Question about Epson Stylus CX5400 All-In-One InkJet Printer
Printer problems im tryin to print, i have claned and preformed nozzle check......still blank pages
  • Epson Master
  • 691 Answers
This sounds the common problem that causes a lack of ink on paper. If you have look HERE you can find a countermeasure that should get you going again. The fix requires some dis-assembly of the printer.
(http://www.tradebit.com/filedetail.php/1594393-Documents-eBooks-Technical)
Posted on Jun 03, 2008
MY printer prints blank pages
probably an ink cartridge problem..Try executing nozzle check on the maintenance tab on printer and faxes then check the results if it prints properly. if there is still a problem deep cleaning is recommended and if it doesn't work then its the time to replace both black and color ink cartridges.
Oct 02, 2014 | Canon Pixma MP500 All-In-One InkJet...
Problem with my PC cant get mky printer to printer more than blank pages. Just bought new ink cartridges
Before fitting new cartridges and before removing them from their packaging give them a good shake.
If you think you have blocked nozzles stand the old cartridge in warm water.
Oct 22, 2012 | HP Officejet 6500 All-in-One Printer
THE PRINTER PRINTS BLANK PAGES
If you haven't used your printer in a while, it's possible the print heads have become totally clogged (assuming you haven't already checked out the obvious things like ink levels etc.)
I found that by removing the printhead (remove the ink carts, flip a lever and lift out) you can try spraying some window cleaner onto the nozzles on the underside, leaving a few minutes, and then get a bowl of hot tap water and touch the nozzles on the surface of the hot water.
This will definitely help some 'soft' blocked nozzles. If you get SOME print action after this, then you know the problem is definitely clogged nozzles. However, if they're severely blocked, then you can find a print head cleaner kit online for about $10. It contains some cleaner fluid, a syringe and some pieces of clear hose that fit on the ink funnels on top. Then you can inject cleaning fluid into the nozzles. Did it for mine - worked a treat!
BTW, the inkjet head is fairly watertight in itself - you can flush the nozzles under a hot tap no problem. DO MAKE SURE THE HEAD IS COMPLETELY DRY BEFORE YOU PUT IT BACK IN YOUR PRINTER!
Jun 28, 2012 | Canon PIXMA iP4600 Color InkJet Photo...
Prints blank page
Blocked print head nozzles
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
May 09, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
Lexmark wireless printer 1400 series prints blank pages
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark Z1400 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Jan 22, 2012 | Lexmark Z1420 Printer
Printer output is a blank page
hi,
* Please check with the ink level in the Catridge.
* Be sure that catridge nozzle is not dry or dirty.
* Check wheather ink nozzle is clogged/ damaged if so use rubbing alcohol to clean them.
* Try printing by replacing new catridge.
Thanks,
Appereciate to rate as "FixYa"
May 23, 2009 | HP PSC 2210 All-In-One InkJet Printer
Deskjet F380 is normaly printing but it will print blank
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the Ink option in the printer driver may be set to Black instead of Color or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Feb 04, 2009 | HP DeskJet F380 All-In-One Printer
Printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Jun 17, 2008 | Epson Stylus C60 InkJet Printer
Not printing even the test page,full ink ??
I have the same problem, I re-loaded the software, checked all the settings, went through set up procedures and nothing??????? I goes through all the motions, spits out the paper..........blank
Apr 10, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
