Question about Brother CS-8072 Computerized Sewing Machine
Singer CG-590 I just recieved my singer CG-590. My father-in-law gave it to me but I have no manual and silly me didn't ask how to work this machine. I don't know how to thread the bobbin, thread the machine itself or anything else. I tried to thread it and tried to sew a little with what was on the bobbin that he gave me, but it seems like there is a lot of tension on the top thread and maybe not enough on the bobbin thread???? When it sews, the bobbin thread shows in a loop on the top of the fabric, with the top thread straight. If I pull on the top thread, I can pull it completely out and then I can pull the bobbin thread out as well. Please help me!!! Is there somewhere that I may be able to download an instruction manual or something so that I may be able to learn a little about this machine.
  • cycurt Dec 20, 2008
    I have the same problem, but I still can not figure out what is wrong with it, even though I have the manual. We have been trying to fix it for hours, but to no avail. HELP! Why does it keep doing this?
You can find a Users Manual plus a workbook that you can get in PDF and print. Users Manual is 44 pages and workbook is 58 pages. Go to www.mannualowl.com and search for Singer CG 590n manual. It's all free.
Posted on Jul 11, 2014
  • 9 Answers
SOURCE: Singer cg-590 floating bobbin keeps jumping out of it's holder.
I'm not completely familiar with the model, but even a floating bobbin holder as you described should have some sort of a hold down. There may see a small swinging arm on the bottom right side of the bobbin area that needs to be located over the bobbin case to hold it in place. Let me know if this doesn't work.
Posted on Feb 21, 2009
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
  • 980 Answers
SOURCE: Threading bobbin on singer stylist 522
To wind a bobbin put the cotton reel on the top pin, take the thread to the left and round the little wheel and back to the bobbin that should be on the winder, wind the thread round a few times to take a grip, release the stop motion in the balance wheel, turn the winder button so the winder moves to the balance wheel and press on the foot control slowly.
When you put the bobbin in the bobbin case make sure it turns anti clockwise.
Posted on Jun 27, 2009
bargainbox
  • 1388 Answers
SOURCE: Huge loops on back of fabric!
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
bargainbox.com.au
Posted on Aug 02, 2009
SOURCE: Threading CG-590
I have a CG590 SEWING MACHINE AND CAN NOT THREAD IT WITH THE DIRECTIONS THAT CAME WITH IT. CAN YOU HELP THANK YOU, SANDY
Posted on Nov 27, 2009
I have a singer CG 590C. It didn't come with manual. I'm just learning to sew. My bobbin was hung up with thread when I pulled on it I pull the whole bobbin casing out. How do I get it back in? Help
First thing, you should probably get a manual for your machine.
Singer CG 590 Commercial Grade Manual
How to thread Singer CG 590
This machine is listed as a commercial grade professional sewing machine, so you are going to have some additional learning curve if you are just beginning to sew.
Nov 23, 2015 | Singer Sewing Machines
How do I adjust needle depth on my Singer 590 c?
There is an Allen screw on the shaft of the needle bar that you can loosen to be able to adjust the height of the needle. Some machines also have markings as to where the needle height needs to be. If you still have trouble talk to the people at the link below. They may be able to help. good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Nov 23, 2014 | Singer CG-590 Commercial Grade Sewing...
How to fix timing on CG 590 singer sewing machine?
It would be best to have a sewing machine technician do that; depending on your machine, it can be complicated to even to GET to the area to retime the machine.
Jul 22, 2014 | Singer Sewing Machines
I just received a new Singer CG-590. Have threaded the machine and bobbin. Each time I try to pick up the bobbin thread, the top thread wraps around the bobbin case. It will not pick up the bobbin...
try turning the bobbin the opposite way, and if that doesn't help then take the machine back and get another one, maybe even a different model
Dec 26, 2013 | Singer Sewing Machines
Cam replacement for Singer CG 590 C
Question looks old but i'll answer for other people.
try this
parts DOT singerco DOT com SLASH CPpartCharts SLASH alpha SLASH CG590.pdf
Get your part number and call Singer 1-800-4-SINGER (1-800-474-6437)
Then see if they can get you the parts.
Nov 27, 2011 | Singer CG590 Mechanical Sewing Machine
I have a CG 590 C singer sewing machine. How do I attach the zipper foot?
From what I can tell looking at your manual, you have a snap on zipper foot that came with your machine. If, you do not have your manual and workbook, go to www.singerco.com and you can download them for free, if you click on support. All you have to enter is 590 and voila. It is nice to do it anyway because you can print it out and save a copy on your computer plus make the diagrams larger. Good luck and happy sewing
Oct 10, 2010 | Singer Sewing Machines
Threading CG-590
Sep 21, 2007 | Sewing Machines
Brother CS-8072 Computerized Sewing Machine Logo
826 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
