Phaser 6110mfp stuck in fax mode, won't copy - Office Equipment & Supplies
    President:
  • 2,072 Answers
NOTE: The Phaser 6110MFP|XN is preset to the Fax mode, but can be switched between the Fax mode and the Copy mode.
  1. Press the [Menu] button on the Control Panel until 'System Setup' is displayed on the bottom line of the Display Screen, and then press the [Enter] button.
  2. Press the [Left] or [Right] arrow button until 'Machine Setup' is displayed, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until 'Default Mode' is displayed, and then press the [Enter] button.
  4. Press the [Left] or [Right] arrow button until the required default mode is displayed, and then press the [Enter] button.
  5. Press the [Stop / Clear] button to return to the Standby mode.
Posted on Apr 21, 2008
How to write firmware to this printer?
Try this link:
http://www.support.xerox.com/support/phaser-6100/downloads-fx/enau.html?operatingSystem=win7x64
Firmware can only be updated thru CenterWare.
You need to download the software from both links and install in date order alder first.
Jan 19, 2016 | Xerox Phaser 6110 Mfp 6110mfp All-in-one...
The copy fanctions does not work well. The copies are deformed
Please follow the link below to reinstall the drivers as the driver for copy have got corrupted. Follow the link verbatim.
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
Dec 14, 2010 | Xerox Phaser 6110MFP All-In-One Laser...
I can not install this printer in windows7 operating system
Hello.
Unfortunately, Xerox doesn't yet offer Windows 7 support for your device. However, they announced a release of the Windows 7 driver until June 2010.
Still, you can try installing the Windows Server 2008 driver:
http://download.support.xerox.com/pub/drivers/6110MFP/drivers/win7/cs/Phaser_6110MFP_W7.zip
Source:
http://download.support.xerox.com/pub/drivers/Compatibility_Matrix/other/win7/en/Windows7_Matrix.pdf
Now ... are you sure your device is not 6110MFP? Because Xerox Phaser 6110MFP does have Windows 7 support and you can download the driver here:
Mar 30, 2010 | Xerox Phaser 6110 Laser Printer
Mac OS 10.6 Snow Leopard: Printer Driver Update for Xerox Phaser 6110 does not work ! Xerox/Apple is providing a most complicated instruction to circumvent the problem that I am not able to...
    1) Change the “Xerox” Folder Permissions:
    • Navigate to Applications > Utilities and open a Terminal window.
      • Type the following command: sudo chown -R root:admin /Library/Printers/Xerox
    • You will be prompted to enter your password.
    2) Install Rosetta from the Snow Leopard DVD:
    • Insert the Snow Leopard Install DVD
      • Select Optional Package
      • Select “Rosetta only” from the list of optional packages
      • Click install and follow instructions to complete installation; there is no need to reboot
    3) Reset Printing System:
      • Navigate to: System Preferences> Print & Fax> Xerox Phaser [6100, 6110, 6110MFP]
      • Right click on the printer
      • Select Reset Printing System
    4) Install Printer (without removing the driver):
      • Select +: add the available Xerox printer
Mar 18, 2010 | Xerox Phaser 6110 Laser Printer
Phaser 6110 mfp , the display say that the scanner is locked , I don't have the manual with maiself
Check here.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=465,E=0000000001733349606,K=391,Sxi=10,Case=obj%284350%29
Oct 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Xerox 6110 MFP scanner locked
The Xerox 6110 MFP has a green 'lock/unlock' slider on the "roof" of the "out" paper tray (under the front control pannel assembly); see images below. When slide to the back, it locks the scanner, and to the front unlocks it.
75884d7.jpg Front of the Xerox 6110MFP howing paper output tray and control panel.
7020767.jpg Xerox 6110MFP showing the output paper tray and the 'green' scanner slide lever in the roof of the tray.
Feb 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Xerox Phaser 6110MFP reports FM_IO.c 172 ROOT during startup
Also make sure you have the machine plugged directly into the wall outlet...some surge protectors or multi-outlet strips won't allow sufficient power to properly boot up and run the machine !
Dec 10, 2008 | Xerox Phaser 6110 Laser Printer
Xerox phaser 6110 mfp
sir,
clean the LSU(Laser Sensing Unit) with a dry cloth.
Sep 25, 2008 | Xerox Phaser 6110MFP All-In-One Laser...
74 people viewed this question
jasbo
jasbo
