-   i have a acer laptop and the bios is lock it is asking me for a current password
-   Guest
Apr 04, 2009
-   How to break bios password laptop Thoshiba -   sigmn
Jul 10, 2008
-   me to have same problem.. i can't go BIOS menu also ...wht can i do??
hw to i remov password??-   Guest
May 07, 2008
-   I have a compaq v2000 I had forgotten the bios password and i tried for like three times..and gave me a message that the system has been disbaled what do I do?...I have opened it apart and took out the cmos battery for a few minutes and it doesn´t work....-   Phawnoer
reset the bios by unpluging to battery doesed work
this is the only working solution:
To reset the password of an old Toshiba, you can use KeyDisk. (cf my web page) If this doesn't work, you can try to build the Toshiba Parallell loopback. To make a simple device that you connect to your parallell port, a lot of Toshiba computers remove the password when you boot it up. The device, named "loopback" by some, could be made out of any parallell wire with 25pins connectors (db25). You should connect these pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, 18-25.
A db25 looks like: 1 13 _______ \_____/
I have a Dell Inspiron 6400 with SigmaTel High Definition Audio. The driver is SigmaTel 5.10.0.5515...
(More)
I have a Dell Inspiron 6400 with SigmaTel High Definition Audio. The driver is SigmaTel 5.10.0.5515 dated 5/10/2007. I have skipping and scratchy noise for about a month. New speakers do not make a difference. Is there anything I can do?
