.
AT&T tech support will usually not help you if the router is not there product.
On Google, there are many sites that will help with this issue.
Unless you've already done it, you should contact AT&T by phone and request tech support on setting up your modem. They will talk you thru the whole setup, including testing but without the router.
Then proceed with the steps thru Google.
I do not know the settings for your specific router, but the forums will usually help.
I assume you're on DSL. Make sure they know that. Cable settings are different.
Dec 14, 2009 | Linksys Wireless-G WRT54G Router
I cant find the wireless switch to turn it my dad got a modem but i cant connetcet my laptop to it we tried everythink evern ring the help line but they could do and think help
hi
give a staic ip on the comp not the default gateway on lan
connection.
connect the comp to the access point
opent the access point GUI using the address on the bottom of
the access point u have
do the same w/l settings u have on the router and make sure
the security is WEP
then if u want to connect the access point w.l with router
then excange the mac address of each device into each other
if u dont want to make access point w/l to router then there is no need to exchange such mac addressess
then u need to change the ipaddress of the access point in the same range of ur router
then try to connect thru w/l network name and password if any.
you will be able to connect and go online
gud luck
thanx and regards
sukhiii
Jul 27, 2009 | Computers & Internet
How can I access the http://192.168.0.1 site so I can set up my d-link router as the click and connect cd is not working.
What is the IP address of the machine you are connecting to the router with? I has to be on the same subnet or it will not work. If it does not have an IP address, then start there. Network settings should be set to DHCP and then connect the cable to the router, reboot the workstation and it should obtain an IP address from the router, if not then troubleshoot that issue first.
Jul 23, 2009 | Computers & Internet
Hi im having bit trouble with my router it is a (f5d7231-4 the wireless connection works fine even though signal low,yet when i try connect another comp from it i keep gettin an ip conflictkeeps telling me...
Hello
do you have dhcp on your router or do you have static ip:n on your computers? sounds like you have same ipn on both computers. you should change it to DHCP. go control panel networks settings then rightclick on your connection and properties click tcp/ipv4 settings and properties, mark optain an ip address automatically, also set dns automatically.
Jul 02, 2009 | Belkin (F5D7231-4) Wireless Router
I have a laptop comp i just got a desk top comp i have embarq broadband internet which comp do i pit the cd into to install and which comp do i hook up the embarq box to?
It sounds as though you will need to get router to allow the sharing of the Internet between the two computers. Using a router makes it much easier to share an Internet connection between multiple computers. You would connect the Embarq box to the router on the WAN port, and then connect your computers to the LAN ports of the router. You may also want to get a wireless router in the event your laptop has a Wi-Fi connection.
Oct 06, 2008 | Computers & Internet
Need to connect router to deck top.comp.
This might work for you. Now to go in and configure the router thats something totally different.
To physically install the router
Step 1: Connect the power adapter Connect the power adapter to the router and plug it into an electrical outlet not controlled by a wall switch.
Step 2: Connect the router to the computer Disconnect the ethernet cable that is connecting the broadband modem to the network adapter in the computer. Connect the ethernet adapter in the computer to one of the LAN ports on the router.
Step 3: Connect the router to the modem Connect the ethernet port on your broadband modem to the WAN port on the router.
Step 4: Check link lights and connections
Check the front of the router to make sure the Power, WAN and LAN1 lights are on.
Jun 29, 2008 | Computers & Internet
G router wont work through vista or satellite dish
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 01, 2008 | Belkin (F5D7230-4) Router (587009)
Netgear
There are two things involved in getting disconnected either your comp is getting disconnected or your router.
Instance 1
Computer getting disconnected connect your comp and router with ethernet cable if using wireless. Because at times it's not router but the wireless connectivity that gets loost.
Instance 2
Router getting disconnected...
Reset your router by holding the reset pin at the back of your router for 15 secs and lights will start flashing on router wait for 1 min you'll have router reset to default settings and now check that dsl or internet light on your router is flashing or static if flashing contact your isp issue with the line if static run the disc for router installation again and it'll remain connected after successful installation.
Apr 22, 2008 | NetGear WGR614 Wireless Router
ROUTER PROBLEMS
You must configure your router..
Nov 01, 2007 | NexxTech 4-Port Ethernet Broadband Router...
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
