Question about Daewoo DVDS151 DVD Player
Daewoo dvd install
I've got my dvd player hooked up through my vcr or I thought I did,theres power but can't see or hear it.I've got hooked up throgh vcr so I don't have to buy a converter box.
  • 323 Answers
  1. Be sure that your VCR is a newer one with at least one "line in" set of jacks in the back. Some have one in the back and one in front.
  2. Your DVD Player should have a video/sound cable with 3 connectors on each end. Otherwise get one or 3 single cables.
  3. Connect DVD Video Out to VHS Video In (yellow).
  4. Connect DVD Left to VHS Left (white).
  5. Connect DVD Right to VHS Right (red).
  6. Turn on your DVD and VHS.
  7. Your VHS should have a tuner setting for "L1" or "L2". Select whichever shows the DVD's video on the TV.
  8. Remember to select that input channel whenever you want to watch the DVD.
  9. When watching a DVD, if you have a blank VHS in the VCR, you may record what you are watching onto the VHS, just as if you were recording from cable.
Verify these steps and you should be good to go ;)
Posted on Apr 19, 2008
How do I hook up my Toshiba DVD player to my old Daewoo Tv /vcr combo
what inputs does the old Daewood / VCR combo use is it RCA and Video cable on an AV input? How many Av inputs are there in TV ? Does the DVD player have AV out audio out (Yellow) RCA (Red and White). If you do not have enough AV inputs on the Tv use an AV switch box . and Switch two AV RCA inputs /DVD and VCR and into one output to the TV. You may be able to feed the AV out RCA out into the VCR AV in and switch the input on the VCR.
May 25, 2015 | Toshiba Televison & Video
We just purchased a Samsung TV, and have been using a RCA DVD/VCR player/recorder, Model#: DRC8295N, Serial#: XXXXXXXXX We have Direct TV and before the new tv was using one of their DVR player/recorders....
The problem with your DVD/VCR is that when you hooked up your new TV you probably removed the power cord for the DVD/VCR during installing and running your new wires and such.
Your DVD/VCR has known problems in the power supply. This is very common. When unplugged, this allowed the capacitors to discharge and now wont work at all. It is very possible that if you left your DVD/VCR plugged into the AC wall socket it might begin to work after a couple of days. I wouldn't plan on it though.
Your DVD/VCR will need power supply repairs.The cost should be around $100 dollars.
if you would like one of our stores to repair this for you we would be happy.
please visit http:www.albiontvandcomputer.com
You can send us the unit and we can repair this for you and return in about a week.
Jan 18, 2011 | RCA DRC8295N DVD Recorder/VCR
Daewoo S04 DVD won't open
The tray is blocked. Unplug and open the player's casing and check for any obstructions and remove it. It might be a disc or something. Check also the gear as you can hear the motor running but the tray don't open.moz-screenshot.png
Aug 23, 2009 | Daewoo DVRS04 DVD Recorder/VCR
Daewoo dvdplayer/vcr combo switct over switch not
that happend to me and we had to take it apart to figure out the problem.
Jul 14, 2009 | Daewoo DV-6T834 DVD Player/VCR
My dvd/vcr promblem
Neen codes to program in my remote
Dec 26, 2007 | Daewoo DV-6T834 DVD Player/VCR
Proluxe ce818
I have this DVD player, and it has surround sound connectors, and seperately L/R connectors.
Whilst the L/R should mix-down the surround sounds, it doesn't appear to and only actually play the surround sound left and right.
My solution was to plug one of the RCA leads into the "Center" of the surround output, (can leave the other in the L or R slot)
you'll then get voice, out one speaker and ambient sounds out of the other.. It sucks, but that's why this things a freebie.. it's not well designed :P
Nov 26, 2007 | GoVideo DVD-VCR Combo
DVD/VCR Locked
My DVD/VCR Daewoo locked and everytime i pressed a button it just said LOCK! I plugged off the vcr for a few hours and then plugged it back in and pressed the on button. Now im watching the dvd that was stuck inside. Try it, you just never know.
Nov 19, 2007 | Daewoo DVRS04 DVD Recorder/VCR
Dvd function not working
PS is progressive scan, unless you have the player hooked up to a HDTV on its component inputs it wont play video, you need to locate button either on the front of the unit or on the remote for the Progressive Scan, this might be a good thing to look up in the manual as I dont know much about this unit.
Jul 07, 2007 | Daewoo DV-6T955B DVD Player/VCR
Daewoo DVDS151 DVD Player Logo
114 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
