Question about Amcor Heating & Cooling
We have an Amcor a/c unit, model AC - 2001M, it was blowing cold air, but is now just blowing cool air, can you help? Graham Collins, Colourdecor Ltd.(01438 355414)
  • 77 Answers
SOURCE: ac BLOWING HOT AIR INSTEAD OF COLD
Check to see if your outside unit is running. If not, check the breaker. If it is running you may have an issue with the reversing valve. It looks like three lines coming out of the top and one on the bottom. Trace the wires back to see that they are tight and secure. Of course, TURN OFF THE POWER first. good luck.
Posted on Apr 18, 2009
SOURCE: AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician.  The freezing up usually is associated with a low refrigerant charge or low air flow.  Check your return air filter and replace as needed.
Posted on May 30, 2009
  • 16 Answers
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Posted on Jun 07, 2009
  • 400 Answers
SOURCE: Compressor not turning on, no cold air
you need new capcitor in your A/C and do also use , if can the (Stabilizer) for coolest performance.... thank you
Posted on Jun 30, 2009
  • 38 Answers
SOURCE: lennox air unit not blowing cold air
your fan motor outside is going bad, have a service company change it out for you.
the motor stopped working and that overheated the compressor shutting it down on thermal cutout, and it will only come on once it cools down
Posted on Jul 01, 2009
Hi, i just bought a second hand amcor air conditioner but it dosent send hot air, what can be the problem?
Air conditioners normally blow cold air, unless it has a built in heat pump. You should post the model with your questions.
Jan 08, 2017 | Amcor Heating & Cooling
Amcor a12000e not blowing out cold air
Halo
Inside of the unit you will find (see attatchment) a feeler bulb witch will be faulty. You might only find 1 feeler bulb witch will be highly rare most of them has two, one for heating and one for cooling.
Now what happens is on the evaporater where it will be located is if on heating the fan does not start until the bulb picks up that the evaporator is warm enough same goes for cooling, only defrence is that it starts the fan when the evaporator is cold enough.
Hope this was helpful.
Regards
Jun 25, 2016 | Amcor Heating & Cooling
KF9000e. Why has it stopped blowing cool air?
Depending on the age of unit either filter blocked needs cleaning or freon low is fan blowing do you have outside of unit clear of obstacles these are all things to check also remember if it's 100 outside AC will only drop air temp 20 or so degrees
Aug 17, 2015 | Amcor Heating & Cooling
I have a portable amcor ac-model-PLM13000E that is just blowing warm air-it is not draining any water.Thanks.
There is no water because the compressor is not coming on and circulating refrigerant. The water comes from the moisture laden warm air blowing across the cold evaporator. If the refrigerant is not flowing there will not be any water.
Aug 02, 2011 | Amcor Heating & Cooling
The unit does not blow cold air any more. Inside is sometimes hotter than outside. will be 85 inside but 80 outside. Have thoroughly cleaned filters, but no change. "comp" light is on
Hi, The compressor has gone bad and it will cost more to replace it then the unit is worth... buy another unit and buy anything BUT an Amcor unit... they are junk!!
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Amcor AF9000E Portable Air Conditioner
Compressor Failing? HELP!!
Portables are priced to replace and not repair unless you are an HVAC tech with your own tools and supplies. There is no guarantee you could even get the imported parts. I recommend you replace the machine; make sure you check with local authorities regarding disposing of a used air conditioner that may contain refrigerant.
May 28, 2010 | Amcor A12000E Nanomax Portable Air...
Ive got an amcor air conditioner, will it blow hot air aswell as cold,
If it blows hot and cool air, it means that you aircon is
not having an isolation of the evaporator and condenser
air. Please have a technician repair the air leak. Hot air from the condenser must be separated from the cool air
of the evaporator. Hope this will help you.
Jan 04, 2010 | Amcor PLM-14000E Portable Air Conditioner
Not cold enough
Check the air coming out with a thermometer. It should be approximately 20-26 degrees colder than the air being sucked in. If it is less than that but it is cooling, there is most likely a freon leak in the system causing it to be low on charge
Jun 22, 2008 | Amcor PLM-14000E Portable Air Conditioner
Heating & Cooling Logo
80 people viewed this question
Top Amcor Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
