Question about RCA P52926 52" Rear Projection Television
D52w26 thanks alot.i payed alot for this tv and it needs to get fixed.what is crt?i think the part #is 264102 but not exactly sure.its the board that the power cord plugs into and had the 2 windings and the only one in the bottom tray with the fuse link.ill get a pic asap if you need to see it.thanks again for the help
  • jetsfan5 Apr 21, 2008
    Here is the board i need.Thank you for the help.Im so pissed my tv went down.
  • RCA Master
  • 8,617 Answers
The board with the power cord attached is the power supply/ filter board. please send a pic if possible so I can be sure
Posted on Apr 21, 2008
  • Sonny Berry
    Sonny Berry Apr 21, 2008
    Yes that board is the power/filter board. That is no longer available. Their are very few parts on that board. What makes you think its bad? Because that board powers the Power scan board and in that Chassis it is much more common for a dead set to be a problem in the power scan board with the Flyback on it.
Is My LCD tv fixeable
Don't waste your time, the cost to repair is most likely more than a new set.
Sep 27, 2016 | Insignia Televison & Video
The Cable connection is broken, how do I replace it? the model is D52W26
Thats called the f-fitting or rf fitting. Its attached to the tuner on your set. You can either replace the whole tuner circuit or in most cases, replace the rf fitting with a new one as long as the tuner board was not damaged. We stock the fitting which are like 2 dollars a piece so I would think alot of tv shops would stock them. You could expect to pay around 125.00 or so depending on your location to have it done in your home. To do it yourself you will need to be handy with a soldering iron and be extremely careful in the tuner area not to damage surround coils..
A cheap or maybe free alternative is if your using a cable box, to just hook it up using video and audio patch cables which will bypass the TV tuner altogether. If you still have a vcr you could use it for tuning or buy a cheap converter box (as long as it has video and audio outputs) at most any local dept store.
Just run patch cable one yellow for video and the other 2 are red and white from the box to the tv. I think the boxes are around 25.00 or so
Oct 19, 2010 | RCA P52926 52" Rear Projection Television
My RCA D52W26 projection Tv is blurry. Digital board replacement
You cannot replace it yourself sir because there are a lot of adjustments(electronically not mechanical) and you need an equipment to transfer the data from the old EEPROM to the new one. If the convergence is fine then the fuse should be ok..Picture is blurry??? 1. could be a dusty CRT lens, you can clean those 3 lenses by taking off the front speaker grill then there's a small hole that you can see the lenses... or the mirror needs to be cleaned also. 2. maybe it needs a convergence alignment, pls check your owner's manual if available. thanks:)
Dec 28, 2009 | RCA Televison & Video
Screen went red now its tring to turn on and off
could be alot of things, without a model # my best guess is either the CRT is shorting out, or a problem with the color driver circuits.
check for a bad connection on the CRT board (tap it gently and tap the neck to see it you can clear the short if there is one) .
If neither test helps, you need a repairman. if this TV is less than 32" its probably not worth paying for service
Thanks
Eric
Aug 23, 2009 | RCA Televison & Video
RCA D52W26. Yesterday the TV all of a sudden started to give Color shadows and then it curve the image.
Easy, repalceing two covergance chips
fixes the problem . the chip cost 10.00-20.00
etch , dont pay more than 175.00 to
have a shop fix it
Jun 28, 2009 | RCA D52W23 52" HDTV CRT TV
D52W26 Convergence board
Yes the D52W20 and the D52w26 are both ITC222 chassis they are exactly the same
Jul 17, 2008 | RCA P52926 52" Rear Projection Television
POWER DEFLECTION BOARD
your part# is 264102 and is no longer available
ship your board to p.t.s for rebuild
Jun 18, 2008 | RCA HD52W59 HDTV Projection Television
What is crt i thought somthing was sprayed in my set.i cant upload pics but its the board with the 2 windings and the power cord plugs on it.its the only one with the fuse in the bottom tray ill try and...
CRT stands for cathode Ray Tube (picture tube) which just needs a new seal which is minor. You will need to replace your board the other site I work for has new RCa circuit boards. I am including a pic of part 264102 thats not the board where the power cord enters.But let me know if this is the board or not and I will post pics of the other boards in that chassis.492f279.jpg
Apr 15, 2008 | RCA P52926 52" Rear Projection Television
HD52W59 CRT Arcing
Blue Crt arching... on the board or on crt? most likely if it is arching you are right in suspecting the tube. These tube are around 240 dollars per tube and then i would sugest replaceing crt board. I work on alot of these at the shop. bottom line if there not under warenty then really not worth fixing. these set cost about 800 new it would cost around 500 to fix. crt replacement of these set is a very involved process. I think almost ever screw in the set has to come out and then after you get it all back together. theres the alignement issues.. im not saying dont do it just if you like a challenge go for it.
Feb 18, 2008 | RCA HD52W59 HDTV Projection Television
No picture
Something in the power supply sounds like it popped. Like a capacitor? These sets the whole board is made to replace. But theres alot of techs who fix these boards and charge alot of money, but in the long run unless its a common problem it dosent pay for the board to be fixed. An example is a tech will charge 65 an hour for labor. It take almost two hours to fix board and 2 weeks to get parts. Pickup and delivery is 75 bucks. service call is 50 bucks. The whole rebuilt board is 140 bucks. + inhome labor at 50 bucks and no long wait to get set back. And the entire board has a 90 day warrantte not just what the tech fixed. Good Luck
Jul 02, 2006 | Zenith H25F36DT 25" TV
RCA P52926 52" Rear Projection Television Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
