Question about XG Viper 2 ATX Mid-tower Gaming Case w/Acrylic Window Blue LED & 500W Power Supply - Silver (ET-CAV2-SL) ATX Mid-Tower Case
What is fp out/audio header wireconfiguration for a viper 2
I WANT FULL INFORMATION 15 K86 011000 671T MV.1.0 MOTHERBOARD?
CPU ? LGA775 socket for latest Intel Core 2 Duo / Pentium D / Pentium 4 / Celeron D processor
? Supports Hyper-Threading Technology CPU
CHIPSET ? SiS® 671 & 968
? North Bridge: SiS® 671
? South Bridge: SiS® 968
GRAPHICS ? SiS Mirage 3 graphic engine
? Share Memory: Maximum up to 256MB
MEMORY ? Single-channel DDR2 memory architecture
? 2 x 240-pin DDR2 DIMM socket support up to 4 GB
? Support DDR2 667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT ? 1 x PCI Express x16 slot
? 1 x PCI Express x1 slot
? 2 x PCI slots
STORAGE ? Support by SiS 968
• 2 x Ultra DMA133/100/66 devices
• 2 x Serial ATA 3.0Gb/s devices
• RAID0 & RAID1 configuration
AUDIO ? Realtek ALC660 6-channel audio
? Compliant with HD audio specification
LAN ? Broadcom AC131 10/100 Lan Phy
REAR PANEL I/O ? 1 x PS/2 keyboard & PS/2 mouse connectors
? 4 x USB ports
? 1 x VGA port
? 1 x Serial port (COM1)
? 1 x RJ45 LAN connector
? 1 x Audio port
INTERNAL I/O CONNECTORS & HEADERS ? 1 x 24-pin ATX Power Supply connector
? 1 x 4-pin ATX 12V connector
? 1 x IDE connector
? 1 x FDD connector
? 2 x USB 2.0 headers support additional 4 USB 2.0 Ports
? 2 x Serial ATA connectors
? 1 x CD in header
? 1 x Front panel audio header
? 1 x Front panel switch/LED header
? 1 x SPDIF out header
? CPUFAN/SYSFAN connectors
SYSTEM BIOS ? AMI BIOS with 4Mb Flash ROM
? Supports Plug and Play 1.0B, APM 1.2, Multi Boot, DMI
? Supports ACPI revision 1.0 specification
FORM FACTOR ? Micro-ATX Size, 244mm*220mm
Dec 21, 2014 | Computers & Internet
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
Is there a way to put more than 2 Gigabyte of RAM onto an Abit LG-95Z motherboard?
No, the mainboard does not support more than 2 gb of ram.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?fMTYPE=LGA775&pMODEL_NAME=LG-95Z
CPU
  • LGA 775 Socket for Intel® Pentium® Dual-Core / Pentium® D / Pentium® 4 / Celeron® D Processors with 800 MHz FSB
  • Supports Intel® Hyper-Threading Technology
  • bullet_31.gif Chipset
  • Intel® 945GZ / Intel® ICH7 Express Chipset
  • bullet_31.gif Memory
  • 2 x 240-pin DIMM sockets support max. memory capacity 2GB
  • Supports Dual Channel DDR2 533 Un-buffered Non-ECC memory
  • bullet_31.gif Graphics
  • Integrated Intel® Graphics Media Accelerator 950 (Intel® GMA 950 )
  • bullet_31.gif LAN
  • On board 10/100M PCI controller
  • bullet_31.gif Audio
  • On board HD 7.1CH Audio CODEC
  • bullet_31.gif Expansion Slots
  • 1 x PCI-E X1 (Wi-Fi Accessories)
  • 2 x PCI
  • bullet_31.gif Internal I/O
  • 1 x Floppy Port supports up to 2.88 MB
  • 1x Ultra DMA 100/66/33 IDE connector
  • 4 x SATA 3Gb/s connector
  • 2 x USB header (support 4 ports)
  • 1 x FP-Audio, 1 x CD-In
  • bullet_31.gif Back Panel I/O
  • 1 x PS/2 Keyboard, 1 x PS/2 Mouse
  • 1 x Serial port, 1 x Parallel port, 1 x VGA connector
  • 4 x USB 2.0, 1 x RJ-45 LAN connector
  • 7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
  • bullet_31.gif Serial ATA
  • 4 x SATA 3Gb/s offer by Intel® ICH7
  • bullet_31.gif Form Factor
  • Micro ATX form factor 244 x 244mm
  • PCB Color: Blue
  • Aug 21, 2011 | Abit LG-95Z Motherboard
    I HAVE HYTECH PCI SOUND CARD. BUT MY FRONT PANEL AUDIO IS NOT WORKING. HOW TO SOLVE
    Hello there,
    1. You must trace the front panel audio headers if it is attached to the right device.
    2. Remove audio headers from the mother board if you are using a PCI sound card.
    3. Check if your sound card has the proper audio headers.
    4. Next configure your audio software if same jacks are tied up.
    The image below is a Typhoon sound card, the rectangle box signifies audio headers. I don't have a clear image of your audio headers. It would be a big help for us to help you. the images provided below will help you to configure your front panel audio. pcsyke_80.jpg
    This is the default header assignment for front panel audio.
    Most casing this days have this dependent or intact headers unlike before.
    This is an example of independent front panel audio in different configurations.
    Hopefully this information Helps.
    Thank you for using FixYa.
    Jul 20, 2011 | Typhoon Anubis Typhoon Silver Crest 3D...
    Motherboard specification
    Intel 865GV Chipset Pentium 4 Main board,
    Supports Prescott CPU
    FSB800, DDR 400, SATA 150 Specifications
    arrow_bullet.gif CPU
    • Supports Intel Pentium 4 Socket 478 processors(Prescott and Northwood) with 800/533/400MHz FSB
    • Supports Intel Hyper-Threading Technology
    arrow_bullet.gif Chipset
    • Intel 865GV/ ICH5
    • Integrated Intel Extreme Graphics 2
    • Supports Advanced Configuration and Power Management Interface (ACPI)
    arrow_bullet.gif Memory
    • Two 184-pin DIMM sockets
    • Supports 2 DIMM Single/ Dual Channel DDR 400/ 333/ 266 memory (Max. 2GB)
    arrow_bullet.gif Graphics
    arrow_bullet.gif SATA 150
    • 2 channel Serial ATA 150MB/s data transfer rate
    arrow_bullet.gif Audio
    • 6-Channel AC 97 CODEC on board
    • Professional digital audio interface supports optical S/PDIF Output
    arrow_bullet.gif System BIOS
    • Supports Plug-and-Play (PNP)
    • Supports Advanced Configuration Power Interface (ACPI)
    • Supports Desktop Management Interface (DMI)
    • Write-Protect Anti-Virus function by AWARD BIOS
    arrow_bullet.gif LAN
    • On board 10/100Mb LAN
    arrow_bullet.gif Internal I/O Connectors
    • 3 x PCI slots
    • 1 x Floppy Port supports up to 2.88MB
    • 2 x Ultra DMA 33/66/100 Connectors
    • 2 x Serial ATA 150 Connectors
    • 2 x USB 2.0 headers (Each header support two USB 2.0 devices)
    • 1 x CD-IN, 1 x AUX-IN
    • 1 x FP-Audio header
    arrow_bullet.gif Back Panel I/O
    • 1 x PS/2 Keyboard, 1 x PS/2 mouse
    • 1 x Parallel Port, 1 x Serial port
    • 1 x VGA Port
    • 1 x Audio connectors (S/PDIF Out, Surround Out, Center/Sub, Lin-out, Line-in, Mic)
    • 4 x USB 2.0, 1 x RJ-45 LAN Connector
    arrow_bullet.gif Miscellaneous
    • Micro ATX form factor (244mm*234mm)
    • Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
      hope this helps
    Jul 07, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
    I received two of these systems in the mail and I am going to attempt to install it myself. I have been reading up and wanted to know if there are any detailed install instructions that I can find....
    Not sure if you have this already, but here's a link to the wiring diagram for your vehicle: http://www.modifiedlife.com/2003-buick-rendezvous-remote-starter-wire-diagram/
    Notice: All Viper Car Alarm Systems, Remote Starters and Keyless Entry Systems Require DEI Professional Installation for Warranty!! I'm sure you already have the owner's manual, but here's a link to Viper's http://www.viper.com/Support/ Last but not least... this is what I found online in regards to installing your Viper 5701 2-way Alarm w/ remote start: http://forums.evolutionm.net/evo-audio-security/364122-diy-viper-5701-install-ct9a.html
    Hope some or all of this helps you!
    Dec 15, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
    How to remove linker error in Tc C++ 3.0 in graphics.h header file and iomanip.h and msoftcon.h and windows.h
    #include<stdio.h>
    #include<conio.h>
    #include<string.h>
    #include<stdlib.h>
    #include<ctype.h>
    struct student
    {char name[20];
    int rollno;
    int mark;
    void main()
    int ch,f,roll,i,j,l;
    char name[20];
    struct student k,t,d[50];
    FILE *fp,*temp;
    clrscr();
    fp=fopen("stud.c","wb");
    fclose(fp);
    while(1)
    {printf("\n=========================\n");
    printf("\n\n1.Insert\n2.Display\n3.Search\n4.Delete\n5.Sort\n6.Update\n7.Exit");
    scanf("%d",&ch);
    printf("\n==========================\n");
    switch(ch)
    case 1:
    printf("\n Enter name");
    scanf("%s",k.name);
    printf("\n Roll no:");
    scanf("%d",&k.rollno);
    printf("\n Mark");
    sanf("%d",&k.mark);
    fp=fopen("stud.c","a+b");
    fwrite(&k,sizef(k),l,fp);
    fclose(fp);
    break;}
    case 2:
    fp=fopen("stud.c","rb");
    while(fread(&k,sizeof(k),l,fp)!=0)
    printf("\n name:%s \t Rollno: %d \t Mark:%d",k.name,k.rollno,k.mark);
    fclose(fp);
    break;
    case 3:
    {f=0;
    printf("\nEnter the rollnumber to be searched :");
    scanf("%d",&roll);
    { if(k.rollno==roll)
    f=1;
    printf("\n Name:%s \t Rollno:%d\t Mark:%d,k.Name,k.rollno,k.mark");
    if(f==0)
    printf("searched item does not exit");
    fclose(fp);
    break;
    case 4:
    f=0;
    printf("enter the roll no for deleting the record:");
    scanf("%d",&roll);
    temp=fopen("temp.c","wb");
    if(k.rollno==roll)
    f=1;
    else
    fwrite(&k,sizeof(k),l,temp);
    fcloseall();
    if(f==1)
    temp=fopen("temp.c","rb");
    fp=fopen("stud","wb");
    while(fread(&k,sizeof(k),l,temp)!=0)
    fwrite(&k,sizeof(k),l,fp);
    printf("record deleted");
    else
    printf("roll no not found");
    fclose(fp);
    fclose(temp);
    break;
    case 5:
    i=0;
    while(fread(&d[i],sizeof(k),i,fp)!=0)
    i++;
    fclose(fp);
    for(j=0;j<i-1;j++)
    for(l=j;l<i;l++)
    if(d[j].rollno>d[l].rollno)
    t=d[j];
    d[j]=d[l];
    d[l]=t;
    for(l=0;l<i;l++)
    fwrite(&d[l],sizeof(k),l,fp);
    fclose(fp);
    printf("\nsuccessfully sorted");
    break;
    case 6:
    f=0;
    printf("enter roll number to update:");
    scanf("%d",&roll);
    if(roll==k.rollno)
    printf("enter the new record name,mark\n");
    scanf("%s%d",k.name,&k.mark);
    f=1;
    else
    fcloseall();
    if(f==0)
    printf("roll no is not present");
    fcloseall();
    break;
    case 7:
    exit(1);
    break;
    Nov 25, 2010 | Borland Turbo C++ 3.0 Full Version...
    No sound due to incorrect wiring on motherboard
    If you are unsure of the correct pins for the FP audio header disconnect them and use rear audio ports.
    Sep 20, 2009 | Acer Computers & Internet
    XG Viper 2 ATX Mid-tower Gaming Case w/Acrylic Window Blue LED & 500W Power Supply - Silver (ET-CAV2-SL) ATX Mid-Tower Case Logo
    47 people viewed this question
    Top XG Computers & Internet Experts
    David Payne
    David Payne
    Are you a XG Computer and Internet Expert? Answer questions, earn points and help others
