Question about Toys
Bent out of shape!! really badly! how do you get it back into shape so it stayes on for goodness sake! thanks
  • 431 Answers
WHAT!
Posted on Jul 09, 2010
My rake's tines got all bent out of shape can they be bent back into shape?
You can bend them back using a vise grip, but it might be worth it to get a new one for $10 if they're bent badly.
Jan 26, 2014 | Garden
My coils are croocked
Oven coils are able to be bent back in to shape if your gentle, if they are badly bent then replacemrnt is the only answer.
Oct 16, 2013 | Whirlpool Stove Oven Sensor 8053344
The back trunk of my car doesn't stay open. There are two rods that are situated in the trunk, as I had shown, in order to keep the trunk cover open. The rod is probably bent out of shape and that's w
Jake,
I can't really tell from the video what should go where. Find another Nissan Sentra of the appropriate year. Try a used car lot, junk yard, Nissan dealer, or just stop one on the street and ask to see their trunk. When you see a Nissan with a working trunk, your solution should be obvious. Take your trusty camera along just in case. You may be missing parts, so the junk yard is probably my first choice.
Anyway, make your car look like the one that works and you should be good to go.
Nov 06, 2012 | Cars & Trucks
The arm on the pram hood is sprained which is inside the hood not on the outside, it does not stay straight when I put the hood fully up, it goes down into a v shape whilst the other side stays straight,...
You may be able to bent it back still inside the hood - otherwise you will have to unpick stitching around the hood to reveal the metal frame and then sort out how to fix it.
Get back to us if the first step doesn't work.
Good Luck
Feb 25, 2011 | Toys
I purchased the toy story bed tent for my daughter and misplaced the instructions on how to put it together so if you could provide me with this I would really appreciate it
there are four pockets on the inside of the tent which hold the ends of the pole with the string in them. connect all the poles with the string in them. bend it in a (n) shape and stick the ends in the pockets. the poles are bent so as to give the tent height not depth, do the same for the rear of the tent. the twelve other poles are connected using the small connectors. one connector for two poles then stick those poles into the front and rear (n) shaped poles in the empty connector spaces already on the pole you bent. remember when you bend the pole they will not stay bent until you stick them into the inside pockets in the tent. the nylon straps at the bottom of the tent help the tent to hold on to the mattress. its simple enjoy. i put all the poles together first and then had my helper to hold it in a (n) shape until i could stick the legs into the pockets. look inside the tent once together you will see where you need to tie the nylon straps to the poles
Jan 08, 2011 | Disney Toy Story Indoor Bed Tent With Push...
Leak at the top of seal
use a hot cloth to mould the seal back into place,once bent to shape it will stay that way.
May 21, 2010 | Whirlpool GB2SHDXP Bottom Freezer...
My honda Civic 04 whistling noise
Check the protective backing plate for the brakes to see if its bent. Look at the opposite side to get a good idea what it looks like to bend back into shape if so. If bent they will create a noise or whistle effect
Feb 04, 2010 | 2002 Jaguar X-Type
Can a bent frame be fixed?
Yes any good reputable alignment shop can fix u right up
Nov 20, 2009 | 2003 Mitsubishi Galant
Rotary cutter shakes
If a roc bent the pan - I dont see how that would make it shake..
I suspect the shaft..
Hoe this helps !!
Jul 14, 2009 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
Problem turning on unit with SD card
Make sure all the contacts that the SD card touches are even in the back. Sometimes the contacts will be bent out of shape and end up grounding themselves. So, get you a pair of tweezers.. and look closely. dont' be afraid to bend them back.. they shouldn't break off. Good Luck. -Daniel
Nov 13, 2006 | Magellan eXplorist 400 GPS Receiver
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
