Question about Sonance Cinema 5150 5-Channel Amplifier
About converting from 110 volt to 220 volt Sonance Cinema 5150
I was wondering if 5150 could be converted from 110 volt to 220 volt?
Regards
David Surjono
Yes no problem all you need is a transfromer that converts 230volts AC to 110 volts AC.
Have a look in your yellow pages to find a Transfromer company
located in your vincinity.
You will need to visit him with the wattage of your amplifier and order a step down transfromer. (The wattage is found on the small plate on the rear of the amplifier. Sometimes its written as KVA?.
Please ensure that the plug on the amplifier is changed to specially fit the 110v output of the transformer this is a must as people plug the wrong plug into the wrong socket and burn out the amplifiers.
Cheers YUBEUT.
Posted on Apr 21, 2008
What spect of voltage conventer transfer to convent the Voltage 110 to the 220-240 V printer??
110 volt to 220 power converter 220 volt to 110 voltage ...
www.dvdoverseas.com/voltage_converters.htm
110-220 volt voltage converter power transformer 220 volt voltage converters 240 ...run on 120 volt 60 cycles (60hz) and most of the worlds run on 220/240 volt ...
Oct 07, 2015 | Canon F151300 LBP 3100 Mono Laser Printer...
Solis 365 royal hair vac I was wondering if it was possible to use this product in australia due to the voltage difference and if there is a product made to suit australian voltage or if an adaptor...
There are products called Step Up transformers/Step Down (Voltage Converters) that can be used. We use these For our 220VAC Australian manufactured lasers when we need to run them in a Dr.'s office that only has US 110VAC.
Info from a website:
Electrical voltage in USA is 110 voltwhereas; the voltage in most of the foreign countries is 220V to 240 volt. A voltage converter / transformer, also known as power converter are usedto convert electricity coming out of the wall to match the voltage of yourdevice. These Voltage transformers or converters can be used safely withRefrigerators, Microwaves, Juicers, Blenders, Coffee makers, Power Tools,Stereo Systems, TV's, Video Games, DVDs, Hair dryers, Chargers, computersand other electronics when travelling abroad..
Remember to leave at least a 100-percent margin for power surges/spikewhen buying a transformer. Some items, such as Televisions, computermonitors spike when you turn them on. For these products you need to buy avoltage converter transformer that is at least 3 times the items capacity.Power tools, laser printers and heating appliances like coffee makers,toasters, microwaves, Halogen, Fluorescent bulbs you must leave a marginof 3-4 times.
Voltage transformers are made to convert single phase 110 or 220 volt.American 220 Volt consists of 2 phase of 110 Volt and European 220 Voltconsists of 1 phase of 220 volt.
Volts x Amps = Watts (i.e. 110V x 0.5 AMPS = 55W). Please make sure not torun any appliance with higher wattage then voltage transformer's wattage.This might damage both: your appliance and the transformer!
I hope this helps.
PHmaddnes Transformer Purchase Guide
May 06, 2014 | Cell Phones
ONKYO TX NR 709 OPERATES WITH 120V FOR US BUT I WANT TO USE ON 220 V AT EUROPE, HOW TO CONVERT?IS IT ANY MODIFICATION OR CONVERTION WHICH MIGHT BE CARRY OUT TO WIRING OR TO RECEIVER'S POWER SUPPLY?
If your Onkyo does not have a voltage button (usually on the backside close to the power supply) where you can shift in between the needed voltage (typically from 110 - 230 voltage) you need to purchase a Voltage converter.
You need one that is able to convert from 110 volt and up to 220 volt. (Step up)
Here is a site which can inspire you to choose the right Voltage converter :
http://www.110220volts.com/Power/Voltage+Converters.html
Regards
Sep 27, 2011 | Onkyo Audio Players & Recorders
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
I want to know if this tv in countries where they have 220 volts energy power need a transformer from 110 to 220? or if it is incorporated automatic or if there is a switch to change
Hello, thanks for the oppertunity to help.
Yes, rest assured you will need a down conversion from 220 to 110 with just about anything. you can purchase these 220 to 110 V converters from just about any eletronics shop.
Throwing a switch on the back of anything at @@V does not grentee it will WORK. specailly if it was made for 110V.
Save some money on repairs purchase this converter for $13 bucks you be glad you did.
Purchase it HERE
Thanks for using fixya.com i hope you find this Very helpful
Regards
Rulds2008
Jan 27, 2011 | Televison & Video
I need to convert power fro 220 to 110 volts
Mixer provides the facility to convert the power to another one.
In the mixer you will provided the key to convert 220 volt to 110 volt.
Drag that key to 110V.
Dec 23, 2010 | Kenwood KM800 Major Classic Stand Mixer
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
Change gas/110volt fridge element to gas 240volt
You need transformer converter 110 to 240VAC.
Regards ,
Edgz
Jan 26, 2008 | Refrigerators
Convert 110 volts to 220 volts
Hi, 1. To convert 110 to 220 - use a step down transformer between your mains and your unit with the watt rating equal to or greater than required by your unit; 2. If I got your brand/model right, I believe it is capable of either 50 or 60 Hz. However, if for some reason you still would want to convert convert 60 Hz to 50 Hz, it will be difficult and technically complicated. At best that I can offer is for you to get hold of an AC-DC-AC converter with the following specs input 220VAC/50Hz output 110/60Hz. 3. NTSC to Pal N would require complicated circuitry and if ever available would be expensive. Past experiences have shown me that any color conversion is not that satisfactory. It may be to your advantage to return the unit and have it replaced with a region correct model. Good luck and kind regards.
Aug 20, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Sonance Cinema 5150 5-Channel Amplifier Logo
228 people viewed this question
Top Sonance Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sonance Audio Player and Recorder Expert? Answer questions, earn points and help others
