Question about Sanyo Xacti VPC-T700 Digital Camera
My new sanyo camera will not format my memory card it says do not turn power off so i leave it on and the camera turns off itself but the memory card still does not format. Can you help?
  • Sanyo Master
  • 17,130 Answers
Presuming that after trying out to format the memory card is not working out I would request you to please remove the memory card then either using an holder if required connect to your laptop or the PC. Most of the present day computers have the slot for the memory card. As you insert into the computer it will show detection, if not reinsert. Once it is detected, click on the memory device detected in the my computer window , right click for foramt and do so. If the memeor card is not detected or if files are not opening then take a search on the device and open. Delete or format as requried. I hope this help you out. Good day
Posted on Jul 09, 2010
Sanyo S770 lens won't retract on shut off and shuts down when try to zoom and get lens error
Lens error happens during the lens guide pin wrong movement. Please try these below and let me know.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 06, 2011 | Sanyo Xacti VPC-S770 Digital Camera
My old memory card all of a sudden reads unusable, So i bought a new one...and it still says unusable... what do i do? I have only had the camera for 4 months
Try putting the new memory card into the camera and format the card. If the camera doesn't accept that it has a memory card turn the camera off remove the battery and then after about ten seconds put the battery back in and turn it on and see if you can format the new card again. You should always format the memory cards in the camera, even though there is a delete for single images leave them on the card and format the card. Always format the card in the camera not the computer.
By deleting single images in on the card while in the camera it sets up little partitions and pretty soon the memory card is rendered useless. Formatting in the computer writes a little program to the card which the camera can not read.
Dec 20, 2010 | Kodak EasyShare C142 Digital Camera
Formatting memory card
Sir/Madam,
At first, you need to copy all images from the Memory card to a PC using a card reader.
and Second, you can format your card.
It will save your images and you card may be in working condition.
Jan 10, 2010 | Sanyo Xacti S650 Digital Camera
Format digital still camera memory card sanyo xacti s6
new memory cards are not pre partitiond please format with any card reader.
Sep 12, 2009 | Cameras
How did my pictures get deleted by formatting the card?
when you format something it deletes everything leaving it how it came from the factory, it's possible that you had corrupted files and the camera advised to format, next time cancel
Aug 04, 2009 | Sanyo VPC-E760 Digital Camera
Memory card error with new memory card
Hi there, welcome to FixYa.
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Rob
Mar 14, 2009 | Canon PowerShot A75 Digital Camera
SD card formatting problems
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Aug 04, 2008 | Sanyo VPC- C6 Digital Camera
Memory Card Error
format the memory card by using low level format in your camera itself.
it must work. check out and reply the rating
Dec 27, 2007 | Pentax Optio M40 Digital Camera
SD card won't format
Did you update the Firmware of the camera? The VPC-C6 can read and write to SDHC memory cards up to 4GB but it would require to have the latest Firmware being installed on the camera. Firmware can be downloaded via http://www.sanyo-dsc.com/english/support/updata/vpc_c6/index.html
Dec 01, 2007 | Sanyo VPC- C6 Digital Camera
Sanyo Xacti VPC-T700 Digital Camera Logo
338 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
