Question about Canon EOS Rebel XSi Digital Camera
I was taking test photos around the house with my new camera and the flash won't fire properly (the flash pops up out of the camera but it makes little sparking sounds and flickering on and off). I've tried various modes including auto night etc but it won't stop flickering (just sparking sounds and a flickering flash like a light bulbs does just before it blows).also I have tried taking images using the basic auto mode in a low lit area and the flash pops up but does not fire.
  • 94 Answers
I think top cover is faulty it s giveing error 05. if poop up and giving err99
then flash pcb faulty other wise need to replace top cover.
Posted on Aug 04, 2010
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
Sony a200 Flash pops up then flashes as if its shorting and I am unable to take any photos.
Are you shooting in low light? Sometimes the flash will fire multiple short bursts to aid in focusing. If the camera is not in focus, then depending upon your setting it will not fire.
Oct 31, 2012 | Sony Alpha DSLR-A200 Digital Camera
D90 Built-in flash won't fire
Go in menu go to bracketing /flash then set for TTL
you should work to test leave lens cap on push button on left side with lightning bolt on it.
Oct 18, 2012 | Nikon DSLR D90 Digital Camera
Ixus 430 will take photos when flash is turned off, but will not take photos when flash or redeye is selected
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try. (Hint, make sure that all the screws around the perimeter of the case are present and firmly seated.)
Jun 01, 2011 | Canon PowerShot S410 / IXUS 430 Digital...
All of a sudden my sb-400 won't fire. i have changed the batteries numerous times and the red ready light is on but when i take a pic the auto flash pops up and the speedlight won't fire.
HI, I have a SB-400 with cracked housing, and hope to find a broken one to replace my part. Any offer is very much appreciated if you are interested of selling yours! Sincerely, Samantha (utwicky at gmail dot com)
May 14, 2011 | Nikon SB-400 Flash
How can you test a camera before use to be sure the flash sync is working properly.
Set camera up and aim at a blank wall. Place flash on camera, fire off test shots with camera set to flash sync speed and lens set to wide angle (eg 18 mm), ensure flash matches angle of lens.
You will probably have to turn auto focus off, so that camera will fire, after taking photo/s use review to ensure that you have a nice even coloured piece of wall.
Any problems either with camera sync problems or flash coverage will show up in the test shots.
Camera sync, will show as part of the frame only exposed, for example you may find a horizontal line approximately 1/3 to 1/2 of frame with a proportion of the frame dark.
If you have flash "drop off" you will find the corners of your frame will be dark, you need to ensure that your flash angle specified on the flash and the focal length of the lens match.
Hope this helps Ian
Jul 21, 2009 | Cameras
Can't take photographs when flash is on
Hi
The powershot s5 IS does in fact have some strange behaviour issues especially on the first rev firmware. For example if you take 15-20 flash photos consecutively without powering down your camera the flash recycle times will increase to about 15sec, so you'll have to wait about 15sec before you can take another flash photo. The work around is to power down the camera and then turn it back ON. Another strange behaviour is manifested by its inability to lock focus after taking a "no-flash" photo, then popping up the flash and trying to take a flash photo. Again the work-around is to power down the camera, pop-up the flash and then power it back up. Confirmed these behaviours in two other cameras of the same model.
Jul 13, 2008 | Canon PowerShot S5 IS Digital Camera
Built-in flash does not fire off
Not really a solution, and about 3 years late :) my EOS400D also developed the same problem (however it was also coincidence that I had just updated to Firmware 1.1.1 (from 1.0.4), but basically the flash would pop up, but wouldn't fire (so not the standard problem with the microswitches), I found with a bit of forum searching that if you hold the flash down to almost clicking it in and then shoot it does actually fire. I am going to see how much it costs to get this fixed and will post what the actual fault is if I can understand the repairman.
Mar 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Pop-up flash
make sure after popping up the flash, you didn't change the mode into "no flash" mode....an easy way to check is put the flash back down, then proceed to take another photo. If the flash pops up again but did not flash, you have a faulty camera (assuming battery level is at least until the 1/3 mark).
Dec 26, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Canon EOS Rebel XSi Digital Camera Logo
329 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
