Question about Alpine SPS-600C Car Component System
How should I wire a 4 channel amp for alpine sps 600, 609
How should I wire a 4 channel amp for alpine sps 600 & 609's? A diagram would be greatly appreciated. I could use step by step instuctions as well. Thanks for the help.
    Problem Solver:
  • 8 Answers
They are only 4 ohm speakers so just put the front speakers on channels 1&2 or a&b and the rear on 3&4 or c&d since you are using a 4 channel amp thats what they are designed for
Posted on Jul 15, 2010
I have 2 2 ohm dvc alpine type r 12 inch subs. Each voice coil on both subs reads 2.5 on ohm meter. I need wireing diagram to hook up to a boss 2500 class a/b amp at 2 ohm
To have 2x 2 ohm subs wired up, they either need to be wired in series or in parallel. In series, they will total as a 4 ohm load to the amp (or 5 ohms if 2.5 each) and in parallel, they will be 1 ohm (may be closer 1.25 ohms I think).
If this is a mono block (single channel) amp, I can't see that you will be able to wire them for a 2 ohm loan. You may have to wire them in series to be a 4/5 ohm total as the amp probably won't be 1/1.25 ohm stable.
Apr 27, 2017 | Alpine Car Audio & Video
Dan alpine sps- 610C speakers be installed in a 2011 sonata
as long as they fit in the hole..u good..whether or not your radio can thump em?...mabe you can add an amp later
Jan 08, 2014 | Car Audio & Video
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
I am wondering about car amplifiers, I don't know what kind to get, I have Alpine 6.5" 2-Way Car Speakers (SPS-600), 80 watt as my front speakers, and Alpine 6 1/2" 2-Way Car Speakers (SPR-17C), 100 watt...
I would strongly recommend that you get a 5 channel amp that puts out 75watts rms per channel that will deliver between 200-300 watts to the sub channel. I use planet audio amps myself and they run strong all day every day-maybe you could look at a planet audio vrx 600.5(5-channel) it throws 100w x4 and 200 or 300 to the subs depending on the resistance of the sub. Good luck
Jan 27, 2010 | Car Audio & Video
Im having trouble installing the sps-600c alpine speaker system. i need a wiring diagram or somthing as im un farmiliar with split speakers that dont have a cross over.
Hello lucal_s2000,
Well, actually those 600c's do have a crossover. It's encapsulated in the wiring you got with the components. Your head unit or amp speaker outputs connect directly to the woofers. The inline crossovers have a 12" wire on one end and a 22" wire on the other end. Connect the 22" side to the 2nd set of terminals on the woofers, and the 12" side to your tweeters, keeping all of the positives and negatives straight.
Here's an image of the connections.
5eca958.jpg Hope this helps.
Apr 12, 2009 | Alpine SPS-600C Car Component System
Want to bridge my alpine 3555 amp to run my sub.
I'm assuming this atleast a 2 channel amplifier all you need to do is hook the negative side of the speaker wire coming from the sub to the negative channel one. and the positive to another positive on channel 2. Should indicate on your amplifier channel one and two. most amps provide a diagram right on the amplifier over top of the speaker inputs. let me know if this helps.
Mar 07, 2009 | Alpine Car Audio & Video
Power Acoustik Area 51 Amplifier
I havthe same amp. Try moving youry ground t a different location. that seemed to help me when i was brigging mine.
May 08, 2007 | Power Acoustik Area 820x2 Car Audio...
Alpine SPS-600C Car Component System Logo
289 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
