Question about GPS
My american legacy la 1990 amp has the red power protect light on and i dont know how to fix it. The subs wont workany suggestions
Electro
  • 38 Answers
SOURCE: american legacy II LA690 amp
it's shutting off for a reason. What speakers are you trying to run? Do you know what impedance they are wired for? Where is the gain set? When bridged that amp is only stable at 4 ohms mono and will/should shut down at impedances lower than that.
Posted on Mar 25, 2006
Jexx
  • 148 Answers
SOURCE: amp shutting off going into protection mode
Check this out: http://www.techlore.com/article/14696/
Posted on Aug 17, 2006
  • 47 Answers
MOST LIKELY THE AMP IS BLOWN TRY TO CONNECT ONE SPEAKER AT ONCE TO SEE IF THE IS SOUND IF THERE IS YOU HAVE THE WRONG OHM LOAD
Posted on May 13, 2008
  • 631 Answers
SOURCE: amp problem
Have you checked the fuses on the amp?
Have you confirmed that you have both B+ and remote voltage at the amp?'
When measuring the voltage, place the black meter probe on the ground terminal of the amp.
Posted on Sep 18, 2008
godspeed808
  • 125 Answers
SOURCE: power and protect light blink red
disconect speaker wires from and amp and repower if light is still on disconnect RCA jacks and repower if protection is still on you have a solder jump inside your amp send it in for erepair to dealer or buy a new amp at dealer prices at www.godspeedaudioheaven.com
Posted on Feb 04, 2009
I need to know the size of external fuses for a american legacy amp 2000 watt 2 channel 1990
25 to 30 amp fuses will work great, anything lower could possibly blow a fuse when a good bass note hits even if there is nothing wrong with the amp. Hope this helps.
Jul 09, 2010 | Legacy - American II: 2 Channel 2000W...
My amp keeps going off on protection mode as soon as the bass starts bumping
check powers and earth, unplug sub and crank it up see if it still goes into protect if it doesnt the sub is too much load for that amp and could have damaged the amp, if it still does it then its a fault in the amp or power problem make sure you have good thickness 4gauge and good earth
Apr 26, 2010 | Legacy Audio American Legacy II LA290 Car...
Legacy audio LA590 car audio amp protecet mode
Is that on all the time or are you saying the light is on? If that light is always on that just means it's protecting your amp. If it's off and not playing bass then your in trouble
Mar 01, 2010 | Legacy Audio American Legacy II LA590 Car...
2000 watt american legacy amp protection ligh wont go off
Same thing happened to me so I returned it for repair turns out it was an internal 25amp fuse on the output. Got it back an it sounded very weak now it does not play at all. Nothing wrong with my setup as I have now got an 800watt amp that is running great.
Jul 01, 2009 | Lanzar MXA422 Car Audio Amplifier
LA-1030 Protect Mode
you have an unloaded channel,so the voltage is exceeding what the protect circuit is supposed to see.you have to connect an 8 ohm resistor across the output of the unused channel.
do not drive a signal into it or you will smoke the resistor.
a 10 watt will do ok with zero signal input
May 23, 2009 | Legacy Audio LA1030 Car Audio Amplifier
Orion xtr15 to a american leagacy la 660 amp
your only choice is to run the amplifier at a 4 ohm mono load - this will not reult in the amplifier making much power.
Positive on sub to Positive on amp.
Negative on sub to Negative on amp.
This is your only possibility.
Adding a second sub in the same fashion will result in a 2 ohm load, and your amplifier will run at its rated potential.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 05, 2009 | Orion Xtreme XTR15 Car Speaker
600w legacy amp
9 times out of 10 if your amplifire is in protect mode and evrything externaly, like speakers, fuse, voltage, etc. checks out fine then
either you have shorted out output transistors or power mosfet transistors. Basicly that just about what happens with car amps.
It's easy enough to fix IF, IF you know what your doing. First you
need to check the output transistors with a digital volt meter on diode check, If they check out then check your power supply mosfet transistors. I can almost guarantee this is your problem. Very common. I buy non working amps all the time and repair them. Listen to pbabin also he has helped me out. Good luck
Sep 08, 2008 | Legacy Audio American Legacy II LA490 Car...
American legacy II LA690 amp
May 13, 2008 | Car Audio & Video
GPS Logo
67 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
