When i go to turn on the tv it takes a little while for the picture to come in clear what do i need to do
  • 17,129 Answers
Assuming your set being older than few years, i would ask you carry out the following test, only if you are familiar with electronics. If this is happening when the set is cold then this could be that some electronic components like capacitors- electrolitics, semiconductors could possiblily be the main culprit.use a hair dryer to warm up the power circuit area, main HT section where the panel voltages are to come. use a soldering iron to warm and check if the set turns on. In this case the culprit will be in this area. Replace and proceed. If there is no change with the warm up, then the component getsa ctive with voltage feed. so make a voltage check from the power and move on, see the +B proceed to the main circuit. solder the drive of the panel, the transformer output. I hope this helps. Good day
Posted on Jul 09, 2010
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
My rear projection tv keeps taking longer and longer to turn on. Sometimes it may not turn on at all or I don't have the patience to wait. But it may take up to 30minutes if I had to make a rough...
Pictures are still clear and tv have no dull or hallow pictures on the tv screen wright?Yes,than the tv CRTS tubes coolant chemicals are still good.100% the tv convergence board components parts are dying and the causes,if causes convergence problems and fixes itself after power on and off.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The Samsung/Akai DLP Tvs models uses the same tv convergence board.Or u fixed it ur self or have ur tv convergence board service.This problems will be solved.
Jul 11, 2011 | Philips 55PW9363 55" Rear Projection...
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
Need to take FPA Bloc off .When menu is pulled up it's in a different language ,unable to look thru menu ,when tv on CH 3 still will not show picture
with the tv off press the vol- in the tv and the clear bottom in the remote control at the same time for 5 second . the tv turn on automatic and clear all password and reset.
Dec 27, 2009 | RCA 32V430T 32" TV
I just hooked up my new Samsung 55" LED LCD TV it has 1920 X 1080 resolution and 240Hz speed. Initially the picture quality was fantastic, sharp clear great colors...almost jumped off the screen at you....
Try the Direct TV connected to the TV via component cables and see if the picture is clear and stable at the same time. If it is normal check the Samsung website for support on your model of TV to see if there are ANY known issues and or software updates. Please take a moment to rate my answer. Thanks..
Nov 26, 2009 | Televison & Video
When I turn on my television, the picture is bright white and it is hard to make out any figures on the screen for a few seconds, then the TV shuts off itself, the little red light will go off and it will...
HI, thank you for visit fixya.
Do you have two possibles solutions:
1.--Vertical IC and capacitors need be replace.
2..-- Convergence IC's is defective, need be replace.
Disconnect convergence plugs ( wires go to yoke) and turn the tv, see if any changes happenings.
Any question, I will be here, Thank you
Nov 11, 2009 | Toshiba 57H82 57" Rear Projection...
KV36XBR400 fragmented picture horizontal overlapping lines
this will continue to degrade, almost any failure that can be affected or temporarily cleared up by hitting the set is caused by bad solder joints.
A good shop should be able to find and fix the bad solder connections for probably a little under $100
if you bring it to them and pick it up.
Feb 10, 2009 | Sony KV-36XBR400 36" TV
Buzzing and poor recption
I wish I had a solution--My DVD picture and sound is fine, but it takes about 30-40 minutes to get any kind of picture but it is broken--not clear at all - and the sound is all garbled, totally stops for seconds to minutes a a time. It is only a little over a yr old. I finally isconnectexd today and am going back to my cheap-o but dependable tv.
Aug 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Video takes i hour to clear-up
YOU R HAVING A PROB TO A CRT SOCKET OF YOUR TV CALL A TECHNICAL PERSON FOR REPLACE
Aug 27, 2007 | Panasonic CT-2789VYD 27" TV
Panasonic 50 inch plasma tv
It's hard to say without seeing a picture. Panasonic has a site with pictures of various Plasma symptoms and the board that will cause that problem. Go to: http://www.pasctraining.panasonic.com/PASS/elearn/PDP.htm Click on: Pictures of plasma symptoms It will direct you to a PDF file. It may not be your exact problem, but, it will show you which board will cause your problem. Hope this helps.
Apr 21, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
