Question about Mitsubishi WS-55859 55" Rear Projection Television
Mitsu WS55859 same flashing green light. Service expects DM board needs replacing - quoted over $1,000. Please send me details of fix. thanks, R. Hendriks I have the same model and same problem. The green led flashes constantly and tv will not come on. I have unpluged the tv and tried the reset button all to no avail. I have called the customer service line and was told to do exactly what I had already done. Nothing helped. Also, where can a person get a set of schematics for this tv model? Help! dmurg99@yahoo.com
  • 3,037 Answers
The regular manual can be found at the following link for free
http://fileshare.eshop.bg/downloadsm/31774/Mitsubishi_WS-55859.html
The schematic can be found at the following link, to access it you must register for 6 Euros for one day which you can then download and print as much off the website as you want.
http://www.nodevice.com/manual/newmans/V19_Service_Manualpdf/get15993.html
By registering you can also get the service manual found at the link below
Please let me know if you need any further help and I would be glad to assist.
Thank you for using Fixya and Good Luck to you
Posted on Apr 19, 2008
  • Benjamin Patri
    Benjamin Patri Apr 19, 2008
    If you let me know how many times the green light flashes, I may be able to narrow down the problem for you
    Genius:
  • 1,142 Answers
It needs the contacts cleaned take off the the back blow it out with can air or air compressor(be careful with a air comp. though)
make sure there is no dust on the contacts of the buttons on the front panel
  • 3 more comments
  • Maanita Chadha
    Maanita Chadha Apr 19, 2008
    ok is in shut down mode kine of proteccion some of the fuses are pico
    fuses but you may have problem with convergence IC's that what I' check
    first if that is ok go to HVT
  • Maanita Chadha
    work around convergence check voltage to convergence IC's if is ok,
  • Maanita Chadha
    try unloading convergence yokes and and turn tv on if it turns on then its the problem with convergence IC's.
  • Maanita Chadha
    1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY
    C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER
    PCB (NOT SHOWN IN THE SCHEMATIC). 2. SHUTDOWN AT POWER WITH SELF
    DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART #
    283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE
    CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS
    INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020
    (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB
  • Maanita Chadha
    Download the service manual from the following link this might help you too.
    http://www.chrisandnat.com/Projects/Blin...
Green light flashing in the front ?
SLinteriors posted this on another page and saved me big bucks.
Here's a bit more detail:
The flashing green timer light after a lightning storm seems to be a very common problem with old Mistubishi rear projection TV's. A friend and I had the exact same problem.
Using this and other sites, I spent $36 bucks and a little time with a soldering iron to replace the capacitors on the DM board and got mine up and running (WS55859). I've never really worked on electronic circuit boards before, but the helpful advice at these sites got me up and running. Definitely check it out before you hire someone or replace your TV:
Repair Kit with instructional CD available at:
http://www.tvrepairworld.com/mitsubishi_repair_kits
for under $40 plus shipping.
Discussion of process in detail at:
http://www.hometheaterspot.com/showtopic.php?tid/137881/
for the WS55859 model, which may be a little different.
Jul 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green light flashing what does that mean?
The steady blinking green timer led is usually caused by failed capacitors on the DM and Power board which prevent the set from completeing the Boot sequence
Jul 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green timer light flashing tv wont come on result of power surge
Your power source seems to be the problem, replace the part (located inside the television) and the problem will be solved.
Jul 18, 2010 | Mitsubishi WS-55859 55" Rear Projection...
I have a WS 55859 and after power outage i got the green POWER light blinking. I replaced all seven capacitors 1000uf but i still can't switch it in? Any other advice? Rgds FM
If replacing the 7 caps doesn't work I then try to re-solder the small 8 pin ICs. Be very careful and try to avoid cooking it or leaving a solder bridge. If that doesn't work either you'll have to replace the DM-POWER board. You'll beed a Mits authorized service center to order the part. Goodluck.
Jul 05, 2010 | Mitsubishi WS-55859 55" Rear Projection...
MITSUBISHI DIGITAL TV WS-55859 GREEN LIGHT FLASHING WON'T SHUT OFF EVEN AFTER RESET. IT HAPPENED AFTER POWER OUTAGE.
This could mean the DM (HD tuner) failed. In the future connect your TV to a good surge protector. The manufacturer's solution is to replace the module and swap the memory from the failed part to the new one. (Except for the memory it is just an unplug one and plug in the new one.)
If you are handy with a soldering iron, you may be able to fix this by opening the DM module and removing 8 capacitors (as I understand the board) and replacing them. All 8 are 1000uf 16v 105C Capacitors
This URL has an good explanation of the process: http://www.hometheaterspot.com/fusionbb/showtopic.php?tid/137881/
I hope this helps.
Jun 19, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Apr 03, 2009 | Mitsubishi WS-55513 55" Rear Projection...
MITSUBISHI 65 INCH HDTV, GREEN LIGHT BLINKING, WILL NOT POWER UP
There are four (4) caps on the 'DM' board that need to replaced. Parts: 680ufd 16 volts, orig are rated at 1,000 ufd.
Nov 01, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65513 Flashing green light
Good Day, charliek1;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Tv wont turn on
This problem very well could be a DM board problem. I have a how to fix file if this is indeed your sets problem. Leave your email and I will send it to you. Good Luck
Jun 15, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
