Question about CP International WBR-3406TX Wireless Router
Unable to renew ip adress
I am trying to setup a WBR-3406 linksys wireless router. After connecting the dsl to the router and the router to the laptop. i got unable to renew ip adress error
    Brigadier General:
  • 10,406 Answers
This is a "duplicate" of your other question:
http://www.fixya.com/support/t5158968-set_up_wbr_3406_tx_router_dsl_modem
See that question for more information.
Posted on Jul 13, 2010
How to set up wbr-3406 tx router with dsl modem
Take an Ethernet cable, and connect the Ethernet port on the DSL modem to the WAN port on the router.
Take another Ethernet cable, and connect one of the LAN ports on the router to the network-port on your computer.
Now, you should be able to web-surf.
Access the web-server inside the router, and run the "Wireless Network Setup Wizard", to configure your wireless networking.
Jun 24, 2010 | CP International WBR-3406TX Wireless...
Im trying hook up a wireless router and it ask what kind of conection I have static ip ect... How do I know what I have? Im using DSL.
Most residential subscriber services use dynamic IP addressing. Dynamic IP addressing is automatic from your Internet Service Provider (ISP). Linksys home based products such as the one you have should be setup up for this configuration out of the box by default, and require no adjustments to the IP configuration of the wireless router.
You should power down the DSL modem and Linksys, then connect them, then reapply power. This will clear the DSL modem if it was connected to another device such as a PC. This is important as most cable and DSL modems use something called MAC address binding that will only allow one device to connect to it directly at a time.
Feb 06, 2010 | Linksys Wireless-N WRT150N Router
Please help! Been trying since Saturday to connect router!
Put the setup CD in a drawer. Set your computer to Obtain a DHCP automatically. Plug in the router to the AC outlet. Plug the computer into any of the LAN ports of the router. Start the computer or do a DHCP renew. Now do an IPCONFIG. Do you have a 192.168.1.x address? Go to IE and use 192.168.1.1 in the address bar. Do you get the login screen? The username is left blamk, the password is "admin". Are you there?
Now, just because I put the cart before the horse, are you possibly using one of those 2wire or Netopia DSL routers? Is it possible that the IP address for it is 192.168.1.254 or worse, 1.1?
Bzzt. Give your router a neat address like 192.168.1.251 and turn off DHCP. Now, plug the WAN port into the modem. and point your browser to 192.168.1.251. Whoa! Did I guess right?
Let me know.
Carl
Jun 30, 2009 | Gateway Wireless-B Router (wbr-100)
No internet connection,
hi
if you have already configure your router and it was working following thing could have happen
1) you have lost connection to internet ...go to your router setup page under status make sure you have connection
2) once you have your router connected re-boot your laptop or pc or renew your wirless connection
good luck
Jun 12, 2009 | Linksys WRT54G2 Wireless Router
Ip problem
It is common to have this as the default IP to connect to equipment.
I suggest you unplug your modem while you set up your router. You can also change the default IP for the router while in the settings. be sure to remember the new IP or you will have to do a factory reset to get it back to default
Jul 03, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Trying to get my linksys wireless router to go on dsl .
All you need to do is change the Linksys router's IP address. Because the westell and the linksys has the same range of IP address that creates a conflict on your network that's why you can't get online.
First login to the setup page of your linksys router.
  1. Under the Setup Tab (this is the first screen that you will see after typing in the linksys router's password.) make sure that the Internet connection type is set to Automatic Configuration- DHCP, Then on the same page look for router IP address or LAN IP address. By default its 192.168.1.1, you need to change it to 192.168.2.1. And hit save settings. You will get disconnected from the linksys page, that is normal. If you want to log back in to the router page you use the new address of your linksys (192.168.2.1).
  2. Now you restart your computer to refresh the connection and that should get you online.
May 07, 2008 | Linksys Wireless-G Broadband Router
WRT54GS wireless router problem
It's possible that the wireless network is secured. you can access the router setup page to check if there is a security enabled. You can follow the steps on this link.
May 06, 2008 | Linksys Wireless-G WRT54GS Router...
After changing LAN IP, can not access setup page
If using DHCP, reboot your machine or release and renew the IP on the network card. If using static IP addresses, change the computer's IP address to match the new segment and remove the old default gateway and replace with the new LAN IP.
Feb 16, 2006 | Linksys WRT51AB Wireless Router
CP International WBR-3406TX Wireless Router Logo
115 people viewed this question
Top CP International Computers & Internet Experts
David Payne
David Payne
Are you a CP International Computer and Internet Expert? Answer questions, earn points and help others
