I have an alficio 1505 copier machine and i am encontering some problem sc 320 what does thid means?
    Problem Solver:
  • 10 Answers
You have to change the poligon motor of the laser, it's not difficult, i can send you the instruction if you want
Posted on Jul 10, 2010
Kyocera 1635 sc A-0410
my dear your LD unit problem or board
Jun 28, 2014 | Kyocera KM-1505 Copier
My alficio 1035 is having a paper jam on the drum area and immediately report error SC395 this problem started after a toner hooper change. the second problem is that it is losing toner and som is falling...
SC 395 Development output abnorma.
Remove the development unit and clean the gears.If necessary change the developer.Remove the OPC imaging unit and clean the cleaning blade.
Apr 10, 2013 | Ricoh Aficio 1035 Copier
What does the code c-620 mean on a cs 1505
This is a fuser related error. Either the thermostat or thermister is faulty. The error can be rest by pressing and holding down stop, start, left exposure or light. Release the keys and press stop. The display will show U000. Press 163, press Start twice. the machine will initialize.
Nov 09, 2010 | Copystar CS-1505 Copier
Can i reset the error code sc 320
sc 320 is the laser error. the polygon mirror motor is faulty in laser unit and it can only be solved by replacing the polygon mirror motor. there is no other solution.
Oct 12, 2010 | Ricoh Office Equipment & Supplies
Hi I have Ricoh Alficio 2032 copier. There is error message C545. what does this mean and how can i solve the problem
Possible causes of your sc545
• Hot roller thermistor is out of position or most likley dirty
• Fusing lamp broken -- not likley
• Thermostat broken -- could be tripped check with a meter for 0 ohms
Once we are sure all fuser components are ok then reset the code by entering sp mode
execute sp 5810
if there is no 5810 then just turn off the machine while in sp modes
Apr 14, 2010 | Ricoh Office Equipment & Supplies
Hi I have Ricoh Alficio 2032 copier. There is C545 error message
I'm assuming it's SC545. It pertains to temp not being correct in the fuser. Possibly a thermistor, thermal fuse or lamps are bad. It's one of the codes that need to be troubleshot and replace whatever is needed before clearing the code. This is to prevent further damage to the machine. Thanks Colin
Jun 28, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio error code sc 320 what is this and how can I fix it.
Polygon mirror motor error/lock. Unplug the copier. Wait 20 seconds. Plug it back in. See if that makes it go away.
Otherwise you should get a hold of a service technician but getting parts for a 250 is very tough. It could be the polygon motor, the power supply, a cable, or a board. It will take some time to troubleshoot.
Oct 30, 2008 | Ricoh Aficio 250 Copier
Error message A 400
I'm sorry to say that it's probably the death of your 1505!
It just might be too expensive to repair, the code A400 relates to the polygon laser motor, which could mean changing the whole laser assembly, or the power source board, either way it's going to cost you. BTW, the 1505 was discontinued in June 2003, what's available today has more features at 1/2 the cost. Happy hunting...
Sep 09, 2008 | Copystar CS-1510 Copier
LANIER 5618 COPIER ERROR CODE SC-320
Yes this is a Polygon Mirror motor error it is reasonably common in the Lanier digitals. The mirror motor can be ordered separtetly to the laser unit.
Feb 11, 2008 | Office Equipment & Supplies
56 people viewed this question
jasbo
jasbo
