Question about Dometic Rooftop RV Air Conditioner
I have a Dometic Duo Therm rv Roof Air Conditioner Model# 59516.531.The fan is blowing and the compressor is kicking on but it is not blowing out cold air. Someone said it must be out of freon. Why would there be no freon? Can a technician add freon to this unit or do I have to change out the whole thing? please help!
  • Dometic Master
  • 6,674 Answers
These are a closed system.(meaning that there is no fill valves for recharging) But a heating & cooling technician can solder them on and re-charge the system. Only problem there is to get an estimate up front, and compare it to buying a new roof unit which also comes with a new warranty, as well as keep in mind that the freon went somewhere, so there is an obvious leak that will need to be addressed as well. Most times it's wiser and cheaper in long run just to buy a new roof unit.
Are you sure that the compressor is kicking in? Did anyone remove cover on roof and check lines from compressor to see if any cooling is occurring?
These don't often leak, that's why I'm asking. Any idea how old the unit is?
Perhaps in fairly new, it's a warranty issue.
Posted on Jul 09, 2010
2 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
Posted on Jun 05, 2010
Where can I find a shroud for my 2003 model 59516.331 duo-therm high efficiency Dometic roof mounted dometic RV air conditioner?
Try googeling Camping world ,Adventurerv ,or best rv and truck supplies ,these are all in the USA who deliver to Australia.I usually find that it is much cheaper to buy parts like this from the US even with the delivery charge.
Good Luck John
Oct 11, 2012 | Dometic Rooftop RV Air Conditioner
Have A Duo-Therm air conditioner on top of my motorhome and it stoped cooling, the fan works fine. Is there a fuse in the box under the filter? It says there is on the out side. I am not sure where it...
Can you please reply with model number off bottom of upper (roof) unit. Should be able to see it when filter is removed from ceiling assy. Please include model of thermostat if possible. You say fan works, but when turned to cool, no compressor kicking in? Try shutting unit off, and turn off breaker at panel as well, give it a few minutes and retry and see if anything changes and let me know.
Aug 16, 2011 | Dometic Rooftop RV Air Conditioner
Duo therm roof top camper a/c. fan runs but compressor stopped kicking on all of a sudden. replaced both capacitors; getting 110 to compressor but it still wont kick on
Sounds like the compressor is toast...if the caps have been changed and there is voltage there, you have done all you can...replace the compressor or buy new...
heatman101
Sep 01, 2010 | Dometic Rooftop RV Air Conditioner
RV Dometic Duo Therm roof top AC w/heat pump Model #630515.321El Serial #21631212 Yr. 2003. It is the rear unit, front unit working fine. In AC mode it is blowing hot air as if the heat pump is on. Fan...
If the Air comeing out is the same as the temp inside the RV make sure the compressor is running and not just the fans. It could be low on freon. If freon is ok then you would need to ck the wiring to the selector switch for a short. It would be obviouse because there will be melted wires. I am leaning toword low on freon since you have already been inside the wiring/control unit.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
Compressor won't kick off
What happens when started in just fan mode? Sounds like relay stuck.
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Have Duo Therm roof mount A/C. Fan runs but when compressor tries to come on it just has a hum sound for about 10 seconds then after a short period of time it tries again but will not kick on
It sounds like the compressor is locked up. You can try a start boost or hard start kit but once this starts the compressor is on it's way out.
Feb 25, 2009 | Dometic Rooftop RV Air Conditioner
Duo-therm by dometic ac rv unit
I suspect that you have a bad selector switch for the on, off, low fan, high fan operation. If the selector switch is put into the off position everything should stop completely.
Apr 30, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
718 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
