Question about Estate TAWX700JQ Top Load Washer
Estate by whirlpool washer
Wont turn over, buzz sound
  • Anonymous Feb 08, 2009
    my washer will run on rise but there is a buzz sound when you go to a cylcle
  • Pataricia Nolte
    Pataricia Nolte May 11, 2010
    do you mean it won't spin?
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#@##$
Posted on Oct 01, 2010
  • 62 Answers
Probably it is your motor to transmission coupler.
Posted on May 12, 2009
Buzzing sound wont spin out
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Replaced the coupler, washer started then smelled hot and now will not do anything but when it is turned on it makes a buzzing noise
sounds like either your transmission is locked or your drum brake is jammed. Either way you will need to pull the transmission off to inspect and replace. This is based on the average whirlpool, roper, kenmore estate or tappan.
Mar 14, 2010 | Washing Machines
Washer wont spin without help from me and then dont go very fast
Estate is a Whirlpool Family Appliance. On this direct drive washing machine there is what is called a BRAKE & DRIVE TUBE also called a clutch. Replace this clutch. MAKE SURE that there is NOTHING foreign in between the inner and out tub.
Dec 04, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My Whirpool Estate washer will not rinse spin or drain
The motor turns in one direction to wash and the other to spin. If it will not spin I feel sure it's a bad motor.
Please rate solution
Sep 04, 2009 | Whirlpool Washing Machines
Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Jul 14, 2009 | Washing Machines
Washing machine spin problem!!!!!
whirlpool estate washer is dun the clothes are ring Wet
Jan 13, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Not agitating
Check your drive coupler. Its the rubber piece between the motor and the transmission which makes the washer agitate and spin. the easiest way to check it is to lean the machine back and look for rubber on the floor. Then look behind the motor to see if it is still in tact. Next try wiggling it, If it wiggles a lot replace it. If that doesnt fix your problem, you probably have a bad transmission.
Nov 18, 2008 | Estate ETW4100SQ Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
97 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
