Question about Janome 6019QC Mechanical Sewing Machine
I have an older janome sewing machine v/740881/612 the power plug into the machine is broken do you have a replacement plug for this model? from susannah
5 Suggested Answers
lavon82931
  • 17 Answers
SOURCE: owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Posted on Jan 25, 2009
  • 19 Answers
SOURCE: manual for Janome Harmony 2049 sewing machine
www.janomestuff.com answer it all
Posted on Sep 16, 2009
SOURCE: How to thread sewing machine Janome model 372
google how to oil and thread a bernina 900 if your janome is like mine this video will help you.
Posted on Dec 07, 2009
hazelgrace
  • 340 Answers
SOURCE: How do i thread a
Hi
I couldn't find a manual on the Janome site for the machine you have but I did find this one for a similar looking machine. It should be enough to get your started on how to thread your machine and what the different parts are for.
http://www.janome.com/documents/File/ManualFile/Sewist509.pdf
Posted on Sep 04, 2010
Where from can i get complete bobbin case the part was missing in my old Janome machine
Have you tried a Janome dealer? Sometimes they carry parts for older machines or maybe they can order it.
Aug 07, 2016 | Janome Sewing Machines
Are older models such as the Janome New Home s650 supposed to stitch in reverse?
Your machine is most likely stuck in reverse if that is the only direction it sews.
Feb 11, 2016 | Janome Sewing Machines
The lcd on my janome mc 9700 is broken/faulty can this be fixed
There are sometimes replacement parts. Call Janome and see what they suggest.
Oct 05, 2012 | Janome Memorycraft 9700 Computerized...
How to set up
  • Remove your Janome sewing machine from the box, placing the main machine on a hard surface appropriate for sewing and the accessories and smaller items to the side. Unwrap all of the wrapped items. Remove the tape used to protect the machine during shipment. Set aside the power cord and foot pedal.
  • 2
    Attach the power cord to the machine. The power cord plug-in area is located on the lower right side of all Janome sewing machines and has a series of metal prongs and a power switch. Fit the female end of the power cord onto the metal prongs and push it gently until it no longer moves.
  • 3
    Attach the foot pedal to the machine. The foot pedal plug-in is also located on the lower right side of all Janome machines, right next to the power cord plug-in. Press the foot pedal plug-in into place gently until it no longer moves.
  • 4
    Turn the power switch on. The power switch is located in the same area as the foot pedal and power cord plug-ins and is a rectangular black switch. Press this button. The sewing machine light will turn on.
  • 5
    Place a spool of thread on the spool pin, located on the upper right top side of the sewing machine. Place the thread so that the thread unwinds in a counterclockwise motion, with the thread coming off the back of the spool.
  • 6
    Insert a needle into your machine. Consult your owner's manual for the appropriate size and type of needle. Turn the needle clamp screw, located above the needle area, toward you to loosen it. Turn the needle so that the flat part of the upper shaft area faces the rear and slide the shaft of the needle up and into the needle area. Turn the needle clamp screw away from you to tighten the needle and lock it into place.
  • 7
    Wind the bobbin and insert the bobbin into the bobbin case. This procedure may vary depending on the model of your Janome machine, so consult your owner's manual for specific instructions.
  • 8
    Thread your machine according to the directions in your owner's manual. Like the bobbin, this procedure can vary widely depending on the model of your Janome machine.
  • 9
    Set your tension, located on the front of the machine, to halfway between three and four. The tension may be a dial or it may be computerized and located on the LCD screen, depending on your model. Consult your owner's manual to find out how to set the tension.
  • 10
    Place a piece of scrap fabric in the machine and sew a test seam before you start to work on a project to make sure all of your settings are correct.
    Things You'll Need
    • Janome sewing machine
    • Owner's manual
    • Needles
    • Thread
    • Bobbin
Jan 11, 2012 | Janome Sewing Machines
I have lost the foot pedal and power cable for my Janome sewing machine model no JD1722 could you tell me where I can get a replacement?
Type in Janome parts into your seach and it will give you a listing. I have a local sewing center that sells Janome and they can order parts for mine.
Sep 22, 2009 | Sewing Machines
Left prong is broke off the machine plug.
If the power inlet on the actual machine is broken, you will need to find a local Janome dealer and see if the part is still available to order, or any sewing repair shop that deals in servicing all brands may have an old one from a deceased machine that will suit you.
I am not familiar with this model in Australia, it may have come out with a different code reference here.
Phone around locally is my suggestion, we here come from all around the world.......beyond the oceans of where any of us call home !!
Feb 04, 2008 | Janome 8080 Computerized Sewing Machine
Janome 6019QC Mechanical Sewing Machine Logo
133 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
