Question about Samsung FPT5084 50 in. Plasma HDTV
Samsung FPT5084x/xxa will not turn on after being unplugged
I just got back from a trip, where prior to going, I unplugged all of my electronics. I got back last night and plugged everything back in and alll I get from this TV is a blinking red light and a faint churp. I have tried to turn it on with both the tv remote and the cable supplied remote. Neither will turn it on. It was unplugged for 6 days.
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Samsung FPT 5084X won't turn on
Sorry, but welcome to the world of highly efficient, component-critical switching power supplies.
These are all of those things and the failure often is related to a specific type of component, an electrolytic capacitor. These are chemical devices and cheap ones fail easily, the most expensive take little longer but the primary value shrinks while the losses climb until the part cannot do what it should any more.
The main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself but it will likely have the same problem eventually unless they have altered the design.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Aug 27, 2009
  • 3 Answers
SOURCE: I have a 50 inch Samsung, Model FPT5084X/XAA that won't turn on.
Seems to be a chronic problem for this model. My list of service calls with Samsung is quite lengthy.
Posted on Apr 12, 2010
Samsung gas dryer dv350agp/xxa have lights come on but is not working
It could be that you have a broken belt. Can you heat a motor running? Try placing your ear to it when you turn it on, if you can hear the motor running then remove the back panel and see if the belt is in tacit.
Best of Luck
'RR
May 15, 2014 | Samsung DV350AGP Gas Dryers
Samsung LCD 1080 flat screen tv model LNT4661FX/XXA clicks before taking 30 seconds to turn on.
Delay in turning on in flat panel TVs is mostly caused by weak and defective electrolytic capacitors in the power supply board. Most of the times they are easily recognized by their bulged top. Some times one has to hunt for them. If one can do it, it is a simple job. Good luck to you.
Dec 29, 2013 | Samsung LN-S4041D 40 in. LCD HDTV
How can you get the "paper out" indication fixed when there is paper in the printer?
Unplug from the wall for a few minutes then turn it back on, should reset everything.
Also
Ensure that the paper is pushed in far enough to trip the measurement device in the printer, if you have a reset button on the top or back of the printer try that prior to unplugging.
Feb 03, 2012 | Brother HL-5240 Laser Printer
My Samsung model HLR4667WX/XXA is making the same buzzing noise I've read about by googling the model + buzzing noise. I need someone in Phoenix that can replace the color wheel or so it seems. Please...
It is easy; just look for a video on you tube and with a screwdriver and some care you can fix replace the color wheel yourself.
I replaced mine in fifteen minutes. Note, I had to replace my ballast prior to this so I had a little experience.
Good luck.
Feb 23, 2011 | Samsung DLP HL-P5663W 56" TV
The TV will not power on. I already replaced the power cord and after the TV is unplugged for a little while and I turn it back on it has rainbow lines across it, whether I have the cable boxed connected...
You may have mutiple problems that may be caused by unstable power suppy, that is the first place to look and find out if all the voltages are correct.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 23, 2010 | Samsung LNT4066F 40 in. LCD Television
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung ltn1565x/xxa power light blinks green as soon a power is plugged in, but tv will not turn on
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 25, 2009 | Samsung LTN1565X/XAA 15 in. LCD Television
Tv shuts off wont come backon samsung fpt5084x
I had the same problem twice with my Samsung FPT 5084 and it was the 12 AMP fuse on the power board both times. The bad part is you have to remove the whole back plate to get to it but once off it sits on the power board (dead center) towards the lower left hand side of it. Replace the top fuse or you can replace both. They're just regular ceramic sealed 12 AMP fuses that cost about 50 cents each.
Mar 06, 2009 | Samsung FPT5084 50 in. Plasma HDTV
50 Inch Samsung tv
the tv is having a high voltage problem.what happen it was a short that cause you tv to stop working contact a tech to look at it.good luck.
Apr 03, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung FPT5084 50 in. Plasma HDTV Logo
185 people viewed this question
Henry  Thomas
Henry Thomas
