Question about Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228
Just replaced my Emerson 2hp pool motor. Turned on new motor all is working fine but water isn't filling the basket?
    Novelist:
  • 116 Answers
First of all you need to fill the pot with water. it is best to pour a bucket in or use a hose and turn the pump on and off real quick a couple times to **** some water into the pump. Once you do that fill the basket as much as possible and quickly put the lid on and turn on (make sure your lid o-ring is there and in good shape. lubricate it with pool lube so it's wet but not all gooped up). when you turn the pump on you should see water either splash, or at least start trickling into the pot. if you see water splash in, but then go dry again, or if it just trickles but doesn't prime after about 20 or 30 seconds, then you may very likely have an air leak on the suction side. Make sure your lid is sealed, the pipe goin into pump is not loose or leaking air, and make sure the pool cleaner hose is not out of the water, or the skimmer sucking air. If the pipe coming into the pump is sucking air or you suspect it might be try wrapping black electrical tape tightly all around the joint (where it threads into the pump). This is temporary troubleshooting step but works great. If there is a union or a Jandy valve where the pipe comes into the pump check o-rings and all joints for leaks.
Posted on Sep 18, 2010
What causes a pool pump motor to overheat
Blocked or clogged water input line
Sucking air from a leak, not enough water thru system
Excessive debris in strainer baskets
Filter needs to be backwashed
Filter needs new sand or new cartridge
Filter needs to be taken apart and "fingers" cleaned
Filter Pump Impeller is obstructed
Filter motor is in-correctly wired
Filter motor bushings need replacement
Filter motor bearings are worn
Filter motor is "shot"
Apr 16, 2013 | Emerson Pool & Spa
I had a Smith 1HP pool pump with a square flange on my Haywwod sand filter. After 12 years it died. The pool shop sent me home with a Emerson 1hp., 1081 pool motor. It doesn't pull the water like the...
Sounds like there is an impeller problem. A 1hp emerson should be fine. Take it apart and recheck impeller and diffuser. I am assuming they gave you a new seal to replace with the motor.
Apr 26, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Pentair Whisper Flow 2hp pump appears to not **** as much water as before. Filter basket recently broke and allowed small leaves to get sucked up by the motor. Could this be the reason for the loss of...
Yes, If the debris you speak of got past the filter basket, it can clog the impeller. If the impeller is clogged, it wont pump water. Simply remove the 6 bolts on the pump end, then remove the diffuser with a 3/32 hex wrench, then clean the impeller. Its very easy, and very important that this get done every 6 months in an outdoor pool with trees surrounding it.
Also, the filter basket should last a long time, if this is breaking on you, make sure your water chemistry is in check. Agressive water can cause lots of damage and cost lots of money.
If you still have bad flow after this fix, replace the shaft seal.
Mar 29, 2011 | Pentair WhisperFlo 2HP Up Rated In Ground...
Help low pressure in pool pump and filter
I can relate so well to your problem. My pool is surrounded by pines and deodora trees... all the needles seem to find their way through the baskets, strainers and into the inlet of the pump. It became a daily routine of having to reach into the inlet and clean the debris if I wanted a filtered pool.
Here' s a solution that will work!
Purchase an extra debris scoop ...the kind you put on the pole and scoop debris from the bottom of the pool.
Cut the net out of the frame and wrap the netting around the skimmer's debris basket and secure it with an oversized rubber band or zip ties, then replace the basket back in the skimmer.
Your skimmer will keep the debris out of the pump!
This will make a world of difference in your pump's pressure!
Give it a try and see if you're not working better!
Jun 03, 2010 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
1/2hp Hayward Pump for existing inground pool
you will be fine with the 1/2hp. The Hayward will move quite a bit of water as well. It may not move as much water as the 3/4hp but it's very close and the 1/2hp will cost a little less to operate so if anything, you may just have to run it for one additional hour per day to compensate. You will be surprised how much water a 1/2hp will move. The only issue with smaller pumps is if you have pop-up cleaner heads or a suction driven automatic cleaner such as a kreepy krauly, however, if a 3/4hp will run it, a 1/2hp will run it as well. You can install a larger motor on the super pump but it will not move more water unless you upgrade the impeller as well. Just make sure you don't use a bigger impeller than what the motor is rated for because it will strain the motor and cause it to overheat. Hope this helps.
Feb 20, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward variflow filter SP710 O.K. with 2Hp pump?
Yes you are well within your limits on that filter, as long as your not way far away from the pool with small return lines.
Jan 06, 2010 | Hayward SAND FILTER, PRO SERIES
My pump was working just fine all seaon. I turned
check that pool cover is not blocking filter intake.intake hose may need to be temporarily re-routed to a point below skimmer to drain water.
Sep 26, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
My new AO Smith 2HP pool pump won't pump water, just hums
I'm guessing that you replaced the motor that goes to the pump, not the pump itself. You know the motor works just fine. Is the motor rotating in the correct manner(clockwise or counterclockwise) in relation to the rotation of the pump? Have you checked the pump to see if the impeller is working/rotating? Is the motor hooked up to the pump correctly, so that the motor is turning the impeller? Are all connections to the pump tight, so there are no suction leaks? Have you primed the pump and purged it of any air locks?
Aug 11, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Lost my prime in my pump, i have tried numerouse time fill the basket area with water turn on pool pump nothing, any more suggestions. I lost my prime to my pump a few weeks ago . I had a pool company...
please check your impellar it sounds like it is broken this is the part that really moves the water if motor is ok then it would most likely be this .
Thanks for useing fixya
Rate me
Apr 27, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228 Logo
173 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
