When power os switched inonly leds glow but nothing comes on screen.
    Sniper:
  • 72 Answers
try to unplug every thing connected to the laptop, even the power supply. Now disconnect the battery. Now press and hold the power button for 30 seconds.
Reconnect the battery and power to the unit. now try to power on the machine.
You should be good to go.
In case that this does not help, I suggest you visit the service station
Posted on Jul 09, 2010
When i press the power button, the red light begins blinking blue, the screen flashes once and the tv never comes inon
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 07, 2016 | Televison & Video
My Sony Bravia 32 lcd when doing to ON screen comes for seconds and it goes to off and power led is glowing
Change the power socket its plugged in to.. if that doesnt help maybe you use it too much and it overheats so it cuts.
Sep 11, 2014 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How do i fix my LCD?
I have got a hp pavilion dv5000, when I turn on it the screen goes blank.
Power led glows, I hear for a few time the fan, disk led flashes intermittently and also I feel that the DVD player tries to load.
If I try to click on caps lock or num lock, leds don't respond to commands. I tried the hard reset pressing the power button for 30 seconds with the battery and the power removed. Nothing to be done by connecting an external monitor....
Thank you
Jun 11, 2013 | HP Pavilion dv1000 Notebook
The display of my laptop is not working when i switch it on the backlight glows but nothing appears on the screen it doesn't even boot.
It would be helpful if we knew the Make, Model of Laptop and the OS you are using? Try a hard restart , remove ALL media, DVD, CD, USB, etc., unplug , remove battery, leave battery out, plug in , reboot. Describe what happens, Fan spins? LED's blink? HDD spins up? Sound? Anything on screen? Have you tried a System Restore/Recovery? You can start by removing the HDD and testing it, if you done have a USB to sata/ide adapter take it to a Qualified Computer Tech.
May 04, 2013 | Computers & Internet
CAN'T POWER UP NEW COMPUTER
Do any lights/LEDs glow when the unit is plugged in? If not, you could have a bad charger or battery, If you do see blinking or glowing lights when plugged in, but no display (and you are sure the on/off switch is in the on position) try hooking up an external monitor to see if the built in screen is faulty or even deselected from use. It is possible, if you do in fact have power, that a bios message cannot be displayed on the built in screen.
Dec 30, 2011 | HEWLETT-PACKARD Computers & Internet
When pressing the power button the blue LED on the front for power, hard drive illuminate briefly and then go out. The LED about the mouse pad does the same as does the DVD drive. Does this sound like...
  1. Check your power cord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery.
    If no, then remove the battery & switch on the PC in AC mode.
  4. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  5. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
  6. If still no display, connect an external monitor, check if display is coming. If Display is coming then your LCD need to replace.
  7. Still nothing change, take it to a service centre.
Aug 31, 2010 | HP Compaq Presario F756NR Notebook
Logitech Laser Mouse not working properly
Nothing to worry Just your LED has given way due to long usage. It seems you never switch off your UPS or power supply properly because you can monitor for yourself even after shutting down your red laser on the mouse will keep on glowing until you switch off the power supply to CPU. You can use your mouse without that LED also.
Sep 07, 2009 | Logitech Cordless Desktop MX3200 Laser...
Acer aspire 5100 black screen
pls check the RAM i think it is a RAM malfunction it has nothing to do with lcd if ur system does not bootup and u dont see any hard disk activity as loading OS files while the screen is OFF black then try changing RAM , or if u have 2 chips of RAM try one at a time in one slot that is the upper most or get another one to try with same specs
aslo try connecting the monitor out this will trouble shoot ur LCD screen and vga
pls let me know if i can help more , and rate me FIXYA if i fixed
Mar 09, 2009 | Acer Aspire 5100 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
