Question about GE Energy Star 3.7 IEC Cu. Ft. Front Load Washer with Stainless Steel Basket
I have an error code e70 on my ge adora front load washer where can I find the codes or what is my error?
  • 3 Answers
SOURCE: Ge Adora Front Loader
If you have not already done so, clean the filter behind the panel in the front bottom of the washer. Remove the three philips head screws to get the panel off. Unscrew the plastic filter on the right hand side (use a shallow cake pan to catch any water). Remove the filter and clean out the pens, pencils, change, lint, etc... and put back in. All should work well after this. Thanks, Greg
Posted on Jan 03, 2008
SOURCE: GE ADORA model WHDVH626FWW
you have to clean out the filter on the bottom by removing the lower panel and twisting the cap... careful lots of water comes out but will work great after
Posted on Dec 13, 2007
dutchman05
  • 487 Answers
SOURCE: GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Posted on Apr 23, 2008
  • 3 Answers
SOURCE: Error code E43 on display of WPRB9220DCC GE Washer
This is the beginning of a leaking seal in the gear box. Some units have a pan to catch the leak from getting to floor. Seal needs to be replaced, otherwise gearbox will fail (lot more $$$$)
Posted on Mar 16, 2009
  • 57 Answers
SOURCE: My Ge Adora washer fabric softner dispenser
You have low water pressure which wont reach the dispenser drawer during rinse cycle. Clean the feed pipe in case there's dirt in the feed gauze located at the back of the machine. The mould on the rubber is dirt in the machinme. A mixture of 1 cap of bleach and 1 small tub of Swarfega mixed with water and put into the drum on an empty wash will stop it geting worse but it cant be removed.
Posted on Dec 09, 2009
Error code E70 What is it?
E70 Stuck key Continuous key read for 60 seconds. Power down (unplug) machine, wait 30 seconds and retry. Use t04 test to test keys. Separate control and control housing from front panel - clean and remove foreign debris. Ensure all keys can be operated freely without sticking. Replace control panel if actions do not resolve. Maybe this will help
Oct 27, 2013 | GE Adora Front Load Washing Machine Washer...
What is an E70 error code in a GE Adora Front load washer?
E70 stands for a stuck key. Try unplug for 60 sec. Then try again. If not unplug and try to open and clean buttons of debris
Oct 27, 2013 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Washes starts buzzing and blinking and says e70
The e70 error code comes on when the hot and cold water hoses are reversed or not properly installed.
Feb 21, 2011 | Frigidaire Affinity ATF7000E Front Load...
Error code #E70
Hi
Error code E70 means Cold water hose is connected to wrong faucet or Cold water faucet is not turned on. If this is not the case then check the cold water hose, whether it is kinked or plugged. If the hose is fine then the fill valve assembly has turned bad and you would need to replace the valve. Connect hose to cold water faucet and cold water inlet on washer. Be sure cold water faucet is fully opened.Hope this helps... Please post back for more information.
Daniel
Nov 16, 2010 | Kenmore 43142 Front Load Washer
E70 error code
The main cause for this e70 error is that the hoses would have swapped (hot to cold, cold to hot). It means the washer isn't getting cold water.Try to switch between the hoses. Another possibility is the faucets are not turned on.... Hope this solution will fix your problem for sure.
Mar 30, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error Code E70
water fill problem ,,,check fill hose for kink,,,or lost of water pressure,,,you may need to clean inlet vavle screens..onthejob
Dec 20, 2008 | Frigidaire Affinity ATF7000E Front Load...
GE Energy Star 3.7 IEC Cu. Ft. Front Load Washer with Stainless Steel Basket Logo
500 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
