Question about Lenovo 3000 N100 CoreDT2080 VB PC Notebook
The screen was broken when i lean on it. Can the screen be changed?
  • Lenovo Master
  • 17,129 Answers
I am so sorry that this accident happened. To be frank I think the repair will be expensive. you can get to buy the screen but you will need to check the price of a new model to the cost of teh screen. I wish to advice you to searrch for a second hand one which you can procure from repair shops where the mother board or body was defective. Attempt to go forward except with the cost of replacement. Hope this advice helps. Good day
Posted on Jul 09, 2010
My 2006 GMC Sierra has a bad lean to the driver's side is there any way to fix it
Do you know if the lean is worse on the front, or on the rear? Sounds like a bad or broken spring or maybe a bent or broken shock.
Apr 22, 2017 | GMC Cars & Trucks
Rebuilt the carburator.Now when you run the starter it fires through the carburator.
Usually means a lean carburator condition. If an adjustment screw is available, turn counter clockwise a 1/4 turn at a time. Check carb to engine gasket-if missing or broken an air leak will cause a lean condition. It could also be a bad intake valve, timing problem, bad spark plug, bad coil, or bent or broken flywheel key.
Jun 15, 2011 | Briggs & Stratton Garden
Getting a too lean on bank one service engine code. We have replaced spark plugs, wires. one of the coils. The car has 109,000 miles and has been using a little oil. I have to put about 1 quart after...
Lean codes are caused by the engine running lean. What this means is that there is too much air and not enough fuel. There are several things that can cause this. The most likely causes would be a clogged-up fuel filter, a weak fuel pump, a broken or leaking vacuum hose, a leaking vacuum brake booster, a torn air intake "snorkel" that is torn between the Mass Airflow Sensor (MAF) and the Throttle Body, or a bad MAF Sensor. An intake manifold leak can also cause this but it is pretty rare on your car.
With the mileage on your vehicle, I would replace the fuel filter just because it probably needs it anyway. (They are supposed to be changed every 30,000 miles) Then, if you don't find anything wrong with the vacuum hoses or the intake snorkel, I would say that the most probable cause would be a defective MAF Sensor.
Jan 30, 2011 | 2002 Saturn S-Series
Starts to miss when it gets up to temp and givs a little puff of light blue smoke but seems like it is running lean to me
Well the car is 12 years old. That is pretty good. The answer isn't one possibility. The two symptoms may or may not be related. The "Miss After Warm Up" could be Fuel, EVAP, or exhaust. And the blue smoke could be an over due oil change, worn rings, valves, or valve guilds. Start with a wet and dry compression test then Find out when the last tune-up and oil change was. You may want to make a list so you don't go in circles. Also right down any other symptoms that come to mind.
Do a good preliminary check, look for broken or pinched vacuum lines, broken or corroded wiring, Look it over good.
If you believe the engine is running lean then you can take steps to proof it out. Test the fuel system, make sure that it isn't leaking and that the pressure is correct. It should be around 35psi. Faulty 02 sensor/s can cause the car to run lean, a problem with the EVAP system or the timing will too. Let me know how it is going.
Apr 28, 2010 | 1998 Dodge Intrepid
My driver seat on my 98 Toyota Camry keeps leaning back. It's not powered, its manual. I guess when I was leaning back to get my wallet out of my pants, I leaned back to hard and now it doesn't go back...
You have a broken seat frame.
You are going to have to have the seat removed form the car, the upholstry removed, and the broken metal frame re-welded. As to the costs, I would expect about $125-150 dollars.
Oct 12, 2009 | 1998 Toyota Camry
I crack the screen
this is because only your screen must be broken, the rest of of the hard ware is properly, so jus need to replace the screen. thank you,, plz rate me..
Jun 29, 2009 | LG Vu CU920 Cellular Phone
The hindge is broken it leans the full way back and my touch
you broke the wiring that goes to the top screen through the hinge...
Jun 05, 2009 | Nintendo DS Console
Older 36 inch rca crt tv broken
Your high Voltage anode button that connects into Picture tube may have came lose Rember Picture Tube if not broken Holds 36,000 volts if not discharged, Have you Look under chassis to see if board it cracked? Sounds like your FBT?
Dec 23, 2008 | RCA D52W23 52" HDTV CRT TV
LCD Sanyo screen looks shattered
The inner glass plate inside the screen is broken. The glass inside of these is very thin. I think it is only a few millimeters thick at the most.
The complete screen must be replaced to fix the fault. It will probably be cheaper for you to buy a new monitor rather than replace the screen!
Jerry G.
Jun 02, 2008 | LG 42LC2D 42 in. LCD HDTV
Lenovo 3000 N100 CoreDT2080 VB PC Notebook Logo
52 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
