Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Color Within the last 2 days, the color of my tv is not right. I can go thru all the settings, get it close, but if i go to another channel, it's terrible again. I've had the best pic since i've had the set. i've also tried a different set of component cables and hdmi. same issues. is there more of a diagnostic area i can get into? any type of convergence with lcd? this problem is driving me NUTTS... thanks in advance for any help... kenny
  • 927 Answers
Good Day, kenny;
Since you are using comp. and HDMI inputs tells me you using some type of BOX. Suspect the BOX the is only a monitor at this point, like your computer set-up.
Good Luck, big IRISH.
Posted on Aug 26, 2008
Recently(within the past 6 months...) have been having a problem with my L37HDTV10A. The picture always takes a yellow hue. This applies to every input accross the board, and changing hue and color...
A digital TV handles the color in three channels, red green and blue. Your TV has a problem on the red channel. That causes pictures getting yellowish. The computer functions can compensate the fault, but that is not a solution. If the problem happens on every input and also with internal tuner, then the logic circuits that elaborate video signal are defective. The main board is usually replaced to fix the problem. Before replacing the main digital board the technician can check if any repairable fault is found. A contact in one of the input for example may short the circuit affecting one of the color channels. In that case the tech will only need to resolder the connector on board to fix the problem. More commonly the whole board must be replaced.
Here parts for this TV: L37 TV Parts ' ShopJimmy
Sep 19, 2011 | Vizio L37 Television
Here are some preferred settings for the same model in 32" It should get you close enough to fine tune from.
  • Picture Modes
    • Picture Mode : N/A
    • Color Temperature : Warm
    • Aspect Ratio : Wide
  • Precision Settings
    • Contrast : 60
    • Brightness : 50
    • Color : 52
    • Tint : G1
    • Backlight : 3
  • Advanced Video Menu
    • Noise Reduction : Off
    • 3DYC : Off
    • Dynamic Contrast : Off
Dec 25, 2009 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Color is terrible - lot of green
If this is a CRT type most probably loosely connection of the other color gun. Commonly attached to the backend of the CRT.Dust problem or transistor is busted for color red and blue. Or some minor component connected to driving color.
Apr 08, 2009 | Sony Televison & Video
Jvc av-20cm5 channel programming issue
you have a programing error in the main control ic it ca be repaired but its $$$$$$ my guess is 150.00 -200.00 the control ic has a modified control memory the memory is held in place by a charged capacator if you unplug it and leave it for a week and plug it back in it might be ok for a while if not try unplug it for a month . that might be enough for a reset but the problem will keep comeing back the chip is damaged
Apr 01, 2009 | JVC Televison & Video
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Picture within a picture on screen
Click here to find info the user's guide and how to turn close caption OFF. Download all the files and and you should find the info on page #19 but you will need to have the TV remote control or if your TV has a menu/set up button on the front panel, you can try to get to close caption using the channel up/down and volume up/down.
Good Luck.
Oct 10, 2008 | Sony KV-35V35 TV
Double color image (blue and Yellow)
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
Good luck, big IRISH.
Jul 27, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
42 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
