Question about Kenwood KDC-2011S CD Player
My Kenwood KDC-3011 will not power on
My battery died and now my radio will not turn on, I have pressed power button, replaced 10amp fuse, I hear CD player initialize but nothing on display.
When detachable face is off red LED blinks.
robotek
  • 1512 Answers
SOURCE: Kenwood KDC-322
If you have the remote control for the unit, or can buy one then you can reset the code. Just ask me how...
Posted on Feb 08, 2008
  • 78 Answers
SOURCE: kenwood kdc 3011 rests its self every time i turn the car off
This means that the power lead you connected the red and yellow to is a switched live and each time you turn off the ignition the power goes off and therefore resets. to fix this problem you need to connect the yellow to a permanent 12v supply that stays live when you turn off the ignition.
Posted on May 28, 2008
SOURCE: Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
Posted on Dec 09, 2008
shagone
  • 34 Answers
SOURCE: lost the Code for Kenwood Car-radio KDC-W6527
Try code KCAR entered from the remote
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press and hold the "Auto" button and "Track up" (next track button on the right) on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
i hope this works for you.
Posted on Jan 08, 2009
  • 3 Answers
SOURCE: Kenwood KDC-MP438U "USB ERROR"
IF YOU DID NOT PRESS THE RESET BUTTON NEX TO THE USB PLUG, DO IT. IT WILL REINITIATE THE DEVICE TO THE FACTORY; YOU WILL HAVE TO ADJUST THE CLOCK.
I DID BECAUSE IT WAS WORKING AT FIRST.( PAGE 3 OF THE MANUAL)
CLAUDE
Posted on Jan 19, 2009
Kenwood kdc mp142
press the reset button or hold to am button for some time to turn on am radio and check if ST indication is ON
Jul 19, 2013 | Kenwood KDC-MP142 Car CD/ MP3 Player
How Do i Turn on The LOUD option on my kenwood KDC-MP205
Unless you turned it off, Kenwood radios automatically have the loud turned on when the radio is first powered up.
Jul 10, 2011 | Kenwood KDC-MP205 CD Player
Kenwood KDC-MPV 7019 code
Kenwood Code reset for KDC-MPV7019: (remote required)
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>| and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>| key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>| key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>| key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>| key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
MANUAL for the same radio
Jan 15, 2009 | Kenwood KDC-MPV7019 CD Player
Got a new Kenwood KDC-128 car radio recently, fitted it but the radio presets would not stay when the ignition was turned off. Then it stopped working altogether and I noticed the 10amp fuse at the back...
you need to hook the yellow wire off the back of the radio up straight to the battery this keeps memory power to the head unit then wire the wires in color coded sequence red to red black to black so on and so forth if this doesnt fix it you might want to think about replacing head unit
Jan 02, 2009 | Kenwood KDC-128 CD Player
How to set europe freq on KENWOOD KDC-BT838U car radio
Last night i got the answer from KENWOOD Support
Press and hold in the SRC button until the unit turns off. While power is OFF,
press and hold FNC and AUTO/TI buttons, and momentarily press the SRC button to
power the unit back on. Continue to hold the other buttons until the unit comes
back on completely.
I did it and it works
Enjoy
Dec 26, 2008 | Kenwood 2005 KDC-MP5028 CD/MP3...
Kenwood KDC-MP922
there is a button under the back of the face in one corner, just press around the back of the face with the car on until you feel the button press in and it should open.
If not you may have a bad ribbon cable that is not too expensive to replace.
Sep 09, 2008 | Kenwood KDC-519 CD Player
Kenwood kdc 3011 cd player
Have you tried the balance and fader control?
Also make sure the ground or - negative wire has a good connection for that speaker from the back of the unit. Or it could be the internal amplifier it self.
Dan
Aug 17, 2008 | Kenwood KDC-2011S CD Player
Kenwood kdc 3011 rests its self every time i turn the car off
May 27, 2008 | Kenwood KDC-2011S CD Player
KENWOOD RADIO
take a pen and press the reset button ...it's a tiny little button next to the button that takes off the faceplate...
Jan 18, 2008 | Kenwood KDC-MP235 CD Player
Kenwood KDC-2011S CD Player Logo
117 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
