Question about Microsoft Windows XP Home Edition
DEP/WMI problem When I boot up I get an error message saying "Data Exectuion Prevention-Microsoft Windows - To help protect your computer, Windows has closed this program. Name: WMI Publisher: Microsoft Corporation" I installed an upgrade to Spyware Doctor yesterday. Could this be the cause? And what should I do to resolve it? My computer is clean (full scan done) and has all latest Windows updates. I run Windows XP (Home ed.) SP3. Do hope you can help.
  • Microsoft Master
  • 11,800 Answers
WMI is a part of Windows that allows other remote computers to control your own. This means that someone has infected your pc with a rootkit that has taken partial control of it. Good rootkits are virtually undetectable and practically impossible to remove. Recover all your files and do a full reinstall - when , during install, you will be asked what type of format do you want select full , not quick.
Posted on Jul 09, 2010
    President:
  • 2,666 Answers
Start in safe mode and do a system restore.
    Guru:
  • 480 Answers
to turn off the message
do the following:
Open Control Panel > system>click on advanced>on perfomance tab click setting> on Performance setting option click on Data Execution Prevention and select the option for DEP on settings accordingly.
thks
DEP as IE shuts of
There is two area's that DEP is held One in the perfomance section and the other in IE Firstly we'll fix IE DEP 1. Open up IE and quickly select Tools 2. Select the advanced tab 3. Uncheck the Enable memory protection 4. Restart IE to apply.
1. Start Control Panel System and Maintenance Performance Information and Tools Adjust visual effect 2. Select the Data execution prevention tab 3. Check the Enable DEP for Essential windows programs and services 4. Restart the computer to apply.
Alternatively
Disable DEP using CMD
A) In the command prompt, type bcdedit.exe /set {current} nx AlwaysOff and press Enter.
B) You should get a success message back
C) Close the command prompt.
D) Restart the computer to apply.
Enable DEP using CMD
A) In the command prompt, type bcdedit.exe /set {current} nx OptIn and press Enter.
Regards
Oct 24, 2011 | Microsoft Windows? Vista Home Premium...
The application failed to initialize properly (0xc0000005). click on ok to terminate the application
"An application error has occurred and an application error log is being generated. Exception: access violation (0xC0000005), Address"
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back Symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
You can read more about DEP at:
http://www.updatexp.com/data-execution-prevention.html
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers and then "Google" to see if their are any other folks reporting this issue. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the tag, an access violation may occur.
Mar 03, 2011 | Computers & Internet
I get the following error as soon as i start casino.exe. The application failed to initialize properly (0xc0000005). click ok to terminate the application. please help me. i like konami casino game...
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then would remove them and see if the error goes away. If it does then send the memory back and get a refund!
/NOEXECUTE
This error also seen when people have updated drivers for their graphics card. If this happens just roll back your drivers. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
Mar 03, 2011 | Konami Casino Inc. for Windows
How to enable or disable programs onDEP
To enable or disable Data Execution Prevention (DEP)
In windows XP,
  • Log in as administrator
  • Open the Start menu, right-click on My Computer and Choose "Properties" from the context menu.
  • On the "System Properties" window, click the "Advanced" tab .
  • click settings button under Performance
  • click the "Data Execution Prevention" tab
  • choose either "Turn on DEP for all programs and services except those I select:" or "Turn on DEP for essential Windows programs and services only to select the OptIn policy"
  • If you choose "Turn on DEP for all programs and services except those I select:", click Add to add the programs that you do not want to use the DEP feature.
  • Click OK twice
  • Restart the computer for the changes to take effect
I hope that you find this information helpful.
Mar 03, 2011 | Microsoft Windows XP Professional for PC
Data protection (DEP ) Can I remove it I have protection without it.
Having DEP is a "good" thing -- your RAM holds "instructions" (such as 'add' or 'multiply') and it holds "data" ('1', 'cat', '2', 'dog').
DEP recognizes the difference between "instructions" and "data", and REFUSES to take a "data" value, and try to interpret as an "instruction". This "prevention" blocks some computer-viruses!
Jul 11, 2010 | Microsoft Windows Vista Home Premium...
Data Execution Prevention-Microsoft Windows...
It may be a virus try a virus scan with Malwarebytes a feeware virus scanner that works well.
Aug 05, 2009 | Computers & Internet
Why do i keep getting DEP error message each time i close IE8 or a tab?
windows xp has DEP ( data execution prevention ) some viruses etc use that sort of technique and from SP2 onwards I believe it was they included it.
http://www.zensoftware.co.uk/kb/article.aspx?id=10002
Several OSs have no-execute or execute protection. Microsoft has added this as well in SP2 with data execution prevention (DEP). This precents code execution in memory regions already marked as storage. This is a powerful tool against buffer overrun exploits. If a program is failing and you want to disable DEP to see if that is the cause. Here are the steps. (Just disable DEP for the program in question… don’t disable it for your whole system.)
    1. Click Start
    2. Select Control Panel
    3. Select System
    4. Click the Advanced tab
    5. In the Performance region select Settings
    6. Click the Data Execute tab in the dialog box that opens
    7. Select Turn on DEP for all programs and services except for those I select
    8. Click Add.
    9. The open dialog box will open. Browse and select your application.
    10. Click Open
    11. Click Apply
    12. Click Ok
    13. Reboot
May 10, 2009 | Microsoft Internet Explorer 8
Desktop doesn't appear on the computer.
hi there, The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
i would suggest that the ram in your computer has possibly broken down over a period, may i recommend obtaining some new ram, if you go to www.crucial.com they can provide you with information that tells you which ram you have in your PC.
Jan 25, 2009 | Acer Aspire 3680 Laptop
Application error - the application failed to initialize properly (0xc0000005) when launch Import Media (HandyCam/Dics) application
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
/NOEXECUTE
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Oct 11, 2008 | Sony DCR-DVD608E DVD Camcorder
Intellinav.exe application error
/NOEXECUTE
CAUSE:
Aug 30, 2008 | Nextar Q3 GPS Receiver
Microsoft Windows XP Home Edition Logo
685 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
