Question about ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard
Short beep sound CUV4X-Ckey boart not detecting
Short beep sound
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
This might be a problem from the motherboard. Otherwise it can also be a problem from the RAM.
If this doesn't solve the problem, provide much more details of the issue it helps to understand the problem.
Posted on Jul 09, 2010
Beeping on start up
The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
GuruAid
Apr 09, 2014 | HP Compaq Presario SR1830NX PC Desktop
No display in motherboard help me my number is 7890360208
Do this motherboard beeping sound code first.
1. No beeps means short, no power and loose M.B. peripherals(VGA). (need to change Motherboard).
2. One beep means everything is working good.
3. Two beeps means CMOS error (need change bios rom ic).
4. Continuous beeps means memory not detected (try to clean slot and change memory).
5. One long beep, two short beeps means Videocard external loose or defective parts.
I hope this information will be helpful to you.
Regards
Jul 25, 2011 | Computers & Internet
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
Asus cuv4x-c problems, all capacitors is ok, im getting series of beeps (continuous beeps)
A lot more than just capacitors could be the problem. First things first, if you have a tester, test the power supply. Next is most likely memory problem. Remove the memory piece/pieces clean the contact and memory slots (blow-out with air). Reseat the memory in proper slots. While you are in there, also check that all components are seated. Re-seating the memory should correct the problem. If not, use some different memory sticks to check again. Note: Motherboards are cheap, If your power supply is OK and you are sure the memory sticks are OK, just replace the motherboard.
May 24, 2010 | ASUS VIA Apollo Pro133A Chipset CUV4X-C...
My asus cuv4x-c motherboard doesn't beep? what could be the problem?
It has died of old age - the capacitors have failed. Either try to replace all of them or junk it and get another one.
May 23, 2010 | VIA ASUS CUV4X Socket 370 Apollo Pro 133Z...
No display .. getting three short beeps, pause, one shot beep, pause, four short beeps, pause and another three short beeps.
It's the sound produced by motherboard stating that motherboard is not able to detect the RAM,open the laptop and remove the RAM and clean with a white paper slowly and insert it properly.check it solve your problem otherwise if you have another RAM slot available then try that too. if none work replace with a NEW RAM this will solve your problem
let me know if it's helpful to you
Dec 09, 2009 | IBM ThinkPad R52 Notebook
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
Motherboard has a long beep after initialization
Did you try with different RAM module? If yes and still having the problem then its the keyboard connector which is having problem. Most of the time the capacitors next to the connector, which are meant to subside the external noise, do not function properly. If you have soldering iron, just get rid of those capacitors and you are good to go. If all fails then south bridge has problem which can not fixed easily(in most cases it can't be fixed). Hope this helps.
Dec 11, 2007 | ASUS VIA Apollo Pro133A Chipset CUV4X-C...
Are the PCI slots 2.2 or 2.3 compliant??
download n install bios updates for ur motherboard n then try it!
Nov 07, 2007 | ASUS VIA Apollo Pro133A Chipset CUV4X-C...
ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
