Question about Kenmore 71121 Air Conditioner
Just put in the window for the first time his year
Seems like the compressor isn't working. It working just like a fan would. No real cold air. It worked fine last year. Is there a fuse or reset?
  • 29 Answers
No fuse or reset just for the compressor. Since the fan is working only, you will have to open up the unit and see what you have. Possible causes: 1. bad thermostat
2. a wire burned off
3. bad capacitor
4. low on refrigerant
5. bad compressor
Posted on Jul 09, 2010
1995 Isuzu Rodeo AC isn't working....
You mean there is no cold air coming out the vents, right ?
What are the gauge readings ? Is the freon flowing thru the system ?
Is the radiator fan running when the compressor is ?
May 04, 2013 | 1995 Isuzu Rodeo
GR-349SQF won't freeze
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
R
Jan 17, 2012 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator (GS6SHXLQ): Freezer does not working at all.
Jan 16, 2012 | Whirlpool Refrigerators
My freezer is no longer freezing
Regards.
Sep 14, 2011 | Hotpoint Freezers
I've had my air conditioner for a few years now and it no longer cools anything. The fan works, the condenser(?) turns on when I set it to cool instead of fan, but the air coming out of it isn't...
You need to determine if the compressor is running, if it is and you have no cooling then you either have lost charge or bad compressor, these units re not worth replacement compressor
Jun 22, 2011 | Goldstar R5208 Air Conditioner
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
Compressor comes on, some cold air, no fan?
Try spinning fan by hand. If it spins freely, change capacitor. If fan is tight, change fan motor.
Apr 08, 2010 | Fedders AED24E7F Wall/Window Air...
Campbell hausfeld mod wl611700aj runs for 3-5sec
If the motor isn`t bad,then the one way (check valve )is not working,putting to much pressure on the head.
Oct 05, 2009 | Campbell Hausfeld 28 - Gallon Air...
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Kenmore 71121 Air Conditioner Logo
77 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
