Question about Dell UltraSharp 2007WFP Monitor
Dell 2007WFP suddenly stop working. When I reboot pc for a few seconds the windows xp logo show up right after this disappear.
Joed911
  • 4338 Answers
SOURCE: need graphic driver for dell model 02x378 pc
Download the Video driver from Dell's website, Enter your service tag number (which it on a label located on the back of the unit) in the second line on this page. It will bring up the correct driver for your unit.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=PLX_PNT_P4_GX260&os=WW1&osl=en&catid=&impid=
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 07, 2008
jeltey
  • 44 Answers
SOURCE: picture is sideways
The problem is most likely not with the monitor it is the computer. Some graphics cards have shortcuts to turn the display. Most likely you accidentally hit this shortcut. Most are done with Cntrl/ALT/Delete. Regardless lets get it back to normal. If you right click on the desktop somewhere and select Properties from the box pops up you should get to the display properties. From here select the Advanced button from the settings tab. You should get the Plug and Play display box. Selet the Display adapter tab. Mine happens to be Intel it is usually the tab on the top and takes up the whole length of the box. From this box there should be button for display properties ot something similar. If you check the different tabs in display props there should be a setting for rotation. Set it back to zero. I would deselect the Enable rotation so it does not happen again by accident. I hope this helps. You may find things a different on your PC but this should get you to the right place to fix it. I see this happen a lot. I always disable this on people PC's that I repair for them to avoid calls like this. It is easy to mess up.
Posted on Dec 01, 2008
mudasser
  • 50 Answers
SOURCE: Dell M70 laptop mouse cursor disappears off screen
please clean the componet of mose curser
Posted on Jun 06, 2009
  • 26 Answers
SOURCE: my dell dimension 3000 goes to blank screen after
Have you tried starting in safe mood and then ran a scan of the hard drive, it could possably correct any file errors that the start up files may have Hope this Works Steve
Posted on Oct 01, 2009
  • 12173 Answers
SOURCE: Lap boots up, shows dell logo then screen goes black but runs.
ur unit is overheating turn off and unplug and let cool down,clean vents around fan intake (under unit) and around top each side of keyboard when cool enough plug back in and listen for fan operation while booting up if no fan it may be stuck or burnt up and may need replacement but ur biggest problem will be the hard drive if it was overheated for to long could or is damaged good luck hope ur lucky and that it just got hot
Posted on Dec 05, 2009
Why does it keep rebooting?
OS is corrupt and needs to either be repaired or reinstalled.
Oct 20, 2015 | Dell OPTIPLEX 960 MT Desktop Computer...
The sound on my computer has suddenly stopped working, and I have no idea why. When I click on ''Sound and Audio Devices'' on the Control Panel, it says ''No Audio Device''. The volume icon has also...
That happened to my Laptop as well and all I did is reinstalled the audio driver that is included in the package and it actually worked with no problem. If in that case is still happening, try to update the driver after reinstalling it.
Jan 07, 2010 | Dell OptiPlex GX110 PC Desktop
It starts with Dell Scrn followed by Windows Logo, then it stops
Should not be with the hardware This seems to be a problem with windows.Try starting on safemode. Otherwise you may have to reinstall Windows.
Regards
Aug 11, 2009 | Computers & Internet
Pc is restarting but doesn't show the log on screen
It sounds like your Windows Installation is corrupt. If there isn't anything you need on the drive, I would get a Windows XP CD (Look on the side of your case for a Windows Key, Get that version of the CD) Then I'd use that windows XP CD to wipe the drive and Re-install windows. If there is Data on the drive you need, You will need to invest in either a second HD, or You need to Install Windows on a Second HD and boot from that if you already have a second HD.
Jun 21, 2009 | Dell 2.8 GHz Second Processor for...
Dell logo then blank screen
you to first put everthing back into your computer then make sure the hard drive is still working by checking your hard drive light see if it is light up or not go into the bios and make sure the computer is set to boot up for your cd rom first and second the hard drive now if you have windows xp home full you will be able to put windows xp full back on the computer if you have upgrade you will need windows 98 se to use for some of the files that the upgrade doesn't have once you do this it should be able to reinstall windows xp and if that doesn't work put windows 98se in the computer and then use the windows xp upgarde to put windows xp back on the computer if none if this work get back to me with more info and I will try to help you get back on track
thank you and good luck
Mar 23, 2009 | Dell Computers & Internet
Loggin problem Windows XP on Dell 4400
Hi there if you hit the del key when booting up the computer this will bring you to the bios screen now just go to the boot section and make the first boot device the cd rom and the second device your hard drive save and exit and reboot with the xp disk in the cd rom . best regards mike
Feb 15, 2009 | Dell Dimension 4600 PC Desktop
System Restore Not working
for enabling system restore do this
Start the Group Policy Editor (gpedit.msc)
Navigate to Computer Configuration/Administrative Templates/System/System Restore
Set Turn off System Restore and Turn off Configuration to Disable
Right click on My Computer and Select Manage
Navigate to Services and Applications/Services
Navigate to System Restore Service and double click
On the General tab set [Startup Type] to Automatic using the drop down list
Click the Start button to start the service
Close the Computer Management console
Return to System Restore in Group Policy Editor and configure both to Not Configured
Close Group Policy Editor and reboot the system.
Nov 26, 2008 | Dell Dimension B110 PC Desktop
DNS error
to fix to the "DNS error" in windows
XP. go to>Control Panel -> Admin Tools -> Services
Find DNS Client and Stop it, wait a few seconds. Then start DNS CLient
again. Can continue without rebooting or reconnecting.
.hope this helps pls appreciate by rating it
Oct 23, 2008 | Dell Dimension 2400 PC Desktop
Dell E510 desktop
Hi Asif,
Did you install there something new on it? Maybe could help to push the F8 key after POST (just after the DELL logo disappeared and before Windows logo would appear) and choose to start with last configuration which worked. If this doesn't help then after F8 choose to start in Safe Mode and uninstall the failing application after you log into Windows.
May 30, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell UltraSharp 2007WFP Monitor Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
