Question about Musso Lussino Dessert Maker 4080 1.5 Quart Ice Cream Maker
Just receive this machine and am not sure which switch is the chill land which switch is the churn!
    Problem Solver:
  • 5 Answers
Simple. The churn button is the one with the swirl on it (i.e. indicating churn). The chill button just looks like a snowflake.
Posted on Aug 13, 2010
How long do I churn mixture?
Probably 15-20 minutes depends on machine and mixture. Some machines stop churning when the ice cream gets so thick that it stops the beater from turning. If you have this type of machine, when you hear clicks turn it off. If you start with a frozen container vessel, your ice cream will freeze faster. Remember that longer is not necessarily better. The longer it is out, the warmer it gets, and will turn back into slush.
Aug 28, 2016 | Ice Cream Makers
Why my Taylor yogurt machine not freezing the yogurt. Model number 339 -58
if cooling light is coming on ck to see if chill plate is getting cold after a few minutes , also visually verify that agitator blades are moving mix around and over chill plate
(chill plate is inside round tunnel that mix bars go thru )
Jan 21, 2016 | Taylor Ice Cream Makers
Problem with my chocolate side. Will not remain as firm ice cream. Becomes liquid ice milk. I turn chocolate side off. After I turn back on it may still be liquid but not firm ice cream.what can I do?
Homemade Ice Cream Mistakes-and How to Avoid Them ...
www.bonappetit.com/test.../common-ice-cream-mistakes
Bon App?titJul 30, 2014 - Ice cream machines are easily found and affordable, so procuring the ...Once ice cream is properly chilled, it should be firm but not a solid, ...
5 Mistakes to Avoid When Making Ice Cream - Cooking ...
www.thekitchn.com/5-mistakes-to-avoi...
Apartment Therapy's The KitchnJul 20, 2015 - Not letting the ice cream maker bowl get cold enough. ... churning away in the machine, this process doesn't end with the firm, super scoopable ...
Will a new ice cream maker make my ice cream set firmer ...
www.chowhound.com/.../ice-cream-maker-ice-cream-set-firmer-964328
Feb 12, 2014 - I've been making ice cream at home for a few years now and tend to have pretty mixed results with how firm my ice cream gets. Even with all ...
Jan 10, 2016 | Ice Cream Makers
Discovery kids ice cream maker instructions
Usually with these cheaper ice cream makers you put the bowl in the freezer for 12 hours and then put it on the machine and turn it on . Very important point turn it on so it is churning. Why so that what ever you pour in doesn't freeze solid and stop the agitator from churning. Most ice cream is Cream and sweeten condensed milk and flavouring. I do not have this exact ice cream maker but the one I do have has made three different ice creams in it so far. Add 1000 mL of cream to 250 mL sweeten condensed cream. Watch it for about 20 minutes till ice cream is solidifying then transfer to an plastic icecream container and put in freezer for at least 4 hours.
Aug 19, 2015 | Ice Cream Makers
I have lost my manual for the big chill
The K-tel Qick Chill Ice Cream Maker manual/recipes can be obtained directly from K-Tel by emailing info@k-tel.com or phoning (204) 832-7782 or 1-800-665-5021. I spoke to the operator and received my manual by email in .pdf format within minutes!
May 22, 2014 | Salton ICM-21 1.5 Quart Ice Cream Maker
Gaggia ice cream machine
Ice cream won't churn but the freezer it's on
Nov 24, 2013 | Gaggia Ri9101/08 Gelatiera Ice Cream Maker
Not churning corectly
This sounds like a low on charge condition which you probably won't be able to repair yourself unless you are a refrigeration technician. There is a possibility that the cooling fan is not operational or the condenser is dirty. Two things that are very easy to check. First check the temperature of the tubing going to and from the compressor. Both will be hot if this is your problem. Blow out the condenser with compressed air. If it is greasy, use a cleaner. If the fan motor is not running, check for voltage at the motor. If there is no voltage check the switch and wiring. If there is replace the motor. If everything is clean and running the tubing from the compressor to the condenser should be hot to warm and the outlet around room temp. Run your fingers down the side of the condenser from the inlet. If it is cool after the first tubing bend, it is low on charge most likely and is probably not worth repairing.
Nov 12, 2009 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
Ice cream maker doesn't chill
The machine must be upright for 24 hours before using it.
If it was stored on its side or upside down you MUST wait 24 hours with the machine in the correct upright position. The 'person' who delivered mine made sure he tumbled it over and over again scanning shipping labels even though it said everywhere fragile and this side up.
If the machine does not work at cooling after 24 hours there is a problem and it should be returned.
Do not expect rock hard ice cream, but thick scoop-able medium firm soft-serve is easy to get as a result. A few hours in the freezer will harden it more.
Nov 08, 2009 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
CAN ANYONE PLEASE HELP ME OR EXPLAIN WHY MY MUSSO ICE CREAM MACHINE TAKES HOURS TO CHURN 1.5L OF CHILLED MIX. DAVE 07 5448 2937
Do you use enough salt to assist in the freezing period? What kind of salt do you use? Use rock salt since it works better than table salt. This wills speed up the freezng time.
Nov 06, 2009 | Musso Stainless Steel Pola Ice Cream Maker
Musso Lussino Dessert Maker 4080 1.5 Quart Ice Cream Maker Logo
132 people viewed this question
Top Musso Ice Cream Makers Experts
Andrew Taylor
Andrew Taylor
Are you a Musso Ice Cream Maker Expert? Answer questions, earn points and help others
