Question about Black & Decker Garden
Electric Chainsaw - chain stops when you try to cut!
My balck and decker GK430 chainsaw has a problem. The elecrtric motor whirrs up fine, but when you try to cut the chain moves for a short time then stops cutting. The motor is whirring as though it would cut if the chain was moving. What is the problem? Does anyone know the most likely part that will need replacing?
    Brigadier General:
  • 4,088 Answers
Remove the bar and chain--check the sprocket and shaft for any mechanical damage. Try to turn the sprocket by hand in a CCW direction, does the shaft move with it? Does it seem to turn the motor? If the sprocket and shaft seem ok, then you may have a damaged gear (likely plastic) within the gearbox. Hope this helps!
Posted on Jul 09, 2010
New GMC electric chainsaw runs until it try's to cut wood. Motor runs but chain dose not turn ? Turns if not on wood.!
problem in the safety clutch area
ensure that the safety bar is fully back and engaged before pressing trigger
the safety bar is that handle at you fingers when you are holding the the saw handle and by moving , flicking your fingers forward it stops the chain action
if that is fully engaged , it will require servicing by any accredited chainsaw repair shop
Apr 23, 2017 | Electric Garden
How to repair a chainsaw
your clutch springs are weak. replace springs or clutch assembly
Jul 17, 2014 | Black and Decker USA BLACK & DECKER...
Use maintain chainsaw
if your question is "best way to care and use a chainsaw"
care: well that's slightly different for a gas model vs an electric model
gas models should not be stored for longer than a week with fuel in it's system (tank,lines,carb) as the gas will evaporate and cause deposits to form (hard) and clogg up the small ports in there
electric models, should be inspected for cuts to cord and general safety ck over saw to make sure it's not going to shock you
just because they show it on tv , chain saws are not for cutting in water or around water , one its not good for the metals the saw is made from and two if water gets inside the motor (gas or electric) its no longer going to run anymore
always keep your chain oiler full of bar oil (not motor oil) and top off every 30 min of use
and sharp chains cut cooler and longer than dull chains , lot less effort too
Jan 08, 2014 | Black & Decker Garden
What type of bar chain oil should I use
For spring/summer use, you can use Motomaster ("spring/summer") or Stihl "medium" chain oil. If you use in very cold winter condition, you need thinner oil, specifically made for it.
Feb 02, 2013 | Black and Decker USA BLACK & DECKER...
Chain stops when offered to the wood to cut
either a bad clutch or a bad gear in the drive head
Aug 19, 2012 | Bosch AKE 35 SDS Electric Chainsaw
What type of oil does my black and decker chainsaw need
You can use SAE 30 weight motor oil or bar and chain oil. Press the bulb on the resevoir cap 2x before each cut making sure the saw is pointed down and to the right to let the gravity feed oiling system work properly.
Jan 05, 2011 | Black & Decker CCS818 Chain Saw
I have a 1600w electric black & decker chainsaw recently purchased that simply takes forever to cut the smallest of logs. Is this the norm?
Hi there Bugs,
Definitely not the norm. I'm guessing that although it was recently purchased, it was used?
It will either need a new chain or have the old one professionally sharpened. You didn't mention bar size, but a new chain should be between $18-30.00.
A less expensive alternative would be a small engine repair shop that services chainsaws. Most also have reconditioned chains for sale.
Eight days ago I picked up a 19" bar banana bar and used chain for $15.00 total to finish some oak. It Rocks.
Try the chain change. Difference? Night and Day.
Best regards
Mike
Jul 30, 2010 | Black & Decker Garden
Blade wont move
there is a broken gear in the gear reduction box. (explain:) the motor spins at a high rpm, the chain moves at a 1/4 or less rpm than the motor. a series of gears reduces the speed, which in turn creates torque, allowing the saw to have the force to keep cutting without stopping. One of the gears is broken or a keyway on a shaft is sheared...as far as i know, no electrical power tools are rebuildable. it's a safety thing (electric shock if reassembled wrong...they are priced for replacement...get a new one...
Jun 06, 2010 | Black & Decker CCS818 Chain Saw
Chainsaw electric motor jammed
Remove the chain, then see if it will turn over by hand. Does it have a chain-brake??? Frankster016
Oct 18, 2008 | Electric Chainsaw Sharpener
Garden Logo
230 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
