Question about Honda 25cc 4-cycle Mini Tiller
Honda 4 cycle cult wont start. New gas primer primes new spark plug. Won't fire.
    Problem Solver:
  • 5 Answers
Check the start switch and the start switch line. If not broken, check the choke switch and try different settings to start it. Last check the gas line for any cracks. This tiller can be easily be flooded when pushing the prime button..
Posted on Sep 06, 2010
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
Honda gx670 has fire and gas to the carb Carb has been cleaned, fluid goes through all jets and ports.when reinstalled still won't start
remove spark plug an see that its actually firing
spray some gas 1/4 oz in the hole an reattach plug
or
prime the carb does it fire
its either
gas , oil, spark , compression
May 03, 2015 | Honda Motorcycles
Not getting gas - wont start
carburettor dirty ,primer bulb has hole in it, or at worse the inlet from the carb.to the cylinder head cracked. hope this helps
Feb 12, 2014 | Garden
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
IT JUST WON'T START
Start with fresh gas and a new spark plug.
Then follow theses steps.
1 Turn ignition on
2 If equiped with a primer, prime it a couple of times
3 Turn to full choke
4 Set the throttle lock to full throttle
5 With short quick pulls try to start
6 when you hear the engine fire shut the choke off
7 A couple of more pulls it should fire
8 If it stalls start over from step 3
Good Luck
May 02, 2011 | Garden
I have a honda FG-100 It has a new carb on it but the primer bulb will not prime. blows bubbles back in the take but wont **** gas.
This happens all the time. The hoses leading to the primer bulb are on backwards.
Switch them and you'll be fine
Mike
May 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Wont start
Start with emptying the gas tank totally. Refill with fresh gas/oil mix. Todays gasoline ain't that great.
Also after putting in fresh gas and priming if it doesn't fire at all pull the spark plug and if it is dry, pour a about a tbsp. of mix gas in the plug hole. put the spark plug back in and see if it will fire.
Phil
Dec 07, 2008 | Garden
Crafsman gas blower: fuel lines to primer bulb had to be reconnected; now blower won't fire at all. Replaced plug and made sure it sparked; still nothing when I try to start.
Hi
Priming the engine(put some gas in the sparkplug hole ,after you have checked the sparkplug,the colour of the spark has to be violet).Start the engine.If it starts there is a carburation problem,change the fuel lines to primer bulb.
wish you good luck savumihai71
Dec 04, 2008 | Craftsman 4 Cycle Blower/Vac
Honda 25cc 4-cycle Mini Tiller Logo
477 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
