Question about Microsoft Xbox 360 Console
MTU settings not high enough for XBL ??????
My MTU settings are not high enough for Xbox Live, and i need to change them so 1364 or higher. How do i do this for Thomson TG782T Modem? I've tried all sorts of things, like editing the registry to allow more Transmission, i've tried going to my router config page, butto no avail. Can anyone help me with this? btw i'm sharing an internet connection from my laptop to my xbox as it is too far from my modem to connect it directly. Im running XP SP2. any help would be appreciated !!
    Scholar:
  • 106 Answers
The MTU or maximum transfer unit is configurable at the
modem that is bringing the internet service, in your case the Thomson tg782t modem, do not attempt to change the registry
Posted on Aug 31, 2010
  • Nathan Locke
    Nathan Locke Oct 09, 2010
    nah, i wasnt going to change the registry, more go to the router config. page and see if there's something i could tweak there. i couldnt find anything there so i was stuck. Than i found that the MTU setting was being limited because i was bridging a wireless connection from my laptop which had ZoneAlarm IE antivirus. This program doesnt allow network sharing over unsecure ethernet connections so i uninstalled it, got a new antivirus and it works fine now :P cheers for the help anyway. BTW ive got ethernet now so dont bother with bridging a wireless connection because its slow, unreliable, an open source-way for anyone to get to my ISP and is very patchy cutting in and out.
We need to change our MTU setting to 1364 or higher. We have a XBOX live which requires this setting. How do we do this?
Go to the following link I will provide and your problems will be solved.
http://support.microsoft.com/kb/826159
Jun 04, 2011 | D-Link Wireless N 150 Home Router 4Port...
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
Connection interruption while playing xbox live
Xbox LIVE recommends using an MTU value of 1364(defaults are 1492 and 1500) on your router.
You will need to log onto your Router, go to the setup section, locate the MTU, set it to Manual, and change the Size to 1364.
If that doesn't work, you will need to clarify the following:
  1. How many machines(do you have other computers?)
  2. What router are you using
  3. Ethernet or Wireless?
Sep 28, 2009 | NetGear WGR614 Wireless Router
How to change mtu settings to get x box live?
heres a good site that discusses adjusting the MTU(maximum transmission unit)
Usually in most cases MTU of 1500will work just fine, I suggest using DrTCP a free program available online to help you tweak your settings
http://help.expedient.com/broadband/mtu.shtml
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Bestdata cmx300v2 mtu setting is too low
My MTU is at 1500 and I get the same message. I don't think XBL is up yet. It is under repair.
Jun 16, 2009 | Computers & Internet
How do I change my MTU settings?
Today would be a bad time to test for a connection issue with XBox Live. It is down today for maintenance, if it worked before today, I would just wait until tomorrow and try again.
http://www.product-reviews.net/2009/06/16/xbox-live-down-on-june-16-maintenance-also-for-zune/
Jun 16, 2009 | Belkin (F5D5231-4) Router
Have the n+ wireless router/modem trying to connect via a cable to xbox live but keep gettin insufficient MTU even though the actual MTU of the router is higher than required
You may have to use trial and error to find the best MTU fit:
MTU Default of 1500 to 1492
Tart the setting the MTU @ 1400
MTU setting. Xbox LIVE requires a minimum MTU setting of 1364.
The information your console sends and receives is broken up into "packets" for transmission over your network. MTU is a setting that controls the size of these packets. If it's too small, you won't be able to connect to Xbox LIVE.
Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
Solution 1: Check your router MTU settings Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Solution 2: Connect directly to the modem If your router's MTU is set correctly, try bypassing it by connecting your console directly to the modem. This will help determine whether there's a problem with your router or something else on your network.
Note
This may require you to move your console to a location close to your modem. This is a temporary arrangement, meant only to troubleshoot your connection. If your console is connected wirelessly, you'll need an Ethernet cable for this step.
To connect your console directly to your modem (wired connection):
  1. Find the Ethernet cable that runs between your console and the router.
  2. Unplug the cable from the router, leaving it connected to the console.
  3. Find the Ethernet cable that runs between the router and the modem.
  4. Unplug the cable from the modem, and plug the cable from your console in its place.
To connect your console directly to your modem (wireless connection):
  1. Unplug the USB connector for your adapter from the console. The adapter can remain attached to the console.
  2. Plug an Ethernet cable into the Ethernet port on the back of the console.
  3. Find the Ethernet cable that runs between your router and the modem.
Try to connect to Xbox LIVE again. If it works, there may be an issue with your router. Double-check the MTU setting in solution 1 above. Also confirm that you're using a compatible router, and make sure it has the latest updates from the manufacturer. If the problem persists, you may want to try a different router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 06, 2009 | Belkin N1 Vision Router
Changing the MTU setting
Log into modem using 192.168.2.1 in your browser and go to modem utility through browser.
May 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Microsoft Xbox 360 Console Logo
1,968 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
