Question about Polaris 380 In Ground Pool Cleaner
Not all the wheels of my Polaris are turning how can i fix it
  • 640 Answers
Make sure that you don't have an obstruction in the drive shaft of the Polaris. These automatic pool cleaners will stop moving if they have the smallest thing caught in the drive shaft. You will also want to make sure that you are at between 28-32 RPM. You will need to adjust your water flow if the RPMs are too low.
Posted on Feb 02, 2011
Polaris 3900 wheels won't turn
check inside see if belts or hoses came off
Oct 20, 2012 | Polaris 3900 Sport Pool Cleaner ()
The wheels on my polaris 360 don't turn
if pressure ok look inside and check hoses and belts and gears on wheels
Jul 25, 2011 | Polaris 380 Automatic Pool Cleaner with...
My polaris keeps getting tangled up. How dod I fix this?
If the hose on these pool cleaners is becoming tangled, there are a couple things you will want to check. Remeasure the hose to verify that it is adjusted to the proper length for your pool shape. With the cleaner operating, check that the swivels in the hose and the hose connections turn freely. Make sure the feed hose if floating. Then, with the Polaris turned off, spin each of the wheels. Make sure they are all turning together and adjust if they are not.
Aug 11, 2010 | Polaris 280 Black Max Pool Cleaner with...
My polaris 380 wheels won't turn. the belt is
If the wheels don't turn there may be sand in the notches on the wheels, the notches may be worn off, if their is sand or dirt in the paddel wheel jet that will keep the unit from turning and again no wheel movement. All of these problems they can check in your local pool store. Stores will generely check your unit out and fix what is needed for just the price of parts to fix it when you bring it into the store.
If you have no water flow to the unit this will also stop things from working so be sure to check your finger screen before you do anything.
Aug 24, 2009 | Polaris 380 In Ground Pool Cleaner
My wheels are not turning on my Polaris 280, what can I do?
When my polaris wheels stopped spinning it was the water jet which spins the turbine was clogged. The in-line filter had failed and some small debris had passed through to clog the jet. Easy fix to take off the top cover then take off the turbine cover and examine /clear the hose (clamped on by zip ties) and the plastic jet.
Jul 27, 2009 | Polaris 280 In - Ground Pool Cleaner with...
Wheels on polaris don't turn. Is there a way to tighten belts
Replace the belts.($30) Tighten with an 1/8" play. Also check the wheel bearings. If the wheels wobble they also need to be replaced
Jul 23, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 280 - tank track keeps coming off
I battled with the track falling off for over a season. The pool guys said they fixed it. Tried the previous solution to adjust middle wheel but no luck. My solution was to remove the left wheel and the tank (to get to the screws). The wheel mount allows for minor adjustment but it is also reversible. Turn the mount around and this will extend the wheel base much more. Mine ran for several hours after doing this and so far the track stays on.
Dec 28, 2008 | Polaris 280 In - Ground Pool Cleaner with...
MY SON'S 2 YEAR OLD POLARIS WILL NOT RUN IN REVERSE AFTER A NEIGHBOR CHILD RODE IT.
I would check and make sure the wiring on the foot pedal is on.
The Peg perego polaris models will sometimes get corrosion on the red wire.
I called the guys at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html and they said to check the red connection. sure enough the connector was barely hanging on.
Hope this helps
Dec 05, 2008 | Polaris 800 Twin Sportsman Ride on Toy
Polaris 380 In Ground Pool Cleaner Logo
185 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
